Old 02-25-2013, 05:07 PM   #5296
ThomasVolomitz
New Old Stock
ThomasVolomitz's Avatar
Oddometer: 4,394
Did a long trip and had to get the salt off mostly.
https://m.facebook.com/dualsportdelinquents
Still Riff Raff
ThomasVolomitz is offline   Reply With Quote
Old 02-25-2013, 05:27 PM   #5297
The Stew
Why not Zoidberg?
The Stew's Avatar
Oddometer: 50
I just lightly power wash mine when it gets bad.
2006 KLR650 Aztek Red / SW Motec Bars, Givi Top Case, Tank Bag, PMR Rear Luggage Guard, IMS Pro pegs, Mirror Relocation mod, Moose Folding Shift Lever, Gold Valve Cartridge Fork Emulators, T-Mod, Coleman Seat Cover, Tusk D-Flex Handguards, Horse Saddlebags, Drill Through Subframe Upgrade, 12.9 Bolts, Doohickey, 16TFS, AGM Battery, AeroLED Tail Light
The Stew is offline   Reply With Quote
Old 02-25-2013, 05:31 PM   #5298
ThomasVolomitz
New Old Stock
Oddometer: 4,394
I keep all my stuff clean like that, bad habit.
Still Riff Raff
Old 02-25-2013, 05:59 PM   #5299
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 7,836
Originally Posted by IDRIDR View Post
Question for ya. I have the rear wheel off my '06, trying to change bearings. The right (rotor) side spacer is stuck on there hard. This one isn't pressed into a bearing or anything, is it? Shouldn't it just lift off like the other spacers? Thanks.
Mine typically fall out via gravity. No, they aren't pressed. Should be a slip fit.
Here's hoping your bearings aren't that bad to cause the parts to seize/weld together.
"This place fucking runs on beer, you buy the right person a beer, and you get a job, a blow, a place to sleep, whatever.
You're hot, cold, thirsty, hungry... beer will fix that.
Beer is a god damn miracle, and don't you forget it!"
-DustyRags
DirtyDog is offline   Reply With Quote
Old 02-25-2013, 10:19 PM   #5300
IDRIDR
Take me to the River
IDRIDR's Avatar
Oddometer: 1,395
Thanks. We will see...
Sent from my C771
IDRIDR is online now   Reply With Quote
Old 02-26-2013, 06:49 AM   #5301
Danger4u2
'04KX500isDanger4u2
Danger4u2's Avatar
Oddometer: 625
Sounds like you ran it to long and it's welded in the bearing.
We have a friend that maintains his KLR when it breaks. I changed my rear bearings at 22,000 miles, did they need it? There was a little slop in the carrier bearing, I might have gotten another 5,000 miles out of it, for $17 dollars I changed all three of them for piece of mind. I took the old bearings to the local bearing shop and bought bearings that were twice the quality over stock, seals on both sides. This friend has run his bearings to failure. Personally I would have noticed something was wrong before the sprocket carrier cut part way thru the swingarm. He's the rider that changes one sprocket or just the chain. We all know they should be changed as a set. The crazy part is, he has the money, he's just cheap. He will squeeze a quarter until the eagle screams. I change parts/tires when I have used 70% of their life. The next crazy part is, he wants my used parts.
We rate our rides on how many parts fall off of his bike or how many times our other friend falls over on his KLR.
Go faster than everyone.
Only worry about what's in front of you.
Danger4u2 is offline   Reply With Quote
Old 02-26-2013, 07:40 AM   #5302
Kawidad
Kawidad's Avatar
Oddometer: 4,745
Try heating things up with a propane torch. Get it hot, but not too hot. I gauge it by touch, as soon as you can no longer touch it, then that should be enough, then try popping it out.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 02-26-2013, 08:41 AM   #5303
Aprilia
Oddometer: 666
Ditto...
Aprilia is offline   Reply With Quote
Old 02-27-2013, 07:29 AM   #5304
wapiti1001
Oddometer: 13
JNS Skidplate & Tool Tube
Has anyone attempted to mount a tool tube to the JNS Skidplate? Any success?
wapiti1001 is offline   Reply With Quote
Old 02-27-2013, 08:51 AM   #5305
GO_OUTSIDE!
dirty hippie
GO_OUTSIDE!'s Avatar
Oddometer: 292
Dropping voltage
I've noticed the voltage on my '04 KLR650 has been dropping from 14.8V to 12.5V over a 45 minute ride to work with heated vest and grips running. Initially turning off the grips will bring the voltage back up but by the time I get to work it wont. I have changed all the lights except the headlamp to LED, and the battery is a 1.5 year old AGM. Ive been running this setup for about a year without any trouble until one particularly cold day last week when I turned on the grips while wearing heated glove liners because one liner wouldnt heat up on my way to work. I dont know if I overloaded the charging system.
I've had charging systems quit on me but never work at the beginning of a ride and slowly run out of power.
Any Idea where I should start looking?
Thank you!
Now Go Outside!
GO_OUTSIDE! is offline   Reply With Quote
Old 02-27-2013, 12:20 PM   #5306
bush pilot
bush pilot's Avatar
Oddometer: 2,536
That's not much fluctuation. I'd consider that normal. I consider anything better than 12volts good.
Mine was going from 9v to 13. And occasionally cranky about starting, then quit altogether. Turned out to be a loose battery ground connection. That would be the first place to check.
KLR's are not fussy machines. Just keep them lubed and locktited.
USA travels 09'
Anchorage to Ushuaia
RTW...part: Europe
Iron Butt #35784
bush pilot is offline   Reply With Quote
Old 02-27-2013, 12:34 PM   #5307
MacNoob
MacNoob's Avatar
Oddometer: 1,583
If you're reading anything below about 13.5V at the battery with the engine running, you're not charging and will surely end up with a dead battery if that low-voltage continues long enough.
I would consider a bad voltage regulator that dies when it gets hot.
"Ignorance, you see, can be out thought. Arrogance can be outmaneuvered. But ignorance and arrogance combined are unassailable."
82 Honda C70, 71 Honda CL175, 08 Kawasaki KLR650, 85 Honda GL1200 Goldwing
MacNoob is offline   Reply With Quote
Old 02-27-2013, 12:40 PM   #5308
JBradley500
Oddometer: 54
I got these in a box of parts with my bike... what are they? I thought they look liked bar-end weights or mirror mounts but have no real idea.
JBradley500 is offline   Reply With Quote
Old 02-27-2013, 12:42 PM   #5309
Grinnin
Forever N00b
Oddometer: 2,623
Mirror vibration reducers.
Motorcycles are magical.
Grinnin is offline   Reply With Quote
Old 02-27-2013, 12:47 PM   #5310
JBradley500
Oddometer: 54
Thanks for the quick reply.
Here's a couple of pictures of last nights easy project. I got a little blood on the old rotor
Times are GMT -7.   It's 10:04 PM.
