11-13-2011, 08:51 AM
#46 | ||
Oddometer: 1,638
But I don't hear many with standard forks bending them, breaking them or speaking of flex all over the place. 41mm tubes are fairly beefy. Except for the small few, these beemers are not ridden at their limit. Mine won't be, but I now will be able to push harder, or do tougher terrain more confidently. It seems the F800 crowd say its ok to spend and upgrade on their 800, but say to stay away of doing so on the 658. The needs are different between bikes. I only call my improved 658 a better little brother... The 658 can be bettered for a modest amount.
Horsepower is a distant second to useable torque, unless cafe cruising is the reason for the purchase... Quote:
11-13-2011, 09:09 AM
#47 | |
its Ground Zero
Oddometer: 574
Sorry if I sounded like I was downplaying your conversion.. I wasn't and I think its totally BA. The post I quoted sounded like they were coming to the conclusion that there wasnt much of an advantage with starting with an 800. And the 800 does have some advantages, at a 2k price tag. Again awesome build, and im sure that many will follow. You have inspiried me to look into beefing up the front end on the wifes 650. Thanks again!! Ryan
XOVERLAND.COM Our vendor thread HERE Season 1 Done!! HERE 6 Full Episodes Free on our website!!! If you like it, "Like" us on FaceBook 2010 F800gs (Mine) 2011 F650gs (Wifes) |
11-26-2011, 07:07 PM
#48 |
Oddometer: 32
Now that you have had some time on the bike. What is the quality of the suspension like? Yes you have more travel but is it better? I am very interested in this mod but am still uncertain if this is the way to go or if I should be doing a complete fork swap.
Anyone out there done a swap for a longer travel fork on their 658? |
11-27-2011, 07:17 AM
#49 |
BACK ROAD BOMBER
Oddometer: 1,105
check lucas m's posts he took a 658 put a ktm front end on it, an 8 shock and body work.
http://www.advrider.com/forums/showthread.php?t=662093
“An adventure is misery and discomfort, relived in the safety of reminiscence.” Marco Polo 09 F 650 GS twin XR 400 Beta Techno |
11-27-2011, 06:42 PM
#50 | ||
Oddometer: 1,638
Initial feel was the front end is stiff. My suspension guy says forks (fork oil) are stiffer in freezing weather. Anyone have experience with this? Race Tech guts are adjustable, so its a matter of nailing it on adjustment (on my bike). I think you could do longer fork tubes ONLY and a 800 shock and keep the stock plush suspension and have the height increase and a pretty nice bike. The rear HyperPro shock feels real good and has the 9" of travel. My forks still have the stock 7.1" travel although the bike is at equal height f & r (due to the longer tubes). Right now my bike is not as plush as it could be - it needs some more dial in time...
11-27-2011, 09:20 PM
#51 |
Oddometer: 32
Thanks for the info. I think if I do something it will be a similar mod to yours. I need the extra clearance and better quality suspension at the same time, but I want to maintain the stock wheel size.
03-01-2012, 07:07 AM
#52 |
Oddometer: 326
The original poster was looking for increased ground clearance on his 658 as a top priority and he got it. For me, I don't want greater seat height as I am short in the first place and like the ability to flat foot my 658. Also, my "off pavement" is only dirt roads and for me that's all it will ever be. I did want to improve the suspension however.
Ricor intiminators in the forks and a Ricor shock pretty much transformed the bike. Way better ride and control.
A gun is like a parachute. If you need one, and don’t have one, you’ll probably never need one again |
03-01-2012, 10:44 AM
#53 | |
Oddometer: 3,430
Is this the rear shock you used: http://store.ricorshocks.com/product_p/bmw-gs-650.htm ... on sale now ... $340 bucks knocked off the price ... Still it punches a big hole in $800 with the hyd. preload adjuster. |
03-01-2012, 12:24 PM
#54 |
Oddometer: 326
So is your seat height about the same as the 800? I'm 6'1, 198lbs and would like this mod on my soon to buy f650 :-) heading to Max BMW on Saturday to test drive and pick a color....
12' BMW Sertao For everything 01' Triumph Bonneville Holligan Bike 94' Suzuki DR250 strickly woods 74' Kawasaki G3SS possible vintage race bike. |
03-02-2012, 12:00 AM
#55 |
Oddometer: 326
JRWooden: yep -- that's the one. No external pre-load adjuster on mine.
03-02-2012, 04:11 AM
#56 | |
Oddometer: 3,430
So if you elect not to drop an extra $200 on the preload adjuster you get the conventional pair of threaded-what-the-hell-ever-they-are called "nuts" that you adjust by spanner? Is there pretty reasonable access to get in there and do that? |
03-02-2012, 06:19 AM
#57 |
Oddometer: 326
Don't really know yet -- still looking for a C-Spanner (hook spanner). Haven't found one off hand yet but I haven't looked too hard yet either. If I had to do it over again, I think I'd spring for the preload adjuster and be done with it.
03-02-2012, 06:38 AM
#58 | |
Oddometer: 3,430
03-02-2012, 07:35 AM
#59 |
Oddometer: 326
Suggest you contact Brian at Ricor directly. He is really helpful. Tell him Tonopah sent you!
Brian@ricor.com
03-02-2012, 07:37 AM
#60 |
Oddometer: 326
