Old 11-16-2011, 05:10 PM   #16
Weldit
Weldit's Avatar
Oddometer: 336
Originally Posted by Masa View Post
I've a new 990 '11 and the hole is oval-shaped. There's about a 1mm play which gives that 3-5mm free travel for the pedal. Push rod's rubber sleeve keeps it against the master cylinder at all times.
my pin has NO movement at all - but the pedal has some free play - which i agree is a must so rear brake will release
if your pin is worn on a '11 990 already ? or just poor manufacturing tolerence ?
weird to say the least ?
'11 Dakar 990
Weldit is offline   Reply With Quote
Old 11-17-2011, 12:14 AM   #17
Masa
Masa's Avatar
Oddometer: 300
I sure hope it's not worn, because the bike has under 2000km on it. I'd think the hole has been made oval-shaped.
Masa is offline   Reply With Quote
Old 11-17-2011, 05:27 PM   #18
Weldit
Weldit's Avatar
Oddometer: 336
when I move the pedal with my foot or hand there is no play
BUT if I take the clevis and pull it up with my hand it will move up some - probably the 1mm you have
the clevis stays down tight to the pedal - no free play when pushing pedal
still this is a NON ISSUE - if you want to "Bling" your bike - ok - fine
'11 Dakar 990
Old 01-08-2014, 06:35 PM   #19
guns&coffee
Gnarly!
guns&coffee's Avatar
Oddometer: 1,235
Availability
Do you still have some of these? Need 1.
"Over the Mountains Of the Moon,
Down the Valley of the Shadow, Ride, boldly ride,"
The shade replied- "If you seek for Eldorado!" E.A.P. 1849
04 KTM 950ADV ~ "BEASTIE", '13 KTM 300XCW, '75 Husky 360WR/CR,
guns&coffee is offline   Reply With Quote
Old 01-08-2014, 09:22 PM   #20
Dustodust
Dustodust's Avatar
Oddometer: 889
I noticed I get an un-acceptable amount of rear brake play when the rotor is wore out ,
when the pads wear out it is quite a lot
replaced the rotor and no problem now
from a cloud of dust we race, then into the dust we return, across the finish line
04 KTM 950 S
04 KTM 525 EXC street plated
Old 01-09-2014, 04:15 AM   #21
guns&coffee
Gnarly!
Oddometer: 1,235
This is play before the I engage the master cyl. Bike is an 04
Times are GMT -7.   It's 07:47 PM.
