08-21-2012, 08:01 PM
#3661 | |
Old Pueblo Rider
Oddometer: 158
It looks like others have asked the question too? http://www.google.com/#q=site:advrid...pw.r_qf.&cad=b |
08-21-2012, 08:08 PM
#3662 |
Oddometer: 135
Doohickey tools to loan
A doohickey tool set is on its way to Geepn and no one else has spoken up. So if your doohickey needs done, give him a PM shout and get on the list. The rules are simple: use the tools, put a punch mark on the wrench (just to keep track of how many it has done), and ship them to the next person. The set consists of a homemade wrench and the rotor puller bolt in a well worn but sufficiently padded box. And if you don't know what the doohickey is or why you should, JGI! (just google it).
PS, weighing in on a couple posts: the Shinko 705s are great for the price. Previously I used AM24 Grippsters and had nothing but praise for them but I can buy front and rear 705s for about the price of the rear AM24. As for the chain guard, mine came off about 20,000 miles ago but I kept the lower white chain guide. Maybe Gen IIs are different? |
08-21-2012, 09:23 PM
#3663 |
Oddometer: 3
07 KLR 650 Kill switch replacement = No Spark!
I'm noob to this site but I feel like this may be the place to come to for some advice in this predicament.
So my girlfriend rides an 07 KLR 650 and about a month ago before we took off on a four day trip I noticed her kill switch was spilling its guts ( red switch popping out, springs visible...) I put the switch to run and and duct taped over it and told her not to touch it, key only. After the trip I found a used kill switch on ebay off an '08 KLR and thought I'd be able to make it work. Before I realized that the '08 switch was a 4 wire (07 is a five wire) I pulled the duct tape off and the original kill switch was ruined. At that point I just tried to hot wire it via some threads I read and I could not get it to start. it would turn over all day via the starter button which still worked but I could not get a spark out of it. During the hot wire ordeal I blew the main fuse a few times and kept replacing it. The main fuse is good and from what I understand gen 1 klrs don't need that part of the electrical system to fire. At this point I went to the stealership and ordered a 07 klr kill switch thinking that possibly putting the correct kill switch on the bike would re-ignite the ignition circuit. New Kill switch installed and still no spark out of the bike! The bike was running when I took the original kill switch apart and something I did in the process has caused the bike not to spark. I doubt its clutch or kick stand switch; it would be to coincidental. Is it possible a fried the ECU when trying to hot wire the kill switch (I definitely made some wrong connections and blew the main fuse a few times). Or am I missing something really obvious??? Any help that helps me not look like an idiot while working on my girlfriends bike is greatly appreciated! If I posted this in the wrong place please let me know, like I said I'm a rookie at this and computers in general. Thanks!
Avery 1983 XL250 1983 CR250R 1990 DR350 (2x) 1977 KZ 400 2001 Ducati M750 2002 CR250R 2005 XR650L 2010 Husky TXC 250 |
08-21-2012, 10:03 PM
#3664 | |
Oddometer: 2
I have a 2006 KLR myself. Picked it up on eBay in Albany, NY Last Dec 12th for $3k. This is my first KLR and I'm loving every minute on it. I put almost 1500 miles on it so far. It had 7k on it when I got it.
08-21-2012, 10:37 PM
#3665 | |
Oddometer: 2,019
Here's a wiring diagram. http://www.google.com/imgres?imgurl=...QEwAA&dur=2828 Look at the IGNITION SWITCH MATRIX (upper left of diagram) and the ENGINE STOP SWITCH schematic (as labeled). Chances are, you grounded the exciter coil lead to the CDI when you transplanted the new kill switch. On the matrix, pay attention to what should be connected, and what should NOT be connected, when the ignition switch is ON. Chase the continuity and connections with a multimeter, and you should be fine. |
08-22-2012, 04:12 AM
#3666 |
Backcountry Rider
Oddometer: 362
If i fit the pelican 1550 cases to the panniers on a klr, would the corners of the cases dig into my passengers rear legs?
