Old 08-21-2012, 01:24 PM   #136
craydds OP
craydds's Avatar
Oddometer: 1,160
Originally Posted by gasolinePony View Post
I'm looking at some of that surface rust in the piston bore (piston itself I've already ordered). Would you recommend wax metallic finish to remove it?
It is easy to clean the piston bore with a good scrubbing; scotchbrite, as you mentioned, with detergent should work well. A bit of phosphoric rust remover couldn't hurt, but don't leave it in contact with the surface for too long. Thorough rinsing and drying should do the trick. Any product/cleaner/etc. must be completely rinsed away so as not to interfere with the brake fluid. Good luck!
ABC #12947
'75 R90S
craydds is offline   Reply With Quote
Old 02-05-2013, 02:57 PM   #137
sigpe57
Oddometer: 340
Are there after-market dust boot and seal kit or just by from the BMW Dealer?
Where is the best place to buy?
sigpe57 is offline   Reply With Quote
Old 02-05-2013, 04:25 PM   #138
craydds OP
craydds's Avatar
Oddometer: 1,160
No aftermarket seal/dust boot kit that I know of, but several of the parts suppliers carry these items. Where are you located - have a local shop in your area? You might give Ted Porter a call, http://beemershop.com/Merchant5/merc...BS&Screen=PLST . Do you have 40 mm or 38 mm ATE's?
ABC #12947
'75 R90S
Old 02-05-2013, 05:38 PM   #139
sigpe57
Oddometer: 340
Good question, I don't know it's 38 or 40mm. How do I check?
I'm in Los Angeles. Few BMW dealers here.
Old 02-05-2013, 06:28 PM   #140
Kai Ju
Kai Ju's Avatar
Oddometer: 1,868
The number is stamped on the outside of the caliper.
Re dealers in LA, there is Long Beach BMW, Irv Seavers ( my choice since they usually have what I need in stock ), BMW of Hollywood, BMW of Ventura County, BMW of Riverside, or let google be your friend: http://tinyurl.com/ao53k85
Kai Ju is offline   Reply With Quote
Old 02-05-2013, 06:30 PM   #141
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,415
I ordered a kit from motobins:http://www.motobins.co.uk/displayfin...search=1&go=GO
and an extra piston seal: http://www.motobins.co.uk/displayfin...search=1&go=GO
The extra piston seal is for my current ATE caliper with the kit for converting to dual ATE's. Provided you have a couple (+) weeks to wait for the parts, motobins has parts difficult to find elsewhere. I can recommend doing business with them. They don't use the BMW part number system, so some of the parts needed to be hunted down, but they seem to have most all the parts for all the models.
Stan_R80/7 is offline   Reply With Quote
Old 02-06-2013, 01:11 AM   #142
chasbmw
Oddometer: 2,254
I have a feeling that the 38s are stamped with 38, but the 40s are not stamped.
If you put your engine no into realoem you will get build date for your bike. I think that 40 s were introduced from 09/75, but I'm not 100% sure. My bike is dated 06/75 and has a bit of a mixture of 75 and 76 model year parts. BMW model year starts from September, when the factory after the summer holidays starts building the bikes for the next calender years selling season, so a 10/75 build date means that you have a 76 model year bike. During the changeover period, bikes could be built with a mixture of parts as the 'old' parts are used up.
Charles
1971 Commando Fastback
Old 02-06-2013, 01:33 AM   #143
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,519
The 40's are stamped with a number 40 most of the time. The 38's do not have a number stamped. I have heard there are some 40's not stamped, maybe late production but I've never seen one.
If it is stamped the number is on the large round area visible when the caliper is mounted on the bike.
---Albert Einstein
disston is online now   Reply With Quote
Old 02-06-2013, 05:46 AM   #144
craydds OP
craydds's Avatar
Oddometer: 1,160
This is a 40 mm caliper off my '76 R90S. It is clearly stamped with 40:
This is the caliper on my '75 R90S. It is in fact a 38 mm. No stamp:
If you are going to remove the pistons anyway, just pop 'em out and measure with a caliper. Then order your parts needed. Best of luck! Let us know how it's going.
ABC #12947
'75 R90S
Old 09-15-2014, 09:08 AM   #145
NSA
Silently Listening
NSA's Avatar
Oddometer: 150
Craydds, what is it you are measuring in that last pic (with the feeler guage), and how is that adjusted? I can clearly see where my calipers have rubbed on the lower brace.
I notice your calipers have a dusting of silver paint on them. Mine did as well (just sent them into powder coat with the rest of the black parts). Do you know how they got that way, and if that's a factory thing?
Did you replace the o-rings on the caliper pivot bolt and in the fork leg? If so, did you buy from the fiche, or do you know if they are just standard o-rings? They're 11$ a piece on the fiche, so I'm looking for alternatives.
Did you sell your frame mounted master cylinder, or do you want to?
You've done some really nice work. Thanks for sharing it with us.
Everytime you think of a fence keeping all those bad people out, think about those fences- maybe- being used against us, keeping us in. - Dr. Ron Paul
NSA is offline   Reply With Quote
Old 09-16-2014, 05:02 AM   #146
_cy_
Oddometer: 6,271
NSA .. there's a local Oring supplier near highway 169 & Pine street that handles specialty materials for dirt cheap.
EPDM Orings is what you need if it contacts brake fluid. Nitrite Orings work fine for contact with oils/fuel.
scroll down to #246 for info about different materials for Orings
http://www.advrider.com/forums/showt...730033&page=17
what an excellent old ATE caliper thread!
Old 09-16-2014, 06:31 AM   #147
NSA
Silently Listening
NSA's Avatar
Oddometer: 150
Thanks, since these are just the caliper pivot bolts, and shouldn't contact brake fluid, I'm going to go by harbor freight and pick up one of their o-ring kits. I'll see if any of those fit, before I go hunting further.
Times are GMT -7.   It's 04:13 AM.
