Old 11-10-2011, 10:43 AM   #1
walkingbear OP
walkingbear's Avatar
Oddometer: 3,605
need GS centerstand repair ino
Some where on this site.. some one who is making a center stand repair kit.
Please email or pm me. I need to repair a center stand hole on a R100GS that I just purchased.
TIA
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear is offline   Reply With Quote
Old 11-10-2011, 10:50 AM   #2
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,819
You can get a new one for around $30 + Postage from Motobins.
Rob Farmer is offline   Reply With Quote
Old 11-10-2011, 10:57 AM   #3
walkingbear OP
Oddometer: 3,605
center stand mounting holes are out of round
Need a kit to re-round the center stand tangs
Old 11-10-2011, 05:22 PM   #4
Toyanvil
Toyanvil's Avatar
Oddometer: 1,690
Can they be welded solid and redrilled?
2004 BMW 1150 GS-1993 BMW R100GSPD-2009 Yamaha TW200 1961 Sunbeam Alpine.
Life is like riding a bicycle, to keep your balance you must keep moving.
Some people try to turn back their odometers. Not me, I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. Hell, some of the places I’ve been there weren’t even roads!
Toyanvil is offline   Reply With Quote
Old 11-10-2011, 05:48 PM   #5
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,644
This?
crazydrummerdude is offline   Reply With Quote
Old 11-11-2011, 04:04 AM   #6
fishkens
Further...
Oddometer: 5,149
I'd like to see a good solution for this.
Step 1 is to replace the bushings bolted to the frame if they're worn (available at a BMW store).
Step 2 is to repair the oval holes in the centerstand.
RF - What are you referring to? I only see centerstands at Motobins ($190 US and nothing for a GS)?
TA - Yep, some sort of welding at the holes and the feet would help in rejuvenating worn stands.
WBB - The GS uses a different pivot in the frame and it doesn't fail like the pre-'81 frame lugs.
fishkens is offline   Reply With Quote
Old 11-11-2011, 06:04 AM   #7
walkingbear OP
Oddometer: 3,605
center stand
I purchased this on ebay
good used straight 1992 GSPD para-lever frame and clear/open Texas tile. 63.00 shipping in the USA, lower 48. the center stand lugs are tweaked a bit from putting it up on the center stand fully loaded.
Waiting to see the frame first but wirewerks has the fixit kit. It it work or this. I will take pics.
Old 11-11-2011, 06:31 AM   #8
fishkens
Further...
Oddometer: 5,149
ahhh, it's the hole on the frame that's rounded out. I misread that.
Old 11-11-2011, 08:03 AM   #9
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
I have been waiting for this situation to arise.
I am currently working on a simple fix, but need to know if your frame/tang hole will clean up at .500".
If bigger, how much?
Robert
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 11-11-2011, 12:26 PM   #10
walkingbear OP
Oddometer: 3,605
frame
I will know it a week when the frame is delivered.
I could send the frame to you .. and you can use it as a mock up.
I don't need it anytime soon.
Old 11-11-2011, 05:35 PM   #11
fishkens
Further...
Oddometer: 5,149
I'll be interested to see how the center stand lugs are tweaked. It seems to me that the only way that the holes in the frame lugs could be ovalized is if the bolts that hold the center stand bushings were loose for a good bit of time. On my GS the bolt secures the bushing which sits in an milled recess in the lug on the frame. As long as that bolt is tight the hole shouldn't be ovalized.
So maybe that's what happened (or, maybe I'm not picturing this correctly ).
p.s. It also seems that if the bolt securing the bushing was loose that the center stand would quickly wear the shoulder on the bushing and fall off. I've had that shoulder wear and allow the center stand to fall off even though the bolt was tight (the hole in the center stand is pretty ovalized).
Staying tuned.
Old 11-11-2011, 05:43 PM   #12
walkingbear OP
Oddometer: 3,605
don't know
I was just told this. I looked at my GS today and I can't figure how it could be tweaked. So, I will wait and look when it gets here.
Old 11-11-2011, 06:00 PM   #13
crazydrummerdude
Wacky Bongo Boy
Oddometer: 7,644
This thread needs pictures.
The center-stand "tangs" on my R75 frame are tweaked for sure, but I keep putting the repair off.
Old 11-11-2011, 09:31 PM   #14
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,977
only way to re-round an oval is to add metal and then take it away again, right?
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Old 11-30-2011, 05:15 PM   #15
walkingbear OP
Oddometer: 3,605
frame
Robert
Just received the frame. Taken some pics and I figure out what is the problem.
The holes are oval and the tang is bent. So, how do you fix this?
Times are GMT -7.   It's 04:05 AM.
