Old 12-02-2012, 03:18 PM   #4426
SavannahCapt
SavannahCapt's Avatar
Oddometer: 860
Good day for a ride to the river
Burton's Ferry, 301 Bridge over Savannah River
[IMG]Photobucket[/IMG]
Anyone can take the helm when the seas are calm.
SavannahCapt is offline   Reply With Quote
Old 12-02-2012, 03:27 PM   #4427
MC-Shifter
aka Shifter
MC-Shifter's Avatar
Oddometer: 220
Thanks XpressCS. I've bled it repeatedly. Same result every time. Bled it at both banjo bolts. No luck
Thanks flea market.
MC-Shifter is offline   Reply With Quote
Old 12-02-2012, 04:47 PM   #4428
beemerjim
beemerjim's Avatar
Oddometer: 449
I'm not very good at bleeding brakes, but one of those vacuum bleeders on the caliper does wonders for me.
jim
The older I get, the faster I was.
It's all about attitude & timing.
I'm not sure where we're going, but this road seems to be paved with good intentions.
beemerjim is offline   Reply With Quote
Old 12-02-2012, 05:12 PM   #4429
Aprilia
Oddometer: 791
Originally Posted by MC-Shifter View Post
Hey Guys,
Hoping someone can help me out. I bought this CZR system from ebay. The seller has sold a ton of them and has lots of great reviews. But I'm having a strange problem with mine. It fits the bike fine, but the calipers won't bite the rotor until the lever travels all the way to the handle bar. And then it just barely grabs the rotor. If I fiddle with the adjustment screw on the lever, the pads drag on the rotor. Basically, the caliper remains partially engaged. And even with the caliper partially engaged, with the pads dragging on the rotor, significant lever travel is required before the caliper grabs the rotor.
I have installed a new steel braided line, there are no leaks and there is no air in the system. Repeatededly bled the brakes. Everything is new. New caliper, new rotor, new master cylinder/lever, new brake line, new pads, new fluid. I'm stumped.
Wondering if anyone has any experience with this system and/or advice. Thanks
You have air in your brake system. I always power bleed from the caliper up to the mstr on the bars. Try wrapping a strap around your brake lever after pulling it as far back as it will go. leave it over nite and give it another try.
Aprilia is online now   Reply With Quote
Old 12-02-2012, 07:21 PM   #4430
MC-Shifter
aka Shifter
MC-Shifter's Avatar
Oddometer: 220
thanks
This is one technique I have not tried. I will do this.
Thanks for the advice, Friends
Thanks flea market.
Old 12-03-2012, 06:49 AM   #4431
Kawidad
Kawidad's Avatar
Oddometer: 5,076
Agreed, all your symptoms point to air in the line.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 12-03-2012, 06:55 AM   #4432
bigdon
Oddometer: 2,686
It is very hard to bleed the brakes with a loop that is higher than the master cylinder.
If that is your problem , lay your bike on the left side and then bleed brakes again. Don't ask how I learned this!
ADV Relay Rider 08 (The Texas Connection)
Ride Pooie Ride
Don't stop riding until you get to the crash , you might save it!
bigdon is offline   Reply With Quote
Old 12-03-2012, 12:01 PM   #4433
MC-Shifter
aka Shifter
MC-Shifter's Avatar
Oddometer: 220
Thanks for all the prompt advice guys. I'm unfortunately not going to be able to get to it again until Saturday. But I will try the techniques listed here. Again, thanks for the support!
Thanks flea market.
Old 12-03-2012, 12:53 PM   #4434
newcastleadam
Artful Tagger
newcastleadam's Avatar
Oddometer: 3,455
Where are you located? Can post up in the Regional section, perhaps someone can swing by, talk about brakes, and drink your beer. Or just drink your beer
Adam
86 KLR250 01 KLR685 06 K1200LT
As ever, buyer and seller of all things KLR
KLR Doohickey Wrench available!
The North Florida Tag-O-Rama wants YOU!
newcastleadam is offline   Reply With Quote
Old 12-03-2012, 01:16 PM   #4435
ADW
'tard bike restos
ADW's Avatar
Oddometer: 577
Like my '08 stock
Originally Posted by Straight View Post
Thanks for the replies regarding wind effect at speed. Is anyone satisfied with the stock shield and not looking to change it? Looks like a lot of options out there. I find that with all the bikes I've had/have. Just was hoping I could manage longish trips the way it comes stock.
I am 5'10" and like my 08 shield stock. Tried a laminar lip and hated it, gave me turbulence where I had none before. That said, a buddy of mine who's a little taller went for a ride and said he got bad buffeting. So I think it really depends on the individual and where you end up in the airstream, and also maybe to some degree your helmet, as that will of course be affected by the airflow (or lack of it). Personally I put mine back stock and am not gonna change it again.
08 KLR, 06 KLR w/Sputnik sidecar, 09 WR250R, 72 CB350F
ADW is offline   Reply With Quote
Old 12-04-2012, 06:49 AM   #4436
redog1
KLR650-2009
redog1's Avatar
Oddometer: 1,825
MC-Shifter....
I'm wondering why you're bleeding at the Banjo bolts? "Bled it at both banjo bolts." If you're bleeding it there down on the caliper you're not getting the air out of the upper piston on the caliper. Bleed your brakes using the bleeder valve on the caliper. The valve with the rubber cap on it. It's at the upper most part of the caliper and will allow all of the air out.
No, I don't know where that road goes, let's find out!
redog1
redog1 is offline   Reply With Quote
Old 12-04-2012, 07:55 AM   #4437
XpressCS
Must. Have. Lumens..
XpressCS's Avatar
Oddometer: 1,359
Just noticed he said Banjo bolts as well...
The bleeder valve will look like this:
2015 Yamaha FJ-09
XpressCS is offline   Reply With Quote
Old 12-04-2012, 11:05 AM   #4438
Fireman1000
Fireman1000's Avatar
Oddometer: 2,721
Anyone ever cut the stock screen down on a 2008+ KLR? If so, do you have pictures?
Fireman1000 is offline   Reply With Quote
Old 12-04-2012, 05:09 PM   #4439
phideaux
phideaux's Avatar
Oddometer: 3,361
Starting Issue
Got an issue with starting my 2001 KLR650.
Here's some background info. This bike has 20K on the clock. I am not the primary rider. I did a 685 upgrade about a year ago. This summer one of the main crank bearings went south. I have fixed that, and while I was in there I replaced ALL the bearings and seals. Believe it or not, I was able to replace the left side crank bearing AND race without having to replace the case! Got a new crank in there too, and a new set of rings.
Now for the starting issue:
Cold start is very good. Pull the enrichener and it fires right up, just as it should.
Hot start...not so good. Takes a while. I have found it starts better hot when I pull the enrichener, but then it still takes a few seconds of cranking and sometimes even a good backfire to get things going.
The bike runs great. Strong as ever and is delivering about 51 mpg or so.
Now you guys tell me how to make that KLR hot start like it should!
Thanks a ton!
Fido
Iron Butt Association No. 22913
Mrs. Phideaux to her octogenarian friend when the granny wants to know if she can sit on one of my bikes:
"It's Okay, they only fall over when HE'S on them."
North GA Tag-O-Rama Map
Georgia Tag-O-Rama Map
phideaux is online now   Reply With Quote
Old 12-04-2012, 06:00 PM   #4440
XpressCS
XpressCS's Avatar
Oddometer: 1,359
Have you pulled the carb and thoroughly cleaned it? Checked for air leaks?
2015 Yamaha FJ-09
Times are GMT -7.   It's 08:40 AM.
