Old 03-01-2013, 08:17 AM   #5341
East Coast Rider
Just Me...
East Coast Rider's Avatar
Oddometer: 4,029
Cool. Gonna be running lots of potentially deep gravel along the Trans Taiga road. Need something that is gonna last about 4500 miles total.
Txt msg with Dan right after he was paralyzed:
Me: Hey Dan-O. Just wanted to say howdy and Love ya!
Dan: Howdy and Love you too. Doin' good and feeling good.
Me: Give 'em hell, little Bro!
Dan: Roger that.
East Coast Rider is offline   Reply With Quote
Old 03-01-2013, 09:56 AM   #5342
Grinnin
Forever N00b
Oddometer: 2,945
Originally Posted by GO_OUTSIDE! View Post
and i need a new gas tank? . . .
So what your saying is the battery is at full charge when I leave the house but the charging system is not keeping up with demand and the battery is slowly loosing charge thus the voltage is dropping. So I need to look into what happened to my charging system that reduced its capacity to charge? This weekend Ill start the bike and measure current output from the rectifier vs total current consumption.
You need a new gas tank AND gas without ethanol.
You can measure the resistance on the 3 yellow wires coming from the stator to almost-conclusively show if you have a short or a break. You ought to be able to test for bad diodes in the Rec/Reg, but I haven't had to test a combined unit, only separate rectifiers.
If you have a spare shunt and analog A meter laying around, you can measure the battery current out and current in for a real-world test.
"The belief that there is only one truth, and that oneself is in possession of it, is the root of all evil in the world."-- Max Born, Nobel Physicist
Grinnin is offline   Reply With Quote
Old 03-01-2013, 12:02 PM   #5343
Barney
I reckon so
Barney's Avatar
Oddometer: 918
Originally Posted by XpressCS View Post
What's the front fender you have Xpress?
Barney is online now   Reply With Quote
Old 03-01-2013, 02:16 PM   #5344
Rode2Nowhere
Rode2Nowhere's Avatar
Oddometer: 2,221
... and how 'bout a shot of your aux lights while you're at it. Where they're mounted, etc.
- Jonathan
'88/'96/'08/'09 KLR650 Amalgamation
IBA #45896
Adirondack Tags
Rode2Nowhere is offline   Reply With Quote
Old 03-01-2013, 04:36 PM   #5345
L-ucky-S-ix
Dadgum'd
Oddometer: 361
I have been posting random things for quite some time, so here is another!
After researching parts fiche's online I came to the conclusion that the sub-frame (subframe for search purposes) from a 2011 KLR would fit my 1990 Tengai.
So I bought one. Cheap.
Everything bolted up just fine except for the mounts for the muffler. The muffler isn't clamped down so it's hanging low, this doesn't show that it's way off and not close to the mounting holes just that it's hanging.
Apparently, the bolts for the 2011 are much nicer. This is something I didn't know they changed. Color me dumb for not knowing about the stronger bolts but I used the old ones for now. That is until I can upgrade.
I did this so I could get a pannier rack without having to modify it. The Tengai's passenger foot pegs are not connected to the subframe and normal rack systems attach to the passenger foot peg mounts on normal KLR's. (Also, it's nice to know the condition of my subframe is 21 years newer.)
Tengai foot peg mount... (Not my Tengai)
And a normal klr foot peg mount... (Not my KLR)
L-ucky-S-ix screwed with this post 03-01-2013 at 04:42 PM
L-ucky-S-ix is offline   Reply With Quote
Old 03-01-2013, 06:53 PM   #5346
XpressCS
Must. Have. Lumens..
XpressCS's Avatar
Oddometer: 1,356
As a PSA to all of my KLR friends:
HID lamps are too fragile to function properly. The electrode in the tip of them breaks from the vibrations coming from normal riding. I've gone through 3 bulbs in the past 2 months, so going back down to a Sylvania bulb. Having to ride home with your blindingly bright LED spotlamps not only annoys every driver on the road, but it doesn't spread wide enough.
Will eventually upgrade to a TruckLite HID lamp, if it will fit. Or some other type of HID lamp, anything to avoid Halogen.
Acerbis Black for a 2006 KX450F:
http://www.motorcycle-superstore.com...50F-Parts.aspx
Hacked up the fairing a bit to fit the lights, I bolted them to the factory turn signal mounts, then just moved the turn signals back. Bolted them to the fender. I figured they don't need such a heavy duty mount.
2015 Yamaha FJ-09
XpressCS is offline   Reply With Quote
Old 03-01-2013, 11:58 PM   #5347
XDragRacer
Oddometer: 3,302
May not avoid the dread HALOGEN, but . . . the TPI headlight bulb for Generation 1 KLR's turns "night into day," in comparison with the OEM lighting.
