01-14-2013, 04:54 PM
#331 |
Trail Trundler
Oddometer: 60
I would be really interested to hear and see more about this Rekluse clutch kit if you could please? Has it robbed any power from the bike? I don't know much about these things – is it just like having one big centrifugal clutch? Has it added any weight?
01-14-2013, 06:13 PM
#332 |
Swagman
Oddometer: 629
Same here, give us a rundown...
01-14-2013, 11:39 PM
#333 |
Carbon-based bipedal
Oddometer: 2,028
no added weight you could detect. they don't rob power. i installed it on a different bike but the benefits and issues i found with the basic EXP model will be pretty similar to those on any model, read here.
01-17-2013, 01:00 AM
#334 |
VMX Tragic
Oddometer: 4
I fitted a heavier rear spring tonight and the bike sag and rider sag are now to KTM specs.
The standard spring SHOULD have suited my weight but was too light. Ride time tomorrow (RDO) so it will be interesting to see how it performs. I strongly believe suspension is the first and most important thing to set up on any bike
The older I get, the faster I was |
01-18-2013, 12:16 AM
#335 |
VMX Tragic
Oddometer: 4
The heavier spring works a treat. This bike just keeps getting better!
01-20-2013, 09:28 PM
#336 | |
Conquistador
Oddometer: 109
i contacted the spirit world but they don't know what's wrong with my 690 either |
01-21-2013, 12:06 AM
#337 | |
Trail Trundler
Oddometer: 60
01-21-2013, 11:41 AM
#338 | |
Conquistador
Oddometer: 109
apart from the incorrect banjo fitting and an extruded o-ring everything else seemed to fit fine. a couple of pics installed ![]()
01-21-2013, 11:51 AM
#339 |
Conquistador
Oddometer: 109
Sorry for the later reply. It took me awhile to get around to opening an online photo albums.
A few pics of the sump guard ![]() ![]()
01-21-2013, 12:56 PM
#340 |
Oddometer: 4,243
I recently pulled all the restrictors out if the exhaust and opened up the filter cage.
To get some more fuel down its gut I fitted a bazzaz z-fi fuel controller. The bikes been geared up 2 teeth on the front and it was a bit dead but now the restrictors are pulled out and the mapping done it goes like stink. The 12t front sprocket allows the rider to keep up with the big bikes on the transport sections (130kph easily doable) yet it wil still idle along in first gear at walking pace without any threat of stalling. It's a great motor and gearbox. |
01-22-2013, 01:19 AM
#341 |
VMX Tragic
Oddometer: 4
I looked at one of the KTM accessory bash plates as the original is a bit of a joke. The price was a bit much but the shocker was when they told me there were 55 on back order!
I'm in the process of making one to give a bit (lot) more coverage. Mine covers half of the ignition cover on the left and the water pump on the other side.
01-22-2013, 02:20 AM
#342 |
Trail Trundler
Oddometer: 60
01-22-2013, 02:21 AM
#343 |
Trail Trundler
Oddometer: 60
01-22-2013, 02:42 AM
#344 |
Oddometer: 4,243
No it was way to lean I did not try to find out how well it went in fear of cooking something.
I'm not sure what map was in the stock ecu to start with it could have very possibly been the restricted map even though the bike was supplied with the air restrictor/filter cover removed. The bike felt lean from the day it was delivered. I used the bazzaz z-fi unit with there self tuner, Its easy to use and works really well. I set it up with two maps one for power and one for fuel economy. |
01-22-2013, 03:08 AM
#345 | |
Podge NT
Oddometer: 1,612
Are you playing with things made post 1980 Joe ? A bit dangerous dont you think?
http://share.findmespot.com/shared/f...1IWs2Hg87TZcsW Plan, what plan, there is no plan |
