Old 03-20-2014, 11:09 AM   #1696
Glennius
Glennius's Avatar
Oddometer: 9
Wicked
Hi isalas...
I think what you are looking at is the water pump. To be more specific; that is the 'weep hole'.
You may see a drip or two of coolant come out but no more than that.
That is just a passage for coolant that slips by the seals to exit the case.
Hope this helps...
Glenn
Originally Posted by isalas16 View Post
Hi everyone, I'm looking for a little help identifying a part, I'm about to purchase a used 2000 miles, 2013 crf250L, however I noticed today while looking at it that there is a piece broken off, I think its the water pump or cover for the pump,
I highlighted the picture below with the scree that has its head broken off, and a piece of the aluminium cover its also broken.
Is that easy to replace? how much do you think it costs?
Present: 2013 Honda CRF250L
2007 Honda CRF230L
1982 Honda XR100
1980 Honda XL80S
1976 Honda CT70 (First Machine) Nope, didn't get laid! (Fun though!)
Glennius is offline   Reply With Quote
Old 05-04-2014, 06:29 AM   #1697
Balitarolo
Balitarolo's Avatar
Oddometer: 3
Question crf250l fuel filter
Is there fuel filter in crf250l?
Is there fuel filter kit for crf250l?
I am going to travel with this bike but some country petrol is very dirty. and I tough this item will be help a little avoid the engine or/and fuel pump damaged. http://youtu.be/CIi1Ratt5Is?t=3m19s
Balitarolo is offline   Reply With Quote
Old 05-04-2014, 08:44 AM   #1698
Ed@Ford
Oddometer: 1,683
see fuel filter info here http://www.cheapcycleparts.com/oempa...212a/fuel-tank
Requires removal of the fuel pump from a large hole in the base of the fuel tank...a real pain in the ass.....plan on carrying a filter sock or something to filter the fuel as it's poured into the tank. I've seen somewhere...can't remember where at the moment...a top-hat shaped filter sock to put into the top of the tank to filter fuel as it's poured in...but it won't work for the honda because of the bars across the inside of the tank to keep from damaging the pump assembly with the filler pipe at the gas station.
Ed@Ford is offline   Reply With Quote
Old 06-04-2014, 09:26 PM   #1699
Sierra_Lima_Hotel
Sierra_Lima_Hotel's Avatar
Oddometer: 36
Keep both! You won't regret it - two totally different bikes. Plus, you'll never be without a ride :)
Sent from my iPad using Tapatalk
Sierra_Lima_Hotel is offline   Reply With Quote
Old 09-04-2014, 06:36 AM   #1700
KxRuss
Oddometer: 29
Hi all I think im going to buy a crf250l tomorrow. Is there anything that needs doing before taking it on a several thousand mile trip other than first service and how do you run it in fast or slow?
KxRuss is offline   Reply With Quote
Old 09-05-2014, 01:54 AM   #1701
KxRuss
Oddometer: 29
Now bought it and pick it up on Monday
Old 09-05-2014, 09:18 AM   #1702
Auto-X Fil
Oddometer: 703
I ran mine in hard without issues. By the book, the first 600 miles should be easy, low-revs, low-speed, with highly varying speed and RPM.
Just ride it. It'll be fine.
Auto-X Fil is offline   Reply With Quote
Old 09-22-2014, 08:26 PM   #1703
rallyeman
Dakarboy -
rallyeman's Avatar
Oddometer: 165
Originally Posted by Alvega View Post
I think this bike is all that I want.
I want to test ride it first but isn't easy around here.
Do you think it will be available for this CRF250L a customised front fairing look alike the new CRF 450 Dakar :
About this one
rallyeman is offline   Reply With Quote
Old 12-10-2014, 05:50 AM   #1704
JettPilot
Oddometer: 962
Originally Posted by hammick View Post
The exhaust is nice and has a nice sound but then again I never road the bike stock. I am running the 13t/42t so it does get loud if running WOT at 65mph. I think it will make a very nice trail exhaust.
I am used to much bigger bikes so I probably won't do any long distance touring on this. Touring at 55 or 60mph would make traveling across Kansas even more mind numbing if that is possible.
