Old 04-14-2012, 01:49 PM   #121
craydds OP
craydds's Avatar
Oddometer: 1,160
Originally Posted by Fritzie View Post
I'm working on the grease gun method. Do you guys braze a zerk onto a bleeder screw ?
Buy a grease zerk with the M10 x 1.0 threads. see http://www.mcmaster.com/#zerk-grease-fittings/=h3u0qv . These thread into the caliper. Use the bleeder valve to block one hole, screw the grease zerk into the other and pump away.
ABC #12947
'75 R90S
craydds is online now   Reply With Quote
Old 04-14-2012, 10:09 PM   #122
knary
sunshine and puppies
knary's Avatar
Oddometer: 29,432
the el cheapo grease guns I've owned screw right in after you remove the zerk fitting bit on the end.
Artist, Father, Etc | Oil & Piston
Go Jane Go - Analog Jane and her three chamber heart
Goodbye Toolfan
knary is offline   Reply With Quote
Old 04-15-2012, 08:40 AM   #123
Fritzie
Oddometer: 8
Grease Gun Options
Thanks guys, super helpful.
Fritzie is offline   Reply With Quote
Old 04-15-2012, 12:21 PM   #124
supershaft
because I can
Oddometer: 9,116
The last time I did it just recently on a RD 350 caliper I just stuck my grease needle in the loose bleeder real hard and started pumping. Sure a bit backed out around the needle but most all of the grease forced the piston out. Both ways definitely work. Good luck!
Old 04-23-2012, 06:29 PM   #125
craydds OP
craydds's Avatar
Oddometer: 1,160
master cylinder
Here is the 14 mm MC. I bought it from Max BMW, part # 32-72-2-310-747 , http://www.maxbmwmotorcycles.com/fic...ts=32722310747
I use Earl's Speed Flex size 3 hose from ANplumbing.com, http://www.anplumbing.com/Hose/Speed-Flex-43.html
I used Earl's Speed Seal fittings, http://www.anplumbing.com/Hose+Ends/...al+S.S-35.html .
One line from MC down to right caliper. The second line goes from the right caliper, over the fender to the left caliper.
brake lines
Left caliper with Earl's SOLO BLEED bleeder valve, http://www.anplumbing.com/Extras/Bre...eeders-64.html, above the Speed Seal fitting part #600493.
ABC #12947
'75 R90S
craydds screwed with this post 04-23-2012 at 07:22 PM
Old 04-23-2012, 06:36 PM   #126
supershaft
because I can
Oddometer: 9,116
That's one way of doing it. I always run a double banjo bolt on the first caliper and keep the bleeder.
Old 04-23-2012, 07:05 PM   #127
craydds OP
craydds's Avatar
Oddometer: 1,160
hose over fender to left caliper.
At the right caliper I used Earl's Speed Seal part #601193, http://www.anplumbing.com/Hose+Ends/...al+S.S-35.html
At the left caliper and the MC I used Speed Seal part #600493. These are adjustable, to keep the hose from twisting into a kink.
ABC #12947
'75 R90S
Old 04-23-2012, 07:08 PM   #128
craydds OP
craydds's Avatar
Oddometer: 1,160
I thought about that, too. Thought that might be easier to bleed. Left myself enough slack in the brake line to change it if necessary. Turns out my set-up was relatively easy to bleed.
ABC #12947
'75 R90S
Old 04-24-2012, 10:54 AM   #129
Fritzie
Oddometer: 8
Success
I soaked the stuck caliper in diesel for 3 days and compressed air brought the bad guy right out. It's toast. Calipers are rebuilt and waiting on new lines. What pads are you guys using ?
Old 04-24-2012, 11:04 AM   #130
craydds OP
craydds's Avatar
Oddometer: 1,160
One must use the M10-1.0 x 19 mm brembo banjo bolts, http://www.rscycles.com/Storefront/detail.aspx?ID=10681. The Earl's Banjo bolts (part #977517, http://www.anplumbing.com/Adapters/Banjos-26.html) are M10-1.0 x 23 mm and are too long.
Front end and brakes are ready to roll... soon, I hope.
ABC #12947
'75 R90S
Old 04-24-2012, 11:12 AM   #131
craydds OP
craydds's Avatar
Oddometer: 1,160
I am going with the EBC's from Ted Porter, http://www.beemershop.com/catalog/pr...ce47f8d670ceff.
ABC #12947
'75 R90S
craydds screwed with this post 04-24-2012 at 11:21 AM
Old 04-25-2012, 07:51 AM   #132
surtees
Oddometer: 29
Looks great Ray, very clean and simple. I used the same MC - when I first filled and bled it I saw swirls of the fluid turn dark in the MC reservoir (I had it open to check the level) - seemed like maybe there was some oil or gasket material left in there. Did you notice that? I also use the EBC pads and like them.
surtees
surtees is offline   Reply With Quote
Old 04-25-2012, 10:59 AM   #133
craydds OP
craydds's Avatar
Oddometer: 1,160
black goo
Yes! That worried me, but I kept flushing/bleeding the entire system until clear brake fluid was flowing out. I might flush the system again after a few months. Brake fluid is cheap. We have heard about rust/corrosion in the calipers and MC's on this and several other threads. Fellow inmates, flush the system at least once yearly.
ABC #12947
'75 R90S
Old 05-11-2012, 05:34 AM   #134
craydds OP
craydds's Avatar
Oddometer: 1,160
Killing time, waiting on other parts, can't finish my brakes yet. So I removed the tired old Konis. (sorry about the fuzzy picture)
Got some new YSS shocks from Tom Cutter, http://rubberchickenracinggarage.com/ .
Shocks installed.
What happened to my pictures?
ABC #12947
'75 R90S
Old 08-21-2012, 11:02 AM   #135
gasolinePony
gasolinePony's Avatar
Oddometer: 27
But, as an example, rusted caliper pistons, could have been polished, rust treatment (Ospho,etc.), then reinstalled and it could possibly work alright; as was previously noted, they could rust again. So, in this case I am going with new pistons (freakin' expensive) because as Snowbum told me (personal email), we don't want to experiment with our brakes. Keep us posted on your project. Good luck, and stay tuned.
Hi, Craydds, great info here, thanks. I'm looking at some of that surface rust in the piston bore (piston itself I've already ordered). Would you recommend wax metallic finish to remove it?
Pictured here: http://advrider.com/forums/showthrea...5953&page=2#30
Thanks for any help.
gasolinePony is offline   Reply With Quote
Times are GMT -7.   It's 06:20 PM.
