Old 02-13-2013, 08:28 PM   #5101
ThomasVolomitz
New Old Stock
ThomasVolomitz's Avatar
Oddometer: 4,409
I will be overjoyed if its that simple.
https://m.facebook.com/dualsportdelinquents
Still Riff Raff
ThomasVolomitz is offline   Reply With Quote
Old 02-13-2013, 08:33 PM   #5102
SkiBumBrian
DualSport Crazy !!
SkiBumBrian's Avatar
Oddometer: 1,051
Originally Posted by BruceDeuce View Post
HI from N.J.. I recently purchased a 1986 KLR 600, in pretty good shape. I posted up in the Thumper thread about the noise Im hearing in the top end and was instructed to check the valve clearances. I am doing that tomorrow. I have another question, if ya dont mind. Theres a little hole in the bottom of the, I assume the water pump (right side front case) that is streamming water out of. It appears to be alot of water at idle. Is this normal?
Also can someone explain to me how to take out the Cam Chain Tensioner? Thanks Bruce
I assume the 600 is similar to the 650. The water out the weep hole is not normal, if only water the pump seal is bad. The cam chain tensioner is on the rear left side of the cylinder, I think it is a 14 or 15 mm into the casting of the cylinder. Buy a Clymers manual for your bike. Amazon may have one for the 600. If not just Google it. It is worth many times it's cost...
"Where ever you are, there you go..."
SkiBumBrian is offline   Reply With Quote
Old 02-13-2013, 08:43 PM   #5103
BruceDeuce
BruceDeuce's Avatar
Oddometer: 20
Thanks for the responses! I assume this is the right water pump seal?
http://www.ebay.com/itm/KAWASAKI-WAT...217110&vxp=mtr
86 KLR600 / Yamoto 50cc Quad / 2006 Loncin 110 Quad / 1985 LT250EF Quadrunner / 1979 XS650 Special / 1972 Kawasaki G3SS 90 / 1973 Aermacchi X90 / 1986 Honda 450 Rebel restored / 2003 HD Deuce Screaming Eagle / 1978 Honda 550 Four (K) / BAYOU 220 / 1985 BAHA 90 / 1987 KDX 80
BruceDeuce is offline   Reply With Quote
Old 02-13-2013, 09:11 PM   #5104
SkiBumBrian
DualSport Crazy !!
Oddometer: 1,051
They look right.... There are 2 seals, a mechanical seal and an oil seal. Be careful not to nick, scratch, or damage in any way the mating surfaces of the mech seal, lube the O ring, etc. Easy to do trying to remove seals. If no clear instructions with kit do not attempt without clear instructions or you could be doing it again very soon. You may need case gasket too...
Old 02-13-2013, 09:17 PM   #5105
BruceDeuce
BruceDeuce's Avatar
Oddometer: 20
Thanks Brian I appreciate your help. I just downloaded the manual for Tradebit and bought the seals. Cost 5 bucks. I will post back with what Im doing and results.
Old 02-13-2013, 09:28 PM   #5106
SkiBumBrian
DualSport Crazy !!
Oddometer: 1,051
Excellent! Glad you found a manual, it's kind of a touchy procedure..... I will be watching for your post. Good luck!
Old 02-13-2013, 09:47 PM   #5107
BruceDeuce
BruceDeuce's Avatar
Oddometer: 20
Brian, I was just reading up on adjusting the Valves. Ive adjusted valves in smaller engines by turning a bolt in the head.. It seems I have to re shim on the 600 in order to adjust space between the valve. Am reading that correctly? Sorry for all the questions!
Old 02-13-2013, 09:53 PM   #5108
SkiBumBrian
DualSport Crazy !!
Oddometer: 1,051
Yep. Valve lash gets tighter as the seats wear on a shim system. Pull your valve cover, measure your lash accurately and with a little math order shims to get you back on the loose side of spec. The existing shim should have a # stamped on the underside. If not you have to measure with a micrometer. Sounds tough, its not....
Old 02-13-2013, 10:03 PM   #5109
BruceDeuce
BruceDeuce's Avatar
Oddometer: 20
Thanks again Bro! I will keep you posted!!
Old 02-13-2013, 10:18 PM   #5110
BruceDeuce
BruceDeuce's Avatar
Oddometer: 20
I was looking at the pics of the water pump and there should be a drain plud in the bottom. I dont have a drain plug. Perhaps thats why theres water coming out? Looks like the last owner had this apart and didnt know what the hell he was doing.
Old 02-13-2013, 10:28 PM   #5111
SkiBumBrian
DualSport Crazy !!
Oddometer: 1,051
Bruce, I PMed you, check your messages...
Old 02-14-2013, 12:10 PM   #5112
KamikazeKLR
Shorty on the 650
KamikazeKLR's Avatar
Oddometer: 659
I'm in need of a new rear tire for my '02. Any suggestions?
- Mel
Long Way Back
Not all those who wander are lost
2002 Kawasaki KLR650 - Big Red
KamikazeKLR is offline   Reply With Quote
Old 02-14-2013, 12:11 PM   #5113
ADW
'tard bike restos
ADW's Avatar
Oddometer: 571
Originally Posted by Paratrout View Post
Thanks Stu. I'll check out the radiator shield.
Also check the plastic that the gauges sit in on the instrument panel. It sometimes buzzes on the metal bar just below it. Mine did.
08 KLR, 06 KLR w/Sputnik sidecar, 09 WR250R, 72 CB350F
ADW is offline   Reply With Quote
Old 02-14-2013, 02:34 PM   #5114
FlyingWWW
Oddometer: 18
Random drop in post.. I use to own an 07 and enjoyed it. Are the new bikes free from the problems of the old like the doo thing and oil consumption? Getting close to selling my sport bike and going back to dual sports.
FlyingWWW is offline   Reply With Quote
Old 02-14-2013, 03:04 PM   #5115
rhlrdr
Oddometer: 70
I love my Michelin T63's...
It would depend somewhat on what conditions you ride and whether you want a "knobby" type or more of a street oriented tires...
rhlrdr is offline   Reply With Quote
Times are GMT -7.   It's 01:57 PM.
