Old 11-13-2011, 11:31 AM   #1
Hodakaguy OP
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 1,681
Suzuki DRZ400/IMS Tanker Brace
The DRZ400 Tanker Brace is designed to work with the IMS tank and offer a solid mounting point for the tank while adding radiator protection in the process.
While preparing for a desert trip my friend ordered the IMS tank for his DRZ400 and found the fit to be less than perfect. The right side of the tank would line up with the mounting holes in the radiator but the left side was quite a ways off. Something needed to be done.....
I made up the DRZ Tanker Brace to make a solid mounting point for the tank. Once installed the Tanker Brace also adds significant radiator protection as the tank wings are no longer connected to the radiators. With the stock IMS rubber stand off mounts the impact of a crash on the "wings" of the tank will transfer energy directly into the radiators, the Tanker Brace connects both sides of the tank together and ties them into the front engine mount bolt. It leaves a buffer gap between the radiator and the wings of the tank, even if you crash hard enough to bend the Tanker Brace it will keep the energy of the crash away from the radiators!
I've made a similar brace for the XR650R for a couple years now, you can check them out here: CLICK HERE
The Tanker Brace is fully Tig Welded and comes painted in a satin textured black finish.
I will be offering the braces at a cost of $55 + $10 shipping in the cont USA.
Here's a few pictures of the Tanker Brace mounted on the DRZ
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy screwed with this post 11-30-2011 at 08:18 AM
Hodakaguy is offline   Reply With Quote
Old 11-13-2011, 02:30 PM   #2
Relaytech
Oddometer: 5
This is a great product! As you can see from the pic with the scuff marks on the tank, I have already tested the worthiness of the brace, as it did protect my radiators from any damage when I fell over crossing a log bridge on the OBDR trip. Much better than the tank being attached to the radiators!
Relaytech is offline   Reply With Quote
Old 11-13-2011, 02:36 PM   #3
oregoncoast
Racing Like a Noob
oregoncoast's Avatar
Oddometer: 4,281
Great idea!
Old 11-13-2011, 09:21 PM   #4
stuckinmud
all the time.
stuckinmud's Avatar
Oddometer: 313
Quality bracket
StuckInMud
stuckinmud is offline   Reply With Quote
Old 11-13-2011, 09:55 PM   #5
STANIMAL
SUPPORT THE SECOND
STANIMAL's Avatar
Oddometer: 1,684
Will this work on a Clarke tank ?
If it don't have tits, spark plugs or gun powder, it don't interest me. ---Moose Dog
If you don't organize your tools, you're a terrible person.---Aghartha
You twatwaffles who enjoy fucking duffelbags full of deer antlers, simply stay out of the thread. ---Hardware02
STANIMAL is offline   Reply With Quote
Old 11-14-2011, 03:13 PM   #6
BCJC
BCJC's Avatar
Oddometer: 37
weight?
BCJC is offline   Reply With Quote
Old 11-14-2011, 09:05 PM   #7
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 1,681
I'm not sure on that one, my Honda XRR brace works with all the diferent tanks but was designed for the Acerbis Sahara tank. If the Clarke tank has the mounting holes in the same spot (most likely if it bolts to the radiators) then it should work. On the IMS tank the left mounting hole is off a bit so the brace is designed to accomodate for that, it's slight though. You can give it a try and send it back to me if it doesn't work.
Hodakaguy
Old 11-14-2011, 09:06 PM   #8
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 1,681
Originally Posted by BCJC View Post
weight?
12oz, a compromise between weight and strength.
Hodakaguy
Old 12-19-2012, 07:19 AM   #9
Gian
dreamer
Gian's Avatar
Oddometer: 646
well done! I had some problems in the past too, so it would be interesting. I think I'm seeing some radiator protecion in your photos, if so can I ask you which model they are or anyway which kind of protection I could combine with your brace?
also, please how much would be the shipping to Italy
Many thanks
Gian is offline   Reply With Quote
Old 04-15-2013, 04:54 PM   #10
rube
Oddometer: 66
Unibikers and Tanker brace?
Any idea if the Tanker brace makes it easier to fit an IMS tank to a DRZ with Unibiker radiator guards?
rube
rube is offline   Reply With Quote
Times are GMT -7.   It's 11:13 AM.
