Old 11-22-2012, 08:54 AM   #4336
mxboy96
mxboy96's Avatar
Oddometer: 65
16tooth/interfere with stator wires?
Hey ya hooligans. Wonderin if any of you guys have thought of or made a cool mod to get the stator wires out of the way when putting on a 16 tooth front sprocket? I've got mine on, but the chain rubs on the 'plastic' guard and it will eventually wear through, contacting the stator wires they so convienently ran right there. I'd like to keep my 16 tooth, but I really want to keep the stator wires too(they're just a tad more critical;)). Thanks guys!
Tanman
mxboy96 is offline   Reply With Quote
Old 11-22-2012, 09:10 AM   #4337
bush pilot
bush pilot's Avatar
Oddometer: 2,531
I never had a clearance issue with 16 tooth sprocket. I heard the guys who run the 17 toothers have to remove the cover, but still cleared the wires.
USA travels 09'
Anchorage to Ushuaia
RTW...part: Europe
Iron Butt #35784
bush pilot is offline   Reply With Quote
Old 11-22-2012, 09:56 AM   #4338
East Coast Rider
Just Me...
East Coast Rider's Avatar
Oddometer: 3,903
No clearance issues with stator wires on my 16....
Txt msg with Dan right after he was paralyzed:
Me: Hey Dan-O. Just wanted to say howdy and Love ya!
Dan: Howdy and Love you too. Doin' good and feeling good.
Me: Give 'em hell, little Bro!
Dan: Roger that.
East Coast Rider is offline   Reply With Quote
Old 11-22-2012, 12:40 PM   #4339
Nitro1970
Nitro1970's Avatar
Oddometer: 191
No problems with a 16. Had to trim the guard a bit for the 17 but it never has gotten into the wires...
Nitro1970 is offline   Reply With Quote
Old 11-22-2012, 12:41 PM   #4340
Grinnin
Forever N00b
Oddometer: 2,708
I have a 2001 and I don't know if the sprocket cover and "separator" are exactly the same or not. (I'll call it a separator because it sure ain't a protector.)
I saw some superficial marks on my the separator and looked into it a bit. With the bike in the air and the suspension fully extended the chain can rub on the back lip of the sprocket cover. And it's hard to see the front of the sprocket with the cover on so, for a while, I thought I could hear the chain hitting the separator.
In the end I decided that the marks were from when the chain is loaded with clay and crud and that the chain doesn't usually hit the plastic. The superficial marks haven't changed much in 10 or 14 thousand miles.
I can see how these pieces of plastic can each flex a little differently so one may have contact where another does not.
Motorcycles are magical.
Grinnin is offline   Reply With Quote
Old 11-22-2012, 06:47 PM   #4341
NHADV
NHADV's Avatar
Oddometer: 554
Anyone out there go from stock Dunlop's to Kenda Big Blocks? I just put a set on and the front end seems glued to the road. I only put 25 miles on going to dinner and back. Anyone else notice a big handling difference when you switched?
-Gary
NHADV is offline   Reply With Quote
Old 11-22-2012, 10:14 PM   #4342
tjk2134
Oddometer: 9
I have over 10,000 miles on my 17 front sprocket, I had to trim the cover but managed to tuck the wires away from the chain and so far so good. It turns about 5000 rpm at 85mph.
tjk2134 is offline   Reply With Quote
Old 11-23-2012, 08:51 AM   #4343
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 7,909
Originally Posted by XDragRacer View Post
Citation, please!
Then, you shall have informed me; haven't noticed any prohibition on friction modifiers in any Kawasaki owner's or service manual, but . . . none of my teachers ever suggested I was a particularly careful reader.
Beyond that, have you ever personally observed or experienced a KLR clutch damaged from exposure to friction modifiers?
Ok, I wasn't supremely confident in what it said, but because I have more of a "photographic" memory of sorts, I was pretty sure there was a diagram of the label in there somewhere. Guess I was not fullly correct (more detail below.) So here's what my owner's manual says. No diagram, just text.
So the only real spec that I wasn't familiar with was the "SE, SF, or SG".
Looked it up and here's what I found. All are obsolete.
My KLR Clymer manual says the following:
Again, no diagram.
Maybe it's my Suzuki Clymer? Nope. Same basic story though.
Lastly, I checked my '03 Honda Shadow Spirit 750 owner's manual. Bingo.
So, technically, no, my KLR manual doesn't specifically reference the labeling like I thought.
In my search for further knowledge in limited time this morning, I stumbled into this article by Motorcycle Consumer News which supposedly "debunks" the Auto oil vs. Moto oil debate.
I'll try to give it a full read when I have time.
LINK HERE.
Also, as to my personal experience, I used Mobil 1 in my bike for MANY miles. Made sense to me because that's what I used in my car too. Well, I can't prove any correlation, but I'm probably one of few individuals on here that have replaced the clutch in my KLR. Take that as one potential data point if you like.
"This place fucking runs on beer, you buy the right person a beer, and you get a job, a blow, a place to sleep, whatever.
You're hot, cold, thirsty, hungry... beer will fix that.
Beer is a god damn miracle, and don't you forget it!"
