11-20-2012, 06:25 AM
#4306 |
Artful Tagger
Oddometer: 3,422
PM sent
Adam 86 KLR250 01 KLR685 06 K1200LT As ever, buyer and seller of all things KLR KLR Doohickey Wrench available! The North Florida Tag-O-Rama wants YOU! |
11-20-2012, 06:26 AM
#4307 |
blah blah blah
Oddometer: 1,378
Craig, with the clutch actuator arm in the position of the first picture, push it toward the cable (front of the bike) and ensure that it does not move upward. You will be manually moving the clutch with your hand, so it's some work, but that's how I got mine in when I experienced the same issue.
I'd be glad to hear if there is a trick to this, but I don't think there is. Just make sure it stays in the hole as you move it forward. |
11-20-2012, 08:08 AM
#4308 |
Just Me...
Oddometer: 3,597
Me, too. Changing that cable is a pita...and I'm do to change mine....
Txt msg with Dan right after he was paralyzed: Me: Hey Dan-O. Just wanted to say howdy and Love ya! Dan: Howdy and Love you too. Doin' good and feeling good. Me: Give 'em hell, little Bro! Dan: Roger that. |
11-20-2012, 08:43 AM
#4309 | |
Scone Rider
Oddometer: 6,719
We don't stop riding because we get old, we get old because we stop riding. |
11-20-2012, 09:20 AM
#4310 |
mcpenner
Oddometer: 120
another doohickey question!?!?!?
I know, I know ... the KLR doohickey has been discussed to death. I've done search, read long threads, watched video, and I know where to order parts.
but There is something I'm curious about that I haven't really come across yet, so here we go again (don't get angry, just move on if you don't like me bringing this up again). I have seen very little about what actually causes the doo to break. I know it is a weak part and poor design and all that. I know the replacement parts are strong enough to hold up. It seems to me that the most likely cause of breakage in the balancer chain assembly would be when the wheel leaves the ground, speeds up and then makes contact again, or when the wheel is spinning and then suddenly contacts good traction sending shock back up through the whole system. In these conditions the weakest part would weaken and fail. ?????? Sooo, seeing as I am new to dirt and off road and I am very careful to avoid wheel spin and or any air under my wheels. I know this will change as my skill improves over time, but until then should I really worry about the doo? |
11-20-2012, 09:27 AM
#4311 |
blah blah blah
Oddometer: 1,378
I can't comment on what causes it to break, but my bike had 14,000 miles on it, and a PO said it was used only as a commuter and had literally been driven across a field only once, never offroaded, etc, etc.
At 14k miles, I pulled it apart to do the 'doo, and the doo was in 2 pieces, and the spring was in 2 pieces. |
11-20-2012, 09:29 AM
#4312 | |
mcpenner
Oddometer: 120
11-20-2012, 09:51 AM
#4313 | |
Why not Zoidberg?
Oddometer: 53
2006 KLR650 Aztek Red / SW Motec Bars, Givi Top Case, Tank Bag, PMR Rear Luggage Guard, IMS Pro pegs, Mirror Relocation mod, Moose Folding Shift Lever, Gold Valve Cartridge Fork Emulators, T-Mod, Coleman Seat Cover, Tusk D-Flex Handguards, Horse Saddlebags, Drill Through Subframe Upgrade, 12.9 Bolts, Doohickey, 16TFS, AGM Battery, AeroLED Tail Light |
11-20-2012, 10:35 AM
#4314 | |
Semi-reformed Tsotsi
Oddometer: 789
The second issue is with the stock springs. Two isssues with these. The ends that hook were made over a sharp edge creating a kink and a weak spot and the hook end would break off. Then when they hardened/tempered the springs after being wound, some were over hardened - the result being fatigue breaks in the coil. So, some had the 'doo' break, others have had the spring break. To overcome these issues, EMike machines the 'doo' out of solid SS so there is no welding. The springs he has made do not have the kinks and the tempering is more strictly controlled. |
11-20-2012, 10:45 AM
#4315 | |
Luminous nut
Oddometer: 290
My current garage: -2004 Kawasaki KLR650, Rigid Dually LED lamps (DD) -1996 Jeep Grand Cherokee 5.2L V8 (Donor) -1989 Jeep Wrangler, stripped to the bone (Implant-ee) -A boatload of 80's 3 wheelers |
11-20-2012, 11:01 AM
#4316 | |
Oddometer: 340
11-20-2012, 12:21 PM
#4317 | |
Oddometer: 42,649
The main thing that causes the part to fail is ham-fisted mechanics. ![]() The second thing is the weakness of the part. If you're the kind of person that waits until something breaks to replace it, it could get expensive... It's a very simple preventive maintenance job, why not just do it and be done with it?
http://www.youtube.com/watch?v=C6cxNR9ML8k |
11-20-2012, 12:40 PM
#4318 |
Oddometer: 120
on 2 of the 3 bikes ive replaced the doohickey on had not been due to it breaking but spring broke in 2 . the other had no tension whats so ever just sitting totally loose . The bracket was little scared but not broken .
my 01 had 33500 miles my 2012 had 2000 both springs were broke . the one totally loose doing nothing was a 91 with 45000 miles .. |
11-20-2012, 01:27 PM
#4319 |
mcpenner
Oddometer: 120
OK, I think I get the idea already. The doohickey and/or spring can and will break for no apparent reason other then bad design and build quality. I only asked because I have very limited funds for this bike right now and need to be careful how I priorities my farkeling.
11-20-2012, 02:01 PM
#4320 |
21st century adventurer
Oddometer: 334
Carb rebuild complete
I just got the bike back together and took it out for a ride. It's backfiring on deceleration
![]() Can I turn the pilot mixture screw one way or the other to cease this symptom? I put the new mixture screw in and adjusted it as the kawi repair manual spec'd Everything with the carb is stock, air box stock, aftermarket pipe... |
