Old 04-26-2012, 03:41 PM   #61
Aquatic OP
Aquatic's Avatar
Oddometer: 1,619
Originally Posted by dc1 View Post
hi
Im looking to buy a dakar650,
Could you advise what to look for before purchasing,
How to check bike mechanics, etc.....
What changes did you make to the bike if any
Mange to get any biltong in Aussie
Much appreciated
To find out what to look for - http://advrider.com/forums/showthread.php?t=441434
It's a very long read, but you won't be sorry.
Sign up to Wild Dogs and look here - http://www.wilddog.za.net/forum/index.php?board=92.0
And lastly - http://f650.com/forum/forum.php
What changes did I make? That is an on going thing as with many Dakakr owners.
The only major change on my bike at the moment is the Yamaha fork replacement(I bought the bike like this)
Nah mate, no decent biltong here. You have to go looking for it at the Expat shops. There is a South African butcher in Brisbane that makes decent biltong.
Aquatic is online now   Reply With Quote
Old 05-16-2012, 09:27 PM   #62
Joe Soap
Oddometer: 3
2007 F650GS Dakar Break Down and Rebuild Bent Frame
Hi Mate
Immigrated to Australia "Sydney" 4 years back from South Africa, I have just discovered that the frame on my F650GS Dakar 2007 is bent after I dropped the bike.
After discussing the matter with my other half, I decided to break down replace the frame and rebuild the machine.
If you have any advice on the matter, I would greatly appreciated it.
Cheer's
Joe Soap is offline   Reply With Quote
Old 05-17-2012, 05:04 AM   #63
Aquatic OP
Aquatic's Avatar
Oddometer: 1,619
Originally Posted by Joe Soap View Post
Hi Mate
Cheer's
All depends on what your overall plan is, available time and budget! Do yourself a favour and actually write up a plan of what you want to do. Work out a priority list and start there.
Lack of funds is why my project is at a standstill at the moment. But I also have a lot I have planned to get done. A lot I can do, but there is still stuff I need to pay to get done.
I also found out the Mrs is "up the duff" so I will most probably have to trim my list down to get it done before the end of the year when all hell is gonna break loose and all spare funds will be allocated to nappies and formula!
How old is your motor? Even though they are bullet proof, check waterpump, clutch and valve clearances.
Look at a fork conversion - this depends on your riding style and needs. But you won't be sorry.
Rear suspension will need an upgrade if you do the front (my opinion)
I'm replacing ALL the bearings and seals on the bike(excluding the engine. That is planned for later)
Especially on the swingarm.
I'm modifying the oil lines and possibly adding a cooler.
Battery upgrade.
Some people swap out the dash. That isn't in my plans.
If you ride at night, the lighting needs work.
If you have any questions, just ask. But be aware, I have no experience and I'm winging it. I do happen to be handy with tools growing up in my dad's garage and being a fitter and turner.
A copy of the workshop manual will also serve you well!
Good luck and post pictures
Old 05-19-2012, 09:59 AM   #64
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 4,005
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 05-20-2012, 03:10 AM   #65
Aquatic OP
Aquatic's Avatar
Oddometer: 1,619
Ta.
Even though it is riding time and budget gone, it is good news
Old 05-20-2012, 06:33 PM   #66
Joe Soap
Oddometer: 3
Aquatic, thanks for your input and advice on the matter mate, the last time a broke down and rebuild a bike was in the 80’s when I did my 84’ TT 600 Yamaha, which does not come close to the 2007 Dakar.
Spent a few hours in the garage over the weekend breaking down the bike taken quite a bit off, basically down to the abs, engine and wiring harness.
Quite a few smaller items require replacing and the rear shock which is shot. I will upgrade the front forks at a later stage as they are easy item to work on and get to. At this point in time concentrating on the frame, engine, upgrading the rear shock and small items that require immediate attention. I replace all the bearing and seals in the swing arm May last year.
All I know the bike needs a good spit and polish and lots of elbow grease.
Cheer’s
Old 08-12-2012, 03:32 AM   #67
Aquatic OP
Aquatic's Avatar
Oddometer: 1,619
Swingarm Bearings
So I finally managed to spend time on my bike. Hopefully this carries on for the foreseeable future
I have read a lot about what needs to be done to keep the swingarm bearings in good condition. Regular strip and regrease. Especially after some water crossings.
So I decided to try something.
I got extra 4 seals used on the shock linkage - pn 33 53 7 650 097 - Seal G22X28X4
So I stripped out the felt washers and the inner bush
Using the studs, special washers and studs I made up previously I shifted the bearings inwards another 4mm
I inserted the new seals. And with the bearings shifted inwards there is still space for the felt washers
So in theory, I have a water tight seal and dust protection with the felt washers. The cavity is also FULL of grease.
All assembled
And sealed ready for assembly in the future
Aquatic screwed with this post 08-12-2012 at 03:51 AM
Old 08-12-2012, 03:43 AM   #68
Aquatic OP
Aquatic's Avatar
Oddometer: 1,619
Another problem I noticed when I stripped out all the bearings from the wheel hubs. My sprocket carrier has been attacked by a rabid Bull Mastiff!
Some one before me didn't have tools or an idea!
I get the impression the bike was ridden with a collapsed bearing and the chain has also climbed off the sprocket
Old 11-15-2012, 10:00 PM   #69
Spyker
Oddometer: 186
Any update? Is it running yet?
PS. Hou op rond tos en bou die ding!
Originally Posted by scottie boy
If you calculated the money spent versus time actually used, vaginas cost more per hour than the space shuttle.
Spyker is offline   Reply With Quote
Old 11-19-2012, 05:24 AM   #70
Aquatic OP
Aquatic's Avatar
Oddometer: 1,619
No, not running yet
But.........I been doing a little work here and there
Then,
and Now,
Hubs - Black powder coat
Spokes - Blood, sweat and Autosol (fuck me that was hard work)
Nipples - unfortunately new are beyond budget. So I just sprayed them with Galv spray. Not what I wanted, but hey!
Hoops - powder coated the inner face and left the edges masked. Afterwards polished the edge to (almost) mirror finish.
Back wheel next and then I will send them for professional trueing.
Old 11-19-2012, 05:49 AM   #71
Gravel Seeker
Thomas
Oddometer: 4,005
Nice !
Gravel Seekers.com
Hey !
Old 11-19-2012, 08:12 AM   #72
kubiak
Oddometer: 4,829
nice work!
Old 11-19-2012, 08:15 AM   #73
LoJack
LoJack's Avatar
Oddometer: 1,604
Great idea to mask the edges of the rims. The powder coat would just get messed up from spooning the tires on and off.
Looks great!
LoJack is offline   Reply With Quote
Old 11-19-2012, 06:41 PM   #74
FabOneUp
FabOneUp's Avatar
Oddometer: 137
FabOneUp is offline   Reply With Quote
Old 12-30-2012, 06:37 PM   #75
nomad5326
Xventurous
nomad5326's Avatar
Oddometer: 302
I wish I had your talent, skill and patience! Beautiful work and looking fwd to your next piece of work!
nomad5326 is offline   Reply With Quote
Times are GMT -7.   It's 08:18 PM.
