03-23-2012, 09:46 PM
#1576 |
Oddometer: 486
Thermo-Bob
I've given quite a bit of thought to this device.
And, I've decided that it simply, for me, is a waste of money. Here's why I think so: The stock thermostat isn't a sealed "valve". There's a significant gap that allows coolant to pass through even when it's "closed". A thermostat is an analog device,not digital. It isn't "open", then "closed" (on/off or one/zero). It opens gradually, as the coolant temperature increases. The idea that your KLR's engine experiences shock cooling is probably absurd. As it gradually warms, coolant 'leaks' past the thermostat, allowing a gradual warm-up. When the engine finally reaches its upper operating temp, the thermostat very gradually opens, allowing coolant to pass through the water jacket, slowly cooling the cylinder. Is the T-Bob an improvement over the stock t-stat? Very likely. Is it a required piece of hardware? Probably not. Want one? Hell's Bells; buy it. Please don't tell me that I'm a damned fool for not installing one, though! Jon
Hey - if it ain't an adventure, it's just a ride! '04 KLR 650 '05 DRZ 400E Titled/Plated Jon B. screwed with this post 03-23-2012 at 09:47 PM Reason: Typo |
03-24-2012, 05:39 AM
#1577 |
TOP TEN KLR650 EASY CHEAPOS
1)Clear machinists face shield replacement lens for pre08 windshield 2)Drain front forks. Measure what you took out and replace with ATF 3)Rear shock--just change the spring 4)Grease rear shafts--just knock em out and leave what you knock em out with in place so realignment doesn't become an issue. Waterproof grease is cheap at auto parts stores. 5)HID headlights--Mine cost 25 dollars on ebay; 22 of that was shipping 6)Subframe bolts--hardened bolts are avail at some hardware stores for less than 5 bucks. I don't care if they are Chinese as long as they are the right grade. 7)Blown engine? Don't try and rebuild it. Get a very low mile US military engine for less than 1000 including shipping. 8)Open up airbox, drill slide, rejet, cut out and change end cap on stock exhaust to bigger outlet. If you don't drill slide, you don't even have to take carb off. 9)Doohickey...I drilled hole in old upgraded doohickey that was in an engine that blew and used again with torsion spring 10)Restuff your stock seat with memory foam. Easy with 4 hands Larger front brake kit if you are riding on street most. Skid plate if you are riding on dirt most. |
03-24-2012, 05:42 AM
#1578 |
whoops left out carb air screw drill out cap and adj to 2 turns out
03-24-2012, 06:46 AM
#1579 | |
Oddometer: 3,814
"Deeply flawed people make deeply flawed decisions." |
03-24-2012, 11:00 AM
#1580 |
Pilot2Wheels
Oddometer: 22
I ride on street roads for about 20 miles, before hitting dirt roads in the Ocala National forest in Florida. Since it has a lot of places with sugar sand, do I keep the tires at the 21psi front and 28psi rear? I have to ride back home on the pavement without a way to inflate them back up.
New to this, and this may be one of those questions that's more opinion than fact, but figure if you don't ask, you'll never know. Maybe that's a good thing. ![]() Wayne
Don't let cheapness cloud your decision making |
03-24-2012, 12:03 PM
#1581 | |
Oddometer: 269
yes if you air down your tires you will have a easier time on the sugar sand....not easy...easier. for 9 american dollars you can buy a little slime air compressor at walmart with a built in gauge to air your tires back up when you are done pounding sand into your various openings. you just need to either add a cigerette lighter socket to your bike or make some other way to plug the compressor in. ive had mine for 20k rough miles and the little guy keeps on pumping.
HEY. did you see something fall off my bike? I mean other than me. "They see me coming on my KLR......They hide their daughters and their PBR...... I'll take the beer,no time for girls......Got a date in the Forest, chasing squirrels. " |
03-24-2012, 01:50 PM
#1582 |
Oddometer: 834
03-24-2012, 02:13 PM
#1583 | ||
Ride hard.
Oddometer: 2,262
Also not advisable, but I would ride on the road to the nearest gas station with the aired down tires. Get the slime pump. Much better option. |
03-24-2012, 02:15 PM
#1584 | |
Ride hard.
Oddometer: 2,262
I have yet to try them off road, but I am sure hard pack will be fine. Although many people I know run the 244's (or the Kenda version) and love those too. That would probably be what I buy if I ever get back to more off road stuff. Thanantos screwed with this post 03-24-2012 at 03:04 PM |
03-24-2012, 02:53 PM
#1585 |
Oddometer: 177
Do y'alls 705 rears run really hot? I have one in the garage I pulled off for something more aggressive and it always got very hot to the touch.
03-24-2012, 03:44 PM
#1586 | |
mach schnell
Oddometer: 1,434
I have a few questions regarding #8 but I need to get my ducks in a row first. Stand by.
****** Mess with me and you mess with the whole trailer park. |
03-24-2012, 03:58 PM
#1587 |
Oddometer: 834
That's why I'm considering them. I like riding off road, but around here it's pretty hard to find dirt roads that aren't on private property.
![]() I like the 244's a lot and have run for them for a couple of years with zero problems.. Thing is, I'm not getting anywhere near 10,000 miles out of them, and with, as I mention, so little dirt opportunities, I figure they're worth a try. |
03-24-2012, 06:28 PM
#1588 |
Oddometer: 429
Iam running a set of 705s on my 08, the tires have vauge feeling to me. On the street they are OK but like a few guys have said after a long blast on the freeway they are HOT to the touch. I dont like them at all in the dirt and or gravel really squirrely and they just dont seem to want to hook up. (running 34 rear 32 front)It may be a problem with the shocks and forks not working with them, but when I bought this bike it had MEFOs on it and was great on the pavement and in the dirt. The price of the MEFOs was pretty high so I tried these I dont think I will try them again, I am thinking maybe a 606 on the rear and a MT21 for the front. I know that they will probabally get about half the life but I really do about 50/50 in my travles.I have about 3200 miles on these and they dont show much wear at all, I would say that they might get 8K or so very easily.
03-24-2012, 08:00 PM
#1589 |
Oddometer: 834
03-24-2012, 08:30 PM
#1590 | |
Just Me...
Oddometer: 3,597
705's are just fine on hard pack, but if you get too enthusiastic on loose stuff, you'll find yourself sliding, especially if you don't air down a bit
Txt msg with Dan right after he was paralyzed: Me: Hey Dan-O. Just wanted to say howdy and Love ya! Dan: Howdy and Love you too. Doin' good and feeling good. Me: Give 'em hell, little Bro! Dan: Roger that. East Coast Rider screwed with this post 03-24-2012 at 08:39 PM |
