Old 06-26-2012, 07:17 AM   #2836
XDragRacer
Oddometer: 3,188
Originally Posted by Danger4u2 View Post
I use the factory Kawasaki expandable tank bag with the clear map compartment. It works fine on my '07.
On my '07, also; appreciate the expandible feature of the bag (e.g., when bringing CARRY-OUT food home!).
I augmented my on-board luggage with a Kawasaki HANDLEBAR BAG; listed for '08-and-later, but fits Generation 1's just fine. Handlebar bag staps must encircle BOTH handlebar and reinforcement tube for proper fit and intended conformation.
XDragRacer is offline   Reply With Quote
Old 06-26-2012, 07:18 AM   #2837
VikB
VikB's Avatar
Oddometer: 762
Originally Posted by Velour Fog View Post
G'Day all,
Was wondering what tank bags you guys have on.
Hi Scotty - I've been using the Giant Loop Fandango tankbag for a few months and like it so far....
http://klr650blog.wordpress.com/2012...nk-bag-review/
safe riding,
Vik...
www.klr650blog.com
I didn't done the doo!
VikB is offline   Reply With Quote
Old 06-26-2012, 08:37 AM   #2838
Asatrur
Newbie KLR adv rider
Asatrur's Avatar
Oddometer: 1,250
Light switch replacement
I have a 00 that needs to have the assembly with the mirror mount, turn signal and high beam switch on it and I am wondering how do I get the grip off without ruining it, as I do not have a replacement for it and will not for a few weeks.
Thanks,
Asa
00 KLR650
04 Connie - Sold, but looking again!
I wonder what is over that dirt thingamagig?
http://share.findmespot.com/shared/f...Op8LhphYfeBJ9I
Asatrur is offline   Reply With Quote
Old 06-26-2012, 09:19 AM   #2839
Danger4u2
'04KX500isDanger4u2
Danger4u2's Avatar
Oddometer: 667
Thanks,
Asa
I don't think you need to remove the grip.
Go faster than everyone.
Only worry about what's in front of you.
Danger4u2 is offline   Reply With Quote
Old 06-26-2012, 10:00 AM   #2840
sandalscout
blah blah blah
sandalscout's Avatar
Oddometer: 2,257
I'm using the Giant Loop Diablo, the shorter brother to the Fandango, and I too love it. The Fandango is taller and has more room, so would like be better for an DSLR, and I think it would be a great fit. It's 8.5" x 12", and 5 inches tall at the lower point. My DSLR, short and long lens, a few filters, extra cards, batteries, etc, would all fit into that space, and I think I could get it all into foam easily enough.
sandalscout is offline   Reply With Quote
Old 06-26-2012, 10:02 AM   #2841
newcastleadam
Artful Tagger
newcastleadam's Avatar
Oddometer: 3,455
This. The switch housing is in two pieces, shouldn't need to remove the grip.
Adam
86 KLR250 01 KLR685 06 K1200LT
As ever, buyer and seller of all things KLR
KLR Doohickey Wrench available!
The North Florida Tag-O-Rama wants YOU!
newcastleadam is offline   Reply With Quote
Old 06-26-2012, 10:05 AM   #2842
Dusty_Bottoms
Adventurer Ordinaire
Dusty_Bottoms's Avatar
Oddometer: 821
Shoot hairspray under it and work it around.
COHVCO #7369
Dusty_Bottoms is online now   Reply With Quote
Old 06-26-2012, 10:24 AM   #2843
685
Scarred Adventurer
685's Avatar
Oddometer: 999
Originally Posted by Tsotsie View Post
I have yet to hear of an oil related issue other than low oil on the KLR. Trucks are running over 100K between changes on this stuff! There is a lot of 'expert' regurgitating of tribal myths about oil.
Ride more, worry less!
I drive a truck, and this is just plain bullshit.
And if you want to go 3500 or 6000 (what Kawasaki suggests) it's up to you. I wouldn't ever suggest to anyone that that's a good idea tho. And if you're pointing to the Kawasaki manual for guidance, I'd ask you where the 6th gear is ? Kawasaki is a big outfit, and the KLR is just a minor pimple on the corporate butt. If they make a mistake, they're slow to correct it and can always hide behind disclaimers and weasel words.
To post images. Go to http://postimage.org/ and do what they require. Copy it to clipboard (there's a box.) Paste the link (right click on the mouse, then left click 'Paste'.) Voila you got an image!
685 is offline   Reply With Quote
Old 06-26-2012, 11:14 AM   #2844
XDragRacer
Oddometer: 3,188
Respecting the fact you drive a truck (professionally, I presume), do you know of any KLR oil-related issues, other than low oil?
If the oil change interval in the manual is incorrect, as you say (either by accident or by design), what mileage should be specified between oil changes? Between oil filter changes?
XDragRacer screwed with this post 06-26-2012 at 11:30 AM
Old 06-26-2012, 02:26 PM   #2845
Danger4u2
'04KX500isDanger4u2
Danger4u2's Avatar
Oddometer: 667
Oil is cheaper than engines. I change mine @ 1500 miles. It's less than 3 quarts. I change the filter every other time. About 50/50 road /off road.
10w40 Valvoline from Wal Mart.
Old 06-26-2012, 03:02 PM   #2846
Stromius
Stromius's Avatar
Oddometer: 58
95 KLR 650 question
Looking at a 95 with 17k, Givi bags, clean, no doohickey. KBB is $1600...what's reasonable? This would be my first KLR for mostly backroads and primarily Washingtons Backcountry Discover Route (Oregon to BC).
Thanks !
I'm all
Stefan
Past: 1969 Yamaha CT1, CL125, KLR 650 Barbie
Present:
Stromius is offline   Reply With Quote
Old 06-26-2012, 03:52 PM   #2847
super21
Oddometer: 21
Packrat rack dimensions/gen 1
Could anyone give me the dimensions/width/pannier mount width/height etc? I made a vice mount bender and have some 3/4 box tubing and want to fab upa mount. Thanks
super21 is offline   Reply With Quote
Old 06-26-2012, 04:00 PM   #2848
chuggins143
chuggins143's Avatar
Oddometer: 130
Thanks !
I'm all
If it runs and doesn't have any funky sounds (knocking and such), I'd say buy it. I looked for a used one for a while and never found one under $2K If it's easy to get to, then I'd pull the cover off and take a look at the internals, but off the cuff, without seeing it. I'd say it's an acceptable price. You'll spend way more than that in farkles before you're done! Just be warned!
Chad
09 KLR 650, blue... Done the Doo!, Thermo-bobed!, LED driving lights, aux fuse box, HID high beam, gel battery, custom racks, tool tube, de-Californicated it, moved main fuses to side cover, relocated plate, PVC mod, Hurricane mod, bypassed the side stand switch...
RIP - 95 Honda VFR750 (the most vulgar shade of yellow I could find in the book!)
chuggins143 is offline   Reply With Quote
Old 06-26-2012, 04:12 PM   #2849
fleshpiston
fleshpiston's Avatar
Oddometer: 609
I can if you're looking for the "sport" model.
But if you have the tools why not do something better?
SRX600
SRX250
SR500
KLR650
fleshpiston is offline   Reply With Quote
Old 06-26-2012, 04:36 PM   #2850
super21
Oddometer: 21
pack rat touring rack gen 1
I am looking to make something close to the packrat touring rack. I may mount the cases differently and move them forward a little. I am going to use the wrap around continuous tubing to minimize welds. Thanks for the reply.
Times are GMT -7.   It's 11:03 AM.