Buell Ulysses Xb12X Suzuki DR200SE 2007 Sold Custom Leather Work-Made In England www.lordofleather.com https://www.youtube.com/user/frontiercolorado |
08-22-2012, 07:06 AM
#3667 | |
Oddometer: 81
08-22-2012, 08:14 AM
#3668 | |
Oddometer: 2,066
If your primary concern is low RPM's and not so much acceleration, I'd jump right up to a 17T front sprocket. It'll drop your RPMs down almost a full 1k at highway speed. The tradeoff is that the ability to accelerate quickly is noticeably less. On my latest KLR I plan on putting a 685 kit in to help in this area. If your trip involves mountain passes, the 17t probably isn't a good option. Also, just my humblest of opinions, but EVERY highway-going KLR needs a Madstad Robo Bracket screen. I've had 5 different windscreen configurations on my 3 KLRs, and this is the absolute best windshield I've found. Infinite adjustment/placement options (infinite in the "normal" range. You can't put it under the bike. ), offering me quiet and virtually turbulence-free air around my helmet. Earbuds heard perfectly for 20 hours of straight, fatigue-free riding. No, I don't work for them. I wish. ![]() My Avon Gripsters looked virtually unworn when I returned to NY following my 95+ degree 2600 mile FL trip. All these replies should get you a decent idea for a starting point, anyway.
08-22-2012, 09:36 AM
#3669 | |
KX & CR 500 Rider
Oddometer: 311
http://cariboucases.com/store/?name=...=i&item=000125
Go faster than everyone. Only worry about what's in front of you. '08KX500AFC(my favorite) '07KLR650 '04KX500(street legal) '97CR500R '06KLX250(351cc kit) '08KFX450R quad |
08-22-2012, 09:46 AM
#3670 | |
Newbie KLR adv rider
Oddometer: 1,052
I like the duffle bag idea.
00 KLR650 I wonder what is over that dirt thingamagig? http://share.findmespot.com/shared/f...Op8LhphYfeBJ9I |
08-22-2012, 10:30 AM
#3671 |
Oddometer: 81
If you run your straps through the handles of a duffel bag the bag can to side to side or forward or backwards and all duffel bags have handles. I also have a wide rear rack at 24 inches but if the duffel sags to much on the sides make sure the tent or something sturdy is in the bottom to brace it or stick a piece of wood in the bottom the length of the bag. I have used motorcycle specific duffel bags and I always end up using my old camo bag. Just seems to work better for me and I like only one zipper and one compartment that is hard to find with motorcycle specific bags. For those smaller things needing their own compartment i have a tank bag and a small tail bag in the duffel. no need for all the extra zippers and stuff.
When riding solo turn the duffel longways on the bike and it makes for a good drivers back rest. just make sure you put something soft in that end. I also normally put a bungee net over the duffel. If it warms up and you need to shed a layer you can just pop it under the net in a few seconds and your good to go again. |
08-22-2012, 11:02 AM
#3672 | |
Oddometer: 42,616
If you have the old blown up kill switch / starter button, it's easy to hotwire the bike: There are a ton of questions to answer... Have you removed the plug from the head and held it against the motor while cranking the starter to visually check for spark? Have you disabled the safety switches on the bike? Is there fuel in the carb? Are you engaging the choke? I'm sure it's something easily remedied. Good luck!
http://www.youtube.com/watch?v=C6cxNR9ML8k |
08-22-2012, 11:20 AM
#3673 |
KX & CR 500 Rider
Oddometer: 311
Video answer to the question, your the man!! AAA+
08-22-2012, 05:01 PM
#3674 |
Oddometer: 2,019
+ 1.
Video shows, BROWN to YELLOW/RED activates starter; BLACK/YELLOW to BLACK/WHITE shuts 'er down. BLACK/YELLOW to BLACK/WHITE is the kill mechanism also from the ignition switch when in LOCK/OFF/PARK position. |
08-23-2012, 04:40 AM
#3675 | |
TAT'erd
Oddometer: 1,816
I got a chance last night to clean and reoil the stock foam filter and swap it for the K&N. Stumbling is gone. I'm sure there's some jetting change that'll make it run correctly with the K&N but I'd rather ride. Headed out west to Wyoming for two weeks so I'm probably better off with the foam and oil anyway. John
Endeavor to suck less--Gaspipe I would rather be riding an imperfect bike than waiting around for perfection. --JDowns |
