11-29-2012, 04:19 PM
#4411 | |
Oddometer: 98
11-29-2012, 04:35 PM
#4412 |
Oddometer: 300
I have an '06, and in the summer I just take the stock shield off & run with the fairing only. I get wind, but it's clean & quiet..No buffeting. To me it's a big improvement over the stock shield. I have a tall shield I put on in the cold weather, and it's noisy, but keeps the cold wind off my chest.
(I'm 5'9" 30" inseam) JIm .
The older I get, the faster I was. It's all about attitude & timing. I'm not sure where we're going, but this road seems to be paved with good intentions. |
11-29-2012, 06:02 PM
#4413 | |
Oddometer: 178
11-29-2012, 07:39 PM
#4414 |
Oddometer: 190
1989 KLR650 owner checking in!
Broken at the moment... won't rev over 3500 rpms, something wrong in the carb I recon. |
11-29-2012, 11:30 PM
#4415 |
Oddometer: 340
11-30-2012, 12:37 AM
#4416 | |
mach schnell
Oddometer: 1,436
Look at Parabellum. http://parabellum.com/ I have one on my GS and it's great. I have been pondering getting one for the KLR too.
****** Mess with me and you mess with the whole trailer park. ausfahrt screwed with this post 11-30-2012 at 07:37 AM |
11-30-2012, 06:34 AM
#4417 | ||
Oddometer: 2,066
Madstad 18" clear Adventure shield on their RoboBracket system
![]() Quote:
![]() They're actually Seahorse SE 720 cases, not Pelicans. Less expensive, quote tough, and waterproof. Don't seem to have any better pics than this. Apologies. ![]()
11-30-2012, 04:41 PM
#4418 |
Oddometer: 47
Tire pressures?
Hey guys. Curious what you guys run for tire pressures, especially offroad? I know factory says 21, but I remember running about 10-12psi on my old mx bike for offroad use. Should you run it that low even for the KLR? What do you guys use? And also, I finally replaced the useless factory dunlop on the front finally with a Pirelli MT21, and it's better(gravel), but not great. Gravels mainly what I ride on. Are your guyz bikes squirrely on loose soil too? Thanks for the input
Tanman
11-30-2012, 04:49 PM
#4419 | |
Oddometer: 42,650
Any lower around here and you are asking for a pinch flat...
http://www.youtube.com/watch?v=C6cxNR9ML8k |
12-01-2012, 07:39 AM
#4420 | |
Oddometer: 340
12-01-2012, 07:46 AM
#4421 |
Gorilla Adventurer
Oddometer: 1,951
MT21 fronts are great!
I don't run less than 18. Dropping from 20 to 18 makes a huge difference.
bikes |
12-01-2012, 07:53 AM
#4422 | |
Oddometer: 2,043
Also stand up on the pegs, stay loose on the grips,use the pegs for direction,and let the bike dance a bit. |
12-01-2012, 10:38 AM
#4423 |
Oddometer: 300
k270's
approximately 30 on the street 20 in the dirt. front and rear.
12-02-2012, 01:47 PM
#4424 |
aka Shifter
Oddometer: 218
Need Front Brake Help
Hey Guys,
Hoping someone can help me out. I bought this CZR system from ebay. The seller has sold a ton of them and has lots of great reviews. But I'm having a strange problem with mine. It fits the bike fine, but the calipers won't bite the rotor until the lever travels all the way to the handle bar. And then it just barely grabs the rotor. If I fiddle with the adjustment screw on the lever, the pads drag on the rotor. Basically, the caliper remains partially engaged. And even with the caliper partially engaged, with the pads dragging on the rotor, significant lever travel is required before the caliper grabs the rotor. I have installed a new steel braided line, there are no leaks and there is no air in the system. Repeatededly bled the brakes. Everything is new. New caliper, new rotor, new master cylinder/lever, new brake line, new pads, new fluid. I'm stumped. Wondering if anyone has any experience with this system and/or advice. Thanks ![]() ![]()
Thanks flea market. |
12-02-2012, 02:42 PM
#4425 |
Luminous nut
Oddometer: 290
Perhaps the master can't push enough fluid to properly engage the brake caliper. Or there is still air in the lines. I've bled brand new hydros before and sometimes it takes a lot of bleeding to get all of the air bubbles out.
---------- Gents (and ladies), I passed my MSF class today with outstanding success. Just have to wait for my forms to come in the mail and then I can take my DMV permit test. Then I can actually get out on the open road rather than screw around on the trails and private roads around town here ![]() ![]()
My current garage: -2004 Kawasaki KLR650, Rigid Dually LED lamps (DD) -1996 Jeep Grand Cherokee 5.2L V8 (Donor) -1989 Jeep Wrangler, stripped to the bone (Implant-ee) -A boatload of 80's 3 wheelers |
