02-15-2013, 06:22 PM
#5131 | |
Luminous nut
Oddometer: 290
My current garage: -2004 Kawasaki KLR650, Rigid Dually LED lamps (DD) -1996 Jeep Grand Cherokee 5.2L V8 (Donor) -1989 Jeep Wrangler, stripped to the bone (Implant-ee) -A boatload of 80's 3 wheelers |
02-16-2013, 09:44 AM
#5132 |
Not so Gnarly
Oddometer: 3,980
First Ride Report
OK, I have been riding a long time and have made quite a few trips.
Stats- Minerva, Ohio to New Orleans and return via Mobile and Biloxi on a 2013 KLR 650. 2330 miles. 50.76 gallons of fuel costing $182.52. Approx $3.60 per gallon (mostly high test). Averaged 45.9 miles per gallon. Well, I thought I had been everywhere but the electric chair and had seen everything but the wind. Yeah, I've been to Ashtabula, Pascagoula, Casablanca and the Isle of Sri Lanka. I've been to Bangkok, Benin, Bugtusell, Singapore, Kuala Lumpur and Ulan Bator. Hell, I've even seen Afro- Nubian dwarf goats furiously, frantically and ferociously fornicating at YOUR county fair. Yes, I've seen a lot of crazy shit in my 53 1/2 years on this planet. But nothing compares to Marci Gras Day in New Orleans. Absolutely nuts. If you haven't been, you gotta go.
Doo Done |
02-16-2013, 11:47 AM
#5133 |
Oddometer: 47
Are they brand new or still 80%+ tread left? If so go for it. I love mine. They will wear faster on pavement, but for serious dirt riding you can't get much better. If your strictly a pavement goer I wouldnt recommend them. But for that price you can't really go wrong
Tanman
02-16-2013, 03:02 PM
#5134 |
Oddometer: 4
02-16-2013, 03:27 PM
#5135 |
DualSport Crazy !!
Oddometer: 839
Sorry, I don't think anybody wanted to ignore you....
The real oil burner was the 08 but others used a bit of oil at sustained high RPMs. Recall on some 08 VINs for ring issues, later years have been fixed. The doo was also redesigned, it is tougher now but sloppy on the shaft and the spring is worthless.... Go figure.
"Where ever you are, there you go..." |
02-16-2013, 04:29 PM
#5136 |
Gorilla Adventurer
Oddometer: 1,951
Gen I use oil at extended high rpms, Gen II use oil at extended high rpms.
All KLR's, all bikes have there own little issues and quirks you should work out. The internet makes every bike sound like crap when you dig in them and over-analyze everything. KLR's are still great bikes.
bikes |
02-16-2013, 05:10 PM
#5137 | |
I look lived in.....
Oddometer: 275
The massive Raider Nation is beyond doubt the sleaziest and rudest and most sinister mob of thugs and wackos ever assembled. Hunter S. Thompson Punk Rock Changed My Life- The Minutemen |
02-16-2013, 05:30 PM
#5138 |
Oddometer: 43
02-16-2013, 10:20 PM
#5139 |
Oddometer: 19
Wiring harness
So I'll try this again:
Anyone have any idea where the most common wear through points are on the Gen II wiring harnesses? I've had it replaced on recall but I would like to make double sure that I never have an issue. Thanks guys! |
02-17-2013, 12:00 AM
#5140 | |
Oddometer: 39
i did have a problem, after 10,000 hard miles, with my throttle (close) cable wearing through underneath the gas tank. it's definitely a good idea to remove the seat and tank and inspect for any wear. the factory cable management "system" is pretty poor.... |
02-17-2013, 01:16 AM
#5141 |
Oddometer: 787
Ride it some and look for the paint rubbed off frame like under the seat support with the hole in it.
and any where it crosses a edge http://lmgtfy.com/?q=kawasaki+wiring...ss+rub+through |
02-17-2013, 04:00 AM
#5142 | |
Old wanderer
Oddometer: 311
Good advice. Some spots are tough to use tape, so a suggestion is try sections of wire loom protective wrap...with some with luck and light cursing...you can slide it to the area you need.
02-17-2013, 06:08 AM
#5143 | |
Oddometer: 2,043
And any thing that moves, zip tie it down. Also remove the front fairing and do everything behind there. There is not much to the Klr, so it isnt to hard to go over the whole bike. |
02-17-2013, 07:11 AM
#5144 |
Oddometer: 340
There are six most common but my experience with early GenII's is better to strip the bike down and simply go over the entire thing. I've had a couple other rub points on several different GenII's. klr650.net has the six on a sticky for reference but again...strip it down and go through it yourself.
02-17-2013, 07:35 AM
#5145 |
Oddometer: 20
I guess you have to be part of the in crowd to get a response. To the best of my knowledge, sometimes the springs stretch, break and theres a problem. Most change them out for peace of mind.
86 KLR600 / Yamoto 50cc Quad / 2006 Loncin 110 Quad / 1985 LT250EF Quadrunner / 1979 XS650 Special / 1972 Kawasaki G3SS 90 / 1973 Aermacchi X90 / 1986 Honda 450 Rebel restored / 2003 HD Deuce Screaming Eagle / 1978 Honda 550 Four (K) / BAYOU 220 / 1985 BAHA 90 / 1987 KDX 80 |