-DustyRags
DirtyDog is offline   Reply With Quote
Old 11-23-2012, 09:05 AM   #4344
GreatWhiteNorth
GreatWhiteNorth's Avatar
Oddometer: 2,106
Another good oil article
Thnx for posting above... some good info. I think the oil in KLRs leads a tough life. Reading this article below convinced me to change my oil out sooner than I had been doing.
Another interesting automotive vs motorcycle oil article: http://motorcycleinfo.calsci.com/Oils1.html
Spending my daughter's inheritance one motorcycle at a time.
Bikes currently owned: '91 Honda Gold Wing with sidecar, '92 Kawi KLR650 with Enduro sidecar, '94 KLR650, KL250 Super Sherpa.
GreatWhiteNorth screwed with this post 11-23-2012 at 09:26 AM
GreatWhiteNorth is offline   Reply With Quote
Old 11-23-2012, 03:55 PM   #4345
redog1
KLR650-2009
redog1's Avatar
Oddometer: 1,797
I change my oil every 2500 miles
in both my 2009 and 1990. I use Castrol GTX 10w40. Tried different viscosities but found 10W40 works best for me and my riding. The only thing I've found with using automotive oil is the clutch tends to grab when started in gear cold. After warm it's a non-issue. My clutch doesn't slip, never has unless I've been riding it in technical terrain. When I start my bike cold in gear, I just tap the start button to "break" the clutch loose. Haven't had any problems, both bikes have 32K on them now and I've had the 2009 since new and the 1990 since approx 18K miles. I'll stick to what works for me.
No, I don't know where that road goes, let's find out!
redog1
redog1 is offline   Reply With Quote
Old 11-23-2012, 04:27 PM   #4346
MacNoob
MacNoob's Avatar
Oddometer: 1,601
Seems to be a KLR issue regardless what oil is used.
Generally only 'thinner' oil like 5W-30, 10W-30 (stuff we're not using anyways) will have the dreaded friction modifiers. 'Thicker' oils that we use (xW-40, xW-50) never will. Thus they will never say 'energy conserving' in the API donut symbol.
"Ignorance, you see, can be out thought. Arrogance can be outmaneuvered. But ignorance and arrogance combined are unassailable."
82 Honda C70, 71 Honda CL175, 08 Kawasaki KLR650, 85 Honda GL1200 Goldwing
MacNoob is offline   Reply With Quote
Old 11-23-2012, 05:11 PM   #4347
MotoBoss
Bad Influence
MotoBoss's Avatar
Oddometer: 3,741
Putting it up for sale
http://www.advrider.com/forums/showt...20330&page=160
Adventure Before Dementia
MotoBossMotoBlog
AdventureRiderRadio
Donate To ADV
MotoBoss is offline   Reply With Quote
Old 11-23-2012, 05:12 PM   #4348
XDragRacer
Oddometer: 3,095
Neither does mine (2007 Kawasaki KLR650 Owner's Manual):
So much for Kawasaki's recommendations (no prohibition listed for "friction modifiers" or "energy conserving" in the KLR250 Service Manual supplement, either).
The Clymer Generation 1 KLR650 manual contains the same italicized caveat regarding additives you imaged above, but I found no specific friction modifier/energy conserving oil-in-the-bottle cautions:
Regardless, thanks for sharing your most interesting research.
Oils containing "friction modifiers" or formulated with some "energy-conserving" association may indeed be detrimental to wet clutches; just didn't recall any Kawasaki advice to that effect.
Sorry about your clutch; if it failed as a result of running zinc-laden Mobil 1, this fact's worth a warning to KLR (and other wet-clutch motorcycle) riders.
Again, appreciate the references.
XDragRacer is offline   Reply With Quote
Old 11-23-2012, 05:18 PM   #4349
Tsotsie
Semi-reformed Tsotsi
Oddometer: 1,793
Ok,
Now if you have a Kawasaki KLR works manual it tells you specifically to use Moly based grease when assembling several parts of the motor - starter motor idler gear bearings, clutch lifter shaft, etc.
I have never heard of a documented failure regarding the use of different oil types in KLR's or extended oil change periods. There is a heap of opinion, assumptions, claims, speculation and "..I know a mechanic who told me...", "...an oil rep once told me...", relating to when, how, why not and why. Low oil, yes.
Choose the right weight oil that KAWA suggest, then the color of the bottle you like or flip a coin. You cant go wrong.
Tsotsie is offline   Reply With Quote
Old 11-23-2012, 05:43 PM   #4350
GreatWhiteNorth
Oddometer: 2,106
[QUOTE=Tsotsie;20105234] I have never heard of a documented failure regarding the use of different oil types in KLR's or extended oil change periods. There is a heap of opinion, assumptions, claims, speculation and "..I know a mechanic who told me...", "...an oil rep once told me...", relating to when, how, why not and why. Low oil, yes. QUOTE]
These articles regarding oil life mention how quickly oil breaks down changing viscosity. A lower viscosity wouldn't provide as much protection to delicate plain bearing surfaces, right? Am thinking this may factor in to galling often found in the cam bearing caps? I sure notice how much thinner my oil is when I drain it after 2000 miles as compared to when new. I've been using nothing but Castrol GTX 10w40 mc oil, but have started recently adding Shell Rotella T synthetic (HD diesel oil) when topping it up to restore viscosity as the oil wears. ...not as good as Mobil 1, but a pretty good oil IMO.
Times are GMT -7.   It's 09:10 AM.
