Old 11-17-2011, 09:30 PM   #1
backdrifter OP
Wannabe rider
backdrifter's Avatar
Oddometer: 1,364
Any tricks for getting steering stem bearing races out of an airhead?
As the title says - I'm having trouble. The Clymer says to use a punch from the other end and gently tap it out. Problem is, the stem is curved and the races are recessed in a way such that you could never reach them with a straight tool.
Compounding the issue is the fact that I didn't remove them before going to the powdercoater and now I have some overspray that is helping to hold them in.
Any suggestions would be greatly appreciated!
"We are very good at preparing to live, but not very good at living."
-Thich Nhat Hanh
1973 BMW R60/5:
http://www.advrider.com/forums/showthread.php?t=608166
backdrifter screwed with this post 11-17-2011 at 09:42 PM
backdrifter is offline   Reply With Quote
Old 11-17-2011, 09:41 PM   #2
ontic
Oddometer: 1,070
welding a bead around the center of the race is the trick I've heard, once the bead cools the race shrinks a little and it is an easy out- however it would definitely be preferable to do this before a powdercoat I rekon.
Someone was just telling me about a good tool for this job, I'll shoot them a pm to find out what it was.
I haven't done this myself yet, but from the sound of it I would probably just try to make a good bent punch/drift to get it done.
1974 R90/6
1981 R80G/S
1994 XLR250R
ontic is offline   Reply With Quote
Old 11-17-2011, 09:53 PM   #3
elite-less
As above, so below
elite-less's Avatar
Oddometer: 548
Easy... get this tool from CycleWorks.
IMG_3966
Slash 5 Revive
elite-less is offline   Reply With Quote
Old 11-17-2011, 09:56 PM   #4
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,329
The welded bead works well. And it still doesn't move, gives you something to hammer on.
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is offline   Reply With Quote
Old 11-17-2011, 10:22 PM   #5
ontic
Oddometer: 1,070
Eek
Well if that is all it is doing then I'd just weld a chunk of metal in the middle of the race and really give myself something to hammer on.
1974 R90/6
1981 R80G/S
1994 XLR250R
Old 11-17-2011, 10:28 PM   #6
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,329
Nah, it shrinks the bearing & most times it just drops out. But I was thinking this one might be glued in with powder coat
Old 11-18-2011, 05:07 AM   #7
SUVslayer
SUVslayer's Avatar
Oddometer: 835
When I did them on my GS, I ended up taking a dremel to the races and (carefully) cutting them out.
SUVslayer is offline   Reply With Quote
Old 11-18-2011, 05:46 AM   #8
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,552
Get an old large flathead screwdriver and bent the tip over about 30-45 degrees and then you can hammer it out from the other side no problem. The cycleworks tool does work nicely also.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 11-18-2011, 05:56 AM   #9
backdrifter OP
Wannabe rider
Oddometer: 1,364
Thanks for all the responses. Unfortunately, I don't have a welder, but I could get my hands on one if that's the best way to go.
I did try cutting the top race out. I actually cut a section about 1/2" out, hammered on it forever (from the top) with a punch and finally got it to come flying out. The rest of the race is still absolutely glued in there.
I can try a bent punch or screwdriver from below, but there is barely a lip at all at the bottom of the race, so whatever I use will need to be a sharp tool.
The Cycleworks tool looks nice indeed, but I'm hoping to have these out before one of those could arrive at my doorstep!
-Thich Nhat Hanh
1973 BMW R60/5:
Old 11-18-2011, 10:24 AM   #10
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,792
This is the way I did this job years ago. Go to hardware store and buy a cheap screwdriver for this. It will be trash when you finish and gets thrown away. Use the old bearing race as a tool to set the new bearing into the frame head, it is recessed. I think some pull the bearing in with action of the slotted nut on the triple clamp. I don't like to do that but it might be OK.
disston is online now   Reply With Quote
Old 11-18-2011, 10:50 AM   #11
backdrifter OP
Wannabe rider
Oddometer: 1,364
Thanks guys. I went out and took another look. The lip on the underside (if coming from the other end of the stem) of the race was tiny. I didn't think I would be able to make a tool sharp enough to get in there.
So, I made a few passes with a cutting wheel on a dremel, and then sharpened a crappy flat head screw driver and used a hammer to wedge it in between the race and the steering stem from the top and pop the pieces out. It was a pain, but it worked.
On to the next problem!
-Thich Nhat Hanh
1973 BMW R60/5:
backdrifter screwed with this post 11-18-2011 at 12:33 PM
Old 11-18-2011, 12:24 PM   #12
simonboxeproject
Oddometer: 84
welded
Hi If it is of help, I went the weld way.
I cut off a short length of 1/2" x 1/8" mild steel, long enough to sit across the race but not fall through then gave it a spot with my MIG on either end, then with a long drift knocked it out. once out did the same for the other end bearing.
Worked well came out easy.
simonboxeproject is offline   Reply With Quote
Old 11-19-2011, 03:27 AM   #13
Martian
Oddometer: 1,104
I used what is called a "cat's paw". Its normally used for pulling nails, but fit into the bearing and hooked the back edge quite nicely. I was able to pry out the race after using a heat gun to warm the stem.
Tom
'93 R100R
'02 F650GS sold)
'93 R100GSPD(sold)
http://frommars.smugmug.com
Martian is offline   Reply With Quote
Old 11-19-2011, 04:32 AM   #14
bikerfish
flyfishandride
Oddometer: 1,640
put the new races in the freezer before installing.
bikerfish is offline   Reply With Quote
Old 11-19-2011, 04:42 AM   #15
brittrunyon
R 100 GS F 650 GS
brittrunyon's Avatar
Oddometer: 523
What's the next problem?...................The bearings?
1992 R 100 GS (ZED)
2007 F 650 GS
My Motorcycle Videos & More @ http://vimeo.com/user2721333
Big Bend Ride Report @ http://brittrunyon.com/
brittrunyon is offline   Reply With Quote
Times are GMT -7.   It's 09:08 AM.
