Old 04-04-2005, 11:10 AM   #46
txrider
txrider's Avatar
Oddometer: 370
I'd love to go with bigger lights, maybe an HID but my old 620 has the non electric start ignition SEM 130 watts.
I think it just barely runs the stock lights, and isolates the lights from the battery so they run straight off the stator/rectifier.
Even my GPS complains about low power at idle and it's connected to battery power, if you can call the tiny thing under the seat a battery.
Then again my bike will run fine without a battery so maybe I shouldn't complain.
2004 KTM 625 SXC
2004 Yamaha FZ-1
1996 KTM 620 RXC
txrider is offline   Reply With Quote
Old 04-04-2005, 05:53 PM   #47
The Misinformant OP
What road?
The Misinformant's Avatar
Oddometer: 350
I know I'm hijakin my own thread but where is the thread for modding the wiring to run both lights together on HIGH beam.
Plan to order dual HIDs soon-just trying to get a better price direct from Asia.
The Misinformant is offline   Reply With Quote
Old 04-04-2005, 07:06 PM   #48
craigincali
Just hanging around
craigincali's Avatar
Oddometer: 2,174
I am electrically ignorant. That being said, is there a light bulb that you can just put in the orignal light housing that is WAY brighter than stock??
Me
I am usually drunk when I post so dont take it personally !
2010 KTM 990
craigincali is online now   Reply With Quote
Old 04-04-2005, 07:36 PM   #49
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 04-04-2005, 10:17 PM   #50
LKN4DRT
Mended
LKN4DRT's Avatar
Oddometer: 714
Any chance of damaging the reflector with the 85w?
LKN4DRT is offline   Reply With Quote
Old 04-04-2005, 10:28 PM   #51
GODSPEED
finger lickin' good
GODSPEED's Avatar
Oddometer: 2,076
Hey Craig, check out this thread on HID's and the Superwhite bulbs.
http://www.advrider.com/forums/showthread.php?t=32038
Godspeed
I'd rather do it than watch it.
Those of you with spouse and SO's know this already, but man give them a big hug, and don't take anything foregranted. - MACK RIP
When 51% of the grasshoppers vote, the ants are screwed.
http://godspeed.smugmug.com/Motorcycles
GODSPEED is offline   Reply With Quote
Old 04-05-2005, 01:15 AM   #52
Jerome
Oddometer: 112
no, i've taken the old main beam 55w bulb out as the dipped one blew so the battery only has to start 2 hid's.
they both work all the time as long as i dont turn the engine on.
to get both to work on i ride away on dipped beam, get up speed, pull in the clutch, turn the ignition off, wait a second, turn it on again flip to main beam and wow!
daylight.
then i loose one hid when i start the engine again.
I think http://www.bajadesigns.com/ may do an hid kit for h4 bulbs.
Jerome
www.fowb.co.uk
Jerome is offline   Reply With Quote
Old 04-05-2005, 08:21 AM   #53
Velocibiker
Adventure Antagonist
Velocibiker's Avatar
Oddometer: 1,164
Not a thread, but
here's how I wired mine up so both lights are on w/hi-beam.
Currently bikeless.
Velocibiker is offline   Reply With Quote
Old 12-13-2010, 05:31 AM   #54
DUNDAS
DUNDAS's Avatar
Oddometer: 55
Both lights on without fiddling with any wires
I wanted both lights on all the time but I did not want to muck with any of the
wiring .. I suck at electrical and frankly a big wiring harness makes me nervous. I went over all these light threads and ending up doing this.
I changed the headlights to LED's
what I did was very simple basically I made the day running light as powerful as I could the small BA9S bulb I found an LED on ebay with 5 leds in it for $2.00
I then changed the other H1 bulbs to 9 leds $2.00 now I could have gone up to 25 LED's packed in one bulb but I didn't want to over power the smaller BA9S neighbor.
* I did have to take out the light assembly and open up the back of the bulbs
as the LED's where thicker in diameter to the stock .. I did this by cutting a needle file in half and putting it in a drill and slowly carved out the opening until it fit .. I then blew out all the shavings with and air compressor .
the result is both lights appear to both on and the high beam trigger and all that jazz works the same
2006 640 adventure
2009 250 xcw (woods bike)
2004 105 sx (wife's woods bike)
1974 DT 100 enduro (wife's)
DUNDAS is offline   Reply With Quote
Old 12-13-2010, 08:27 AM   #55
Seikkailu_R
Seikkailu_R's Avatar
Oddometer: 842
Two Hids work great.
Currently i have one 35w for hi/low and one 50w for flood light.
And no need to drill huge holes to original end caps...
From friends bike, 2x35w on original lights.
And basic wiring for 640a, with relays etc...
Seikkailu_R is offline   Reply With Quote
Times are GMT -7.   It's 10:06 AM.