Your results are very predictable... You RUIN this bike by lowering the gearing, and putting a loud muffler on it. I mean Duhhhhh, you do everything in the world to increase its noise and vibration, and then complain about it on a long ride. AND Lowered your top speed in the process REAL SMART
The CRF250L is perfect with stock gearing, at 60 MPH the vibration is barely perceptible vibration and the bike is so quiet you have to concentrate to hear the muffler noise... I ride CRF250L for 8 hours straight with no problem at all, and I am not some super tough young guy... I have tried riding my CRF250L at 65 and 70 in 5 th gear, which is about same as the doing the sprocket change, and it SUCKS. Vibration increases a lot, as does noise... Honda definitely got it right when they gave this bike 6 speeds. Changing to a 13 Tooth front sprocket is like eliminating the 6th gear, the one I use most.
MONKEY SEE - MONKEY DO: People started putting smaller sprockets on this bike thinking it was a good idea, and once it started, others like you copy it without every trying it stock, or even knowing the consequences of what they are doing...
Mike
JettPilot is offline   Reply With Quote
Old 12-12-2014, 05:30 AM   #1705
markk53
jack of all trades...
markk53's Avatar
Oddometer: 9,237
Mike
I saw something like this you must have cross posted in another thread. but it still deserves a reply.
That is YOU, not others. It is perfect for YOU, not everyone else. Of course we have no idea where you are to remotely equate where this gearing is perfect. If you rode more serious trails in the foothills and mountains of the Appalachian or get into some tight single track trails in the sand in Michigan and places like that you'd understand. Some feel it is more important to be able to run those trails without frying a clutch than to have smooth cruising at 60-65. I'd rather make it out of the woods in which I rode, gladly trading off a bit of the top speed and smoothness to do so if that was my goal.
It may be monkey see - monkey do for some, but for others, myself included with my KLX250, we either rode and found stock was geared too high or, by experience, could tell the instant we rode it, as I did, that it was geared too high for serious off roading.
I had my 250 geared down from a 14/45 to a 13/47 and found it was no big deal to run 55-60 and I'm betting the CRF is about the same. I guarantee you that the 14/45 would have had me slipping the clutch way too much on that same trip since it was riding some Michigan trails and the roads between. Seems the single track trails had 8-10" deep sand and wound through the woods so tight that it made second gear hard to use even geared as low as I was.
So as you see, if the rider has an idea of where they may ride or the kind of riding they may do... monkey see monkey do, monkey doesn't bog down, get stuck, and burn up clutch.
By the way, the beauty of the chain is the ability to swap out sprockets rather quickly. I am running a 15/39 on my 250 and can cruise fairly well at 70-75 mph unless pushing a serious head wind. It's too high gearing, but they were laying around so I figured what the heck! I won't be off road again until spring and this area in west central Ohio is flat and paved everywhere.
Ever get lost? You know, that good kind of lost - come to a dirt road intersection and you have no idea where you are or which way to turn? I like when that happens!
Mark - klx678
95 KLX650C w/Vulcan piston bigbore, Now an 09 KLX250S, selling my 90 Zephyr 550
markk53 screwed with this post 12-12-2014 at 05:36 AM
markk53 is offline   Reply With Quote
Old 12-12-2014, 05:52 AM   #1706
lmavin
Oddometer: 16
Jettpilot,
i have over 10k kilometers on my bike but only 100 or so of those are over 100 kph (60 mph).
So honda gave it 6 gears, but for me and others who ride like me 6th is never used with stock gearing.
lmavin is offline   Reply With Quote
Old 01-15-2015, 02:22 AM   #1707
michaelkozera
Oddometer: 136
http://www.advrider.com/forums/showthread.php?t=1037120
michaelkozera is offline   Reply With Quote
Old 01-15-2015, 02:46 AM   #1708
michaelkozera
Oddometer: 136
Mike
i completely agree. stock gearing is perfect.
ever since i got my 305 BB ive actually gave it a taller gearing, i went 14/38T and a larger rear tire, both of which dropped my RPM by about 6-800rpm @110km/hr. not only do i burn less fuel, but the bike makes less vibrations as a consequence of lower RPM.
however, i still carry a 2nd set of rims with a 44T rear for dedicated off road riding in BC. i leave my 21/18" off road rims/tires at my cabin in fairmont BC, i then ride my 21/18" rims/road tires to BC from calgary and back,(300km one way) this way ive got best of both worlds and it only take me 6min to swap out rims.
michaelkozera screwed with this post 01-15-2015 at 02:51 AM
Old 01-15-2015, 10:27 AM   #1709
markk53
markk53's Avatar
Oddometer: 9,237
Clearly both of you guys must have ridden the exact same stuff as that guy did, knowing his changing the gearing was wrong for his use...
You did, didn't you? I mean unless you rode the same trails and roads how would you know?
Mark - klx678
Times are GMT -7.   It's 11:11 AM.
