Old 03-29-2005, 11:25 PM   #1
Converted Soul OP
On the search dude
Converted Soul's Avatar
Oddometer: 288
Heavier spring for 640 adventure?
I'm loading my 2003 640 adventure up for a trip trough Africa but wonder if it is wise to fit a stronger spring to the rear. It now has an 70-260 spring (meaning 70 kilo with 260 length).
I fitted the Touratech alu canisters (empty) and fixed a spare rear tire to the rear of the bike and already the bike drops way low to the ground.
KTM Adv 640, 2003
DAF YA-4440
Converted Soul is offline   Reply With Quote
Old 03-29-2005, 11:42 PM   #2
Buckster
Buckster's Avatar
Oddometer: 1,003
I'm fitting a stronger one to mine, they are readily available from your local WP importer. I am upping the springs in the forks to.
Buckster is offline   Reply With Quote
Old 03-30-2005, 04:23 AM   #3
Stobie
Mr. Motivated
Stobie's Avatar
Oddometer: 1,865
What rates are you going with Buckster, and what do you weigh?
I weigh 215# (down from 240 and still dropping), and I just received a set of .48 for the front and 8.0/260 for the rear. Almost went with .50 on front, but several suspension gurus recommended against it. Hopefully I'll install them this weekend.
Stobie
Problems cannot be solved at the same level of awareness that created them.
-Albert Einstein
Stobie is offline   Reply With Quote
Old 03-30-2005, 04:50 AM   #4
Mack
Gone, but never forgotten. RIP, Mack...
Mack's Avatar
Oddometer: 3,797
Stobie, any line on who has the .50's? If I can find those, I will order them for the 950 and move the OEM .48's from the 950 to the 640.
Österreichische Motorräder und deutsche Autos. Wie wundervoll kann das Leben sein
Mack is offline   Reply With Quote
Old 03-30-2005, 05:05 AM   #5
Hipster
Hipster's Avatar
Oddometer: 1,811
WP's stiffest spring is a 0.48, if you need anything stiffer you'll have to go with an aftermarket spring such as Eiback. Check out http://www.racetech.com/ for further infomation.
Hipster is offline   Reply With Quote
Old 03-30-2005, 05:55 AM   #6
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,239
If you are going to Africa on your MC then we have no sympathy for you and your problems... where's the jealousy smiley?
Anyhow, have a great trip and please send postcards! You doing a prelim writeup or anything?
PS - the stock Adv setup is for a 165lb rider so anyone who is north of that and loading gear on should definately beef up the shock and forks.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 03-30-2005, 06:38 AM   #7
SRG
SRG
SRG's Avatar
Oddometer: 1,288
Good thread. I have been thinking about heavier springs for the froks of my '02 640 Adv. - sound like the 48's are the right wt. for me. These would be the same as the the stock springs from a 950?
SRG
Lazy Traveler
SRG is offline   Reply With Quote
Old 03-30-2005, 09:55 AM   #8
Stobie
Mr. Motivated
Stobie's Avatar
Oddometer: 1,865
Call Brad Lowe at Lowe's Racing: 989-288-6068. He has no website that I can find, and you might have to leave him a message for a callback, but he probably has what you want on the shelf. From what I understand, he stocks fork springs at least up to .52, and rear shock springs up to 11.0. The rear springs are actually for the PDS shock (but linear instead of progressive), so the ID is slightly larger (63mm v 59mm), but the length is the same, and fitment is no problem.
Also good news is that the fork springs are $80, and the rear spring is $80, include $10 shipping, and I'm respringing both ends for $170. I ordered them Thursday, got'em yesterday.
Stobie
-Albert Einstein
Old 03-30-2005, 09:57 AM   #9
meat popsicle
Ignostic
Oddometer: 14,239
your fitting an 11.0 rear?!? i'm thinking bursitis in a month...
Old 03-30-2005, 10:10 AM   #10
Converted Soul OP
On the search dude
Oddometer: 288
I'll make sure that you envy me even more after you see the pictures and story that's coming in about one to two months time.
The plan is to go through Marocco, Mauritenie, Senegal, Mali, Burkina Fasso to Ghana and then shipping the Adventure back by boot from Accra.
I'm going for the 85 kilo rear spring (does somebody know how to convert that into imperial measurements?)
KTM Adv 640, 2003
DAF YA-4440
Old 03-30-2005, 10:23 AM   #11
GODSPEED
finger lickin' good
GODSPEED's Avatar
Oddometer: 2,077
Conversion Link
187.39#
Godspeed
I'd rather do it than watch it.
Those of you with spouse and SO's know this already, but man give them a big hug, and don't take anything foregranted. - MACK RIP
When 51% of the grasshoppers vote, the ants are screwed.
http://godspeed.smugmug.com/Motorcycles
GODSPEED is offline   Reply With Quote
Old 03-30-2005, 10:31 AM   #12
Buckster
Buckster's Avatar
Oddometer: 1,003
In weigh 200-205 and am going with a 80/250 which is right for my weight allowing for riding gear and giving space for winding in some more pre-load to allow for luggage.
Old 03-30-2005, 12:17 PM   #13
Stobie
Mr. Motivated
Stobie's Avatar
Oddometer: 1,865
Reading comprehension, Meaty.
Stobie
-Albert Einstein
Old 03-30-2005, 12:26 PM   #14
MotoMike
Washed Up Desert Racer
MotoMike's Avatar
Oddometer: 5,047
I just recently had my suspension done. ESP in La Cresenta, CA. did the work. I weigh 225, the spring they used in the rear is a Eibach 0900,225,0475. I believe they had to machine a spacer as well.
Lost Coyotes MC
MotoMike is offline   Reply With Quote
Old 03-30-2005, 12:33 PM   #15
meat popsicle
Ignostic
Oddometer: 14,239
(giggle) sorry couldn't help myself...
Times are GMT -7.   It's 01:11 PM.
