Old 11-12-2011, 02:28 PM   #1
warp9man OP
Gravel in my Travel
warp9man's Avatar
Oddometer: 591
Tired of rear brake pedal play?
Both my 950 and 990 have tons of play in the rear brake pedal and its due to the cheap steel brake bracket KTM uses for the brake pedal clevis. I couldnt stand it anymore and had our machinist make me up a prototype last week. my bikes blue so I had to match of course but we will have Black, Orange and Blue end of December for $39. it will come with a 410 stainless pin and threaded to use the stock brembo push rod.
Guranteed to make you faster Ha-Ha !!!!
warp9man screwed with this post 11-12-2011 at 03:06 PM
warp9man is offline   Reply With Quote
Old 11-12-2011, 02:46 PM   #2
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,579
2013 KTM 690R Enduro
Chuckracer is offline   Reply With Quote
Old 11-12-2011, 03:27 PM   #3
StmbtDave
AKA Invisible Dave
StmbtDave's Avatar
Location: Loveland, CO summer - Green Valley, AZ winter
Oddometer: 3,069
Looks fantastic . The collar looks pretty short. It doesn't appear to allow much adjustment for the rod length .
Dave
Why are we stopping? We don't have time for that!
StmbtDave is offline   Reply With Quote
Old 11-12-2011, 03:33 PM   #4
warp9man OP
Gravel in my Travel
warp9man's Avatar
Oddometer: 591
I agrre that it looks short but the rod is pretty long and as it is runs past the round collar and down into the threaded section below. Maybe ill add another 5mm to the collar length just because.
warp9man screwed with this post 11-12-2011 at 03:42 PM
Old 11-12-2011, 04:25 PM   #5
Wolfgang55
Wolfgang55's Avatar
Oddometer: 3,527
Nice job!
I want one but don't have the bike to put it on.
Did you once own a KLR? I have seen this kind of thinking from that bunch.
Wolfgang55 is offline   Reply With Quote
Old 11-12-2011, 04:54 PM   #6
warp9man OP
Gravel in my Travel
warp9man's Avatar
Oddometer: 591
Did you once own a KLR? I have seen this kind of thinking from that bunch.[/QUOTE]
Ok you caught me, I owned one but I was a closet KLR owner
Old 11-12-2011, 05:36 PM   #7
StmbtDave
AKA Invisible Dave
StmbtDave's Avatar
Oddometer: 3,069
Originally Posted by warp9man View Post
... my bikes blue so I had to match...
So what happened to your black beauty? We met at the Deer Crk Campground on the Burr Trail and you were riding the black one.
Dave
Old 11-12-2011, 07:50 PM   #8
warp9man OP
Gravel in my Travel
warp9man's Avatar
Oddometer: 591
[QUOTE=StmbtDave;17291512]So what happened to your black beauty?
still have it, with it now over 100,000 miles i was given the green light to get a new one by the boss, and my son has been riding the "black beauty"
the 950 is still running great and its fun to have the extra bike for my son to ride.
did you ever put the vacum pump on your 950?
Old 11-13-2011, 03:15 AM   #9
Lc8grrr
Vtwin madness
Lc8grrr's Avatar
Oddometer: 444
Same thing annoyed me a few years ago on the 950 but I've pressed an Alu sleeve into the brake lever hole which allowed me to use the correct size heim/rose joint. I want the rear brake right there, no delay 'cause I'm usually going too fast Yours looks trickier though..
Lc8grrr is offline   Reply With Quote
Old 11-13-2011, 10:34 AM   #10
Unkgd
Oddometer: 348
+1
The shoulder being 1/4 inch longer would be a plus - more adjustability (upwards at least). Let us know when you are going into production on these.
Bill
Unkgd is online now   Reply With Quote
Old 11-13-2011, 10:52 AM   #11
Unkgd
Oddometer: 348
+1
Bill
Old 11-15-2011, 05:36 PM   #12
Weldit
Weldit's Avatar
Oddometer: 336
am I missing something here ?
went out and looked at my 990 to see what the original part looked like
no play in pin at all - but there is a bit of free travel before the rod pushes master cyl
this is easily adjusted with rod length adjuster or pedal height limiter "offset round thing"
are your bikes that high mileage that the pin is worn out
or was the 2011 model 990 different ?
'11 Dakar 990
Weldit is offline   Reply With Quote
Old 11-15-2011, 05:40 PM   #13
Johnf3
Oddometer: 1,067
The free play is essential to the proper operation of the brake, unless you want your rear brake to lock up solid.
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Johnf3 is offline   Reply With Quote
Old 11-15-2011, 06:42 PM   #14
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,579
...are your bikes that high mileage that the pin is worn out...
Yep.
Old 11-15-2011, 11:18 PM   #15
Masa
Masa's Avatar
Oddometer: 303
I've a new 990 '11 and the hole is oval-shaped. There's about a 1mm play which gives that 3-5mm free travel for the pedal. Push rod's rubber sleeve keeps it against the master cylinder at all times.
Masa screwed with this post 11-15-2011 at 11:25 PM
Masa is offline   Reply With Quote
Times are GMT -7.   It's 10:00 AM.
