Old 11-20-2012, 02:13 PM   #4321
IDRIDR
Take me to the River
IDRIDR's Avatar
Oddometer: 1,463
Originally Posted by jonyfi View Post
I just got the bike back together and took it out for a ride. It's backfiring on deceleration
Can I turn the pilot mixture screw one way or the other to cease this symptom?
I put the new mixture screw in and adjusted it as the kawi repair manual spec'd
Everything with the carb is stock, air box stock, aftermarket pipe...
Turning the mix screw out (counter-clockwise) may richen the mixture enough to help with the decel popping. But that may not be the best method of setting the mix where it should be. I don't know about the KLR as mine still has a stock exhaust, but on my other bikes I've found aftermarket mufflers may pop some regardless, and a little air leak in the exhaust, such as where the header connects to the muffler and/or to the head, will result in decel popping. Find those leaks if they exist and fix them. Shouldn't hurt to give the mix screw a try, though. Don't go too far (usually no more than 3 turns out).
IDRIDR is online now   Reply With Quote
Old 11-20-2012, 02:15 PM   #4322
XDragRacer
Oddometer: 3,168
I'd recommend bottoming the fuel screw (gently!), than backing it out 1.75 turns as a starting point. May help reducing backfiring on deceleration; OEM settings excessively fuel-lean, IMHO.
EDIT: Didn't intend to post redundant to IDRIDR's above; looks like we hit our SEND buttons almost at the same time.
XDragRacer screwed with this post 11-20-2012 at 09:47 PM
XDragRacer is online now   Reply With Quote
Old 11-20-2012, 02:32 PM   #4323
jonyfi
21st century adventurer
jonyfi's Avatar
Oddometer: 410
OK, so after a few responses confirming that strategy as an option I will give it a try. I did do some research before reassembling and some folks suggested 2 and 1/2 turns... I thought that that was quite different than KAWI's suggested 1 and 3/8 turns...
I did 1 and 1/2
I will go to 2 turns
....and see what happens
jonyfi is offline   Reply With Quote
Old 11-20-2012, 02:33 PM   #4324
Grinnin
Forever N00b
Oddometer: 2,772
Valve stem seals
Originally Posted by redog1 View Post
Anyone ever replaced them without pulling the head?
Thoughts?
Thoughts:
  1. Each oil seal is under a valve retainer and surrounded by two springs.
  2. The retainer must come off to get a new seal over the stem even if you cut the old seal out.
  3. The springs have to be compressed to remove the keeper and retainer.
  4. The springs are strong.
If you made a spring compressor that DIDN'T press on the face of the valve, it would have to hold the valve stem against pretty strong pressure and not mar the stem.
So I think that you've had no responses because nobody has done it. But let this post bump your question to the current page and maybe we'll hear about someone who has done it.
"The belief that there is only one truth, and that oneself is in possession of it, is the root of all evil in the world."-- Max Born, Nobel Physicist
Grinnin is offline   Reply With Quote
Old 11-20-2012, 02:59 PM   #4325
redog1
KLR650-2009
redog1's Avatar
Oddometer: 1,798
I appreciate the input.
Pretty much convinced the head has to come off for the reasons you state. Really no way to compress the valve springs to get the keepers off, even if you could it's not likely you could get them reinstalled. I'll just dive into it. Now since I have to go that far, I'm thinking I might as well re-ring it. Have all winter to do it.
No, I don't know where that road goes, let's find out!
redog1
redog1 is offline   Reply With Quote
Old 11-20-2012, 03:37 PM   #4326
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,427
I did 1 and 1/2
Make sure you don't have a air leak on the downstream side of the carb. To test, hold an unlit propane torch around the intake side with the bike idling. If the idle speed changes, it's sucking in propane thru a leak. As mentioned, popping is a sign of running too lean.
We don't stop riding because we get old, we get old because we stop riding.
"Wisdom is knowing what to do next, Skill is knowing how to do it, and Virtue is doing it"
HellSickle is offline   Reply With Quote
Old 11-20-2012, 03:41 PM   #4327
OKlr
25mph gate inpector
OKlr's Avatar
Oddometer: 832
key word there.
