Old 11-19-2011, 06:45 AM   #16
backdrifter OP
Wannabe rider
backdrifter's Avatar
Oddometer: 1,363
Originally Posted by jorunny View Post
What's the next problem?...................The bearings?
Don't know yet - but I do know there WILL be another problem!
"We are very good at preparing to live, but not very good at living."
-Thich Nhat Hanh
1973 BMW R60/5:
http://www.advrider.com/forums/showthread.php?t=608166
backdrifter is offline   Reply With Quote
Old 11-19-2011, 07:42 AM   #17
brittrunyon
R 100 GS F 650 GS
brittrunyon's Avatar
Oddometer: 488
Not to Hijack - I'm replacing bearings as well
I've got the front end apart, have the new bearings in hand but the Cycle Works tools are in the mail somewhere..............
I noticed that the lock slot had a big bur on it and quickly filed it down............
Photobucket
I guess without the Cycle Works tools the best way to get this bearing off is with a dremel.............or is it just suppose to drop off?
Photobucket
Just joining this thread to support my fellow armchair motorcycle mechanics working on their front ends & maybe learn some new tricks as well.......
Good Luck on todays project!
1992 R 100 GS (ZED)
2007 F 650 GS
My Motorcycle Videos & More @ http://vimeo.com/user2721333
Big Bend Ride Report @ http://brittrunyon.com/
brittrunyon is offline   Reply With Quote
Old 11-19-2011, 08:02 AM   #18
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,462
Photobucket
I can't remember for sure and I don't have my GS front end handy to look at, but aren't there two holes from the top down to the back of the race to hammer it out from the topside with a drift?
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler screwed with this post 11-19-2011 at 08:13 AM
Old 11-19-2011, 08:04 AM   #19
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,160
Originally Posted by Martian View Post
I used what is called a "cat's paw". Its normally used for pulling nails, but fit into the bearing and hooked the back edge quite nicely. I was able to pry out the race after using a heat gun to warm the stem.
It looks like your cat's paw may be big enough but if using any arrangement like this and it is too small it can dammage the bearing seat area. I did this with a lady slipper pry bar. I thought it was big enough. I ended up having to dress the bearing seat area. Damage was not too bad. I just ground down the nicked area a little. Plenty of fresh material was not touched.
An ordinary slap hammer with a three arm puller works too. Have to sharper the puller teeth maybe.
Old 11-19-2011, 08:49 AM   #20
Martian
Oddometer: 1,105
That's how mine was. There are also holes in the lower triple to knock the lower bearing off the stem, too.
Tom
'93 R100R
'02 F650GS sold)
'93 R100GSPD(sold)
http://frommars.smugmug.com
Martian is offline   Reply With Quote
Old 11-19-2011, 09:12 AM   #21
brittrunyon
R 100 GS F 650 GS
Oddometer: 488
Your right...holes on the adjusting knob
Photobucket
No holes on the lower............those holes don't go thru............
Photobucket
But there is a slot on each side, under what is left of the old bearing..............................
Photobucket
Going at it!
1992 R 100 GS (ZED)
2007 F 650 GS
Old 11-19-2011, 09:18 AM   #22
SOLO LOBO
airhead or nothing
SOLO LOBO's Avatar
Oddometer: 8,715
You simply need to take the triple to a press and press the stem out of the lower clamp.
I have also successfully heated the triple and driven the stem out of the lower triple with a BFH, but I don't suggest this method as it is a serious PITA and you can really screw up the stem and other bits.
"punkrocks what it's all about" - J. Strummer
SOLO LOBO is offline   Reply With Quote
Old 11-19-2011, 09:36 AM   #23
P B G
Oddometer: 10,001
Just get a bearing separator, think you can buy one from harbor freight or rent from autozone.
Old 11-19-2011, 09:58 AM   #24
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,502
Going at it!
I use an grinder (wall mounted) to grind almost through the bearing, let it cool and then give it a tap with a hammer, you can then use the the two slts as lever points.
Rob Farmer is offline   Reply With Quote
Old 11-19-2011, 11:40 AM   #25
Airhead Wrangler
Adios Mexico
Oddometer: 6,462
Or just make two deep slits on the race 180 degrees apart hit the slits with a chisel. It'll often crack the race in two halves that'll just fall off.
Old 11-19-2011, 01:52 PM   #26
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,535
Yes, that works really good.
And my weird tool to push the inner races out of the steering head.....no laughing it has worked before. May be needed again soon or....make an "improved" version, I have "a few" more old wrenches.
Have tools, will travel!
Old 11-19-2011, 02:05 PM   #27
Rapid_Roy
finally understands
Rapid_Roy's Avatar
Oddometer: 25,562
I used the "drill holes then knock them out with a punch" method on the upper, and that sucked. The one on the stem, I always had pressed off. I drilled holes once I had the race out on another bike, but the tool works very nice the last time I did it. I will probably stick with that, it just costs me a six pack to borrow it.
What?!
Rapid_Roy is offline   Reply With Quote
Old 11-19-2011, 04:32 PM   #28
kbasa
Colnago!
kbasa's Avatar
Oddometer: 67,711
Originally Posted by elite-less View Post
Easy... get this tool from CycleWorks.
IMG_3966
+1
It's magic. Same thing for swing arm bearings.
IMHO.
Fuck Cancer. Ride bikes. - dave + tina
kbasa is offline   Reply With Quote
Old 11-19-2011, 07:31 PM   #29
brittrunyon
R 100 GS F 650 GS
Oddometer: 488
Originally Posted by kbasa View Post
+1
I believe in MAGIC................................
1992 R 100 GS (ZED)
2007 F 650 GS
Old 11-19-2011, 07:59 PM   #30
Hurricane Bob
formerly: Bomber1965
Hurricane Bob's Avatar
Oddometer: 2,854
grind then whack.
it's like cutting glass, you score a line and create a failure point in the material
Hurricane Bob is offline   Reply With Quote
Times are GMT -7.   It's 09:56 PM.