OKlr is offline   Reply With Quote
Old 11-20-2012, 06:33 PM   #4328
sandalscout
blah blah blah
sandalscout's Avatar
Oddometer: 2,210
I have no experience with doing them on a car, but I've seen/handled a valve spring compression tool that you can use while the head is still on the block for both a Honda and Mitsubishi. They were both based on C-Clamps with special fittings on them. Anyway, just saying that while it may technically be possible, I don't think you could actually get one in around the frame.
sandalscout is offline   Reply With Quote
Old 11-20-2012, 07:12 PM   #4329
jonyfi
jonyfi's Avatar
Oddometer: 410
Originally Posted by OKlr View Post
key word there.
UNLIT...
Ya for sure...
Old 11-20-2012, 09:00 PM   #4330
Aprilia
Oddometer: 721
I did 1 and 1/2
What year is your KLR? GenII's are equipped with AIS and its sole purpose is to inject fresh air into the exhaust port to burn off excess fuel while decelerating i.e. popping is direct result. If your's is a GenI then most likely cause is exhaust leak allowing fresh air to enter the exhaust. Header flange is most common.
I set my fuel screws using an Air/Fuel meter with an O2 bung installed in the header. Most KLR's like to see just under 2 turns to just over 2 turns. Temp/elevation changes can alter the proper setting. You can set by 'ear' pretty easily. Does take a bit of practice/patience but get a feel for it and you can set it almost as accurate as a wideband A/F.
How to....install an adjustable fuel screw. Get the bike fully warm. Turn idle down below 1K rpm's. Begin turning the fuel screw in 1/4 at a time but give the bike 8-10 sec to respond to each movement. What you are looking for is when RPM's drop. Once you find that point notate the number of turns out. Now begin to open the fuel screw 1/4 turn until RPM's drop. Notate the setting then divide the two setting to arrive at your ideal setting. Be sure to return your hot idle RPM's back to at least 1200.
Side note: I've had several CVK carbs with such poor needle to needle valve sealing that even with the fuel screw closed the bike would still run. Not supposed to do that! If your bike is one then simply set it 2 turns out and call it a day.
Aprilia is offline   Reply With Quote
Old 11-20-2012, 11:49 PM   #4331
Old Kiwi#99
Oddometer: 281
I've done this many times on car engines. With relevant piston at TDC, screw a spark=plug threaded adapter in and compressed air is applied to hold the valves shut (normal shop air pressure).
Valve sprint compressor is not the usual G clamp style, in this case it is attached to the cylinder head eg use the rocker stud and then lever down on the spring as usual.
If you really really wanted to do the KLR you could make a shaft that replaces the cam, use that as a fulcrum to put the spring compressor lever under (eg put the shaft in the inlet side to do the exhaust springs.)
Old Kiwi#99 is offline   Reply With Quote
Old 11-21-2012, 04:08 AM   #4332
tommu56
tommu56's Avatar
Oddometer: 1,371
I did a tractor by stuffing clothes line in the spark plug with the piston at BDC and spinning crank to TDC or as close as you can get it to hold the valve in position. compress the spring
Some thing like this is what I used to compress the spring again it had a push rod and rocker arm over the top not OHC.
tom
tommu56 is offline   Reply With Quote
Old 11-21-2012, 05:00 AM   #4333
Tsotsie
Semi-reformed Tsotsi
Oddometer: 1,838
If the seals need replacing, there is a good chance that the valves/seat need re-facing or grinding too. Might as well do a full head clean-up job if you are going to that much trouble just for the seals
Tsotsie is offline   Reply With Quote
Old 11-21-2012, 05:33 AM   #4334
Danger4u2
'04KX500isDanger4u2
Danger4u2's Avatar
Oddometer: 643
+1. If it's worth doing it's worth doing it correctly.
Go faster than everyone.
Only worry about what's in front of you.
Danger4u2 is offline   Reply With Quote
Old 11-21-2012, 06:45 AM   #4335
Rode2Nowhere
Rode2Nowhere's Avatar
Oddometer: 2,210
I (unfortunately) had the head off my '08 twice when I had it. Sounds/seems like a daunting task at first, but its not so bad. Just takes time, and an extra $38 or so for a head gasket.
Beyond what's involved with a valve adjustment and the Doo, its pretty much just pulling the carb, the exhaust header, coolant hose, and the bolts holding the head to the cylinder, and taking care not to drop the cam chain into the case. And of course proper torque when re-installing.
- Jonathan
'88/'96/'08/'09 KLR650 Amalgamation
IBA #45896
Adirondack Tags
Rode2Nowhere is offline   Reply With Quote
Times are GMT -7.   It's 08:52 PM.