From the vendor's website (Disclaimer: no financial interest):
http://www.tpimotorcycleparts.com/in...category_id=45 ):
For maximum output use our TPI Heavy Duty Wiring Harness . Bulb fits up to 07 KLR and all years DR.
Now issued by Canadian government on their Yukon utility vehicles! The new heavy duty vibration resistant IPF Bulb is 80wt draw at low beam and 60wt draw at high beam. Wait, that's backwards! Read further....bulb has super white low beam that equals 190wt optical output. How many times has your low beam been too dim? Does this mean low bean will blind on coming traffic, No. Remember your low and high beams have different shapes on the road. Your high beam is 150wt optical output for long distance, much brighter than stock, but the low beam has a super white 190wt optical output low and wide on the road. Big safety factor here! Believe me, the older you get the more you need this new bulb.
XDragRacer is offline   Reply With Quote
Old 03-02-2013, 04:07 AM   #5348
Tsotsie
Semi-reformed Tsotsi
Oddometer: 1,952
Really?
I have used an HID on an 08 for 30k without any issues. The bulb does have to be spaced if you want the correct spread.
Sylvania - false advertising scam! Read their info on the package - claim 30% more light against a normal bulb at 80%! Then, check the life expectancy - 1/3 of a standard bulb all at 3X the price! Dont be fooled by the 'color' difference.
Tsotsie is offline   Reply With Quote
Old 03-02-2013, 05:31 AM   #5349
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,646
XpressCs- what brand Hid are you using ?
Something isn't right because tons of riders are using them without problems, including my riding friends and myself.
You better look into it more, before discounting Hids.
ST1300 - IRON BUTT # 23,716
GAS GUY is offline   Reply With Quote
Old 03-02-2013, 06:50 AM   #5350
mxboy96
mxboy96's Avatar
Oddometer: 65
All hale the thermobob!
hey hooligans. Just thought I'd give my two cents about the Thermobob mod from watt-man.com. Just got her installed last night and must say I'm quite impressed. For those of you who don't know of it, It's a cooling system modification that bumps up the running temp to the optimal internal combustion engine temp of 195 rather than 160 and warms up the bike 5x faster, thanks to the bypass hose that will go directly from the upper to lower hose, bypassing the radiator until the engine is warmed up. I only drove downtown(two blocks) and back and it was warmed up already! With the stock system I'd have to get 4 miles out of town before it would be warmed up! It also keeps the coolant temp consistant throughout rather than relying on bursts of cold coolant from the radiator to keep it cool, thus keeping a steady needle/coolant temp. They claim that this will virtually eliminate the common 'high mileage' out of round cylinder problem due to inconsistant coolant temp entering the cylinder, and increase the longivity of the engine and oil in general. As they claim, it's not really an add on so much as it is a neccesity! Ride on;)
Tanman
mxboy96 is offline   Reply With Quote
Old 03-02-2013, 06:57 AM   #5351
XpressCS
XpressCS's Avatar
Oddometer: 1,356
I am aware, I knowingly bought the Silverstar with this info.
I used a few different brands. One was an expensive automotive kit from an unknown source (got it from a buddy for doing some favors, brand new in box), one was from DDM Tuning, and the 3rd was an eBay cheapie.
Rather not fuss with it, each bulb burnt out from the electrode breaking. And I use HID on all of my other bikes as well (2 and 4 stroke).
2015 Yamaha FJ-09
Old 03-02-2013, 09:30 AM   #5352
Tsotsie
Oddometer: 1,952
I am not sure who the they are? Wattman certainly does not make those claims. There are certain sites where hen-party gossip becomes tribal 'knowledge' and is then deemed as fact.
It certainly does what it is supposed too. I am a happy customer - got one the 1st made and installed it in Dec 07. 40+ K miles later it works as advertised.
Old 03-02-2013, 12:44 PM   #5353
IDRIDR
Take me to the River
IDRIDR's Avatar
Oddometer: 1,556
[/B]
plan to install mine this weekend. Looking forward to seeing at night!!
Sent from my C771
IDRIDR is offline   Reply With Quote
Old 03-02-2013, 02:40 PM   #5354
XpressCS
XpressCS's Avatar
Oddometer: 1,356
Sent from my C771
Let me know how it works for you. If it's as bright as it claims to be then I may just grab one.
2015 Yamaha FJ-09
Old 03-02-2013, 03:35 PM   #5355
SkiBumBrian
DualSport Crazy !!
SkiBumBrian's Avatar
Oddometer: 1,051
Originally Posted by SkiBumBrian View Post
Well, Since I got the IMS tank, I was immediately unsatisfied with the less than perfect welds, molding, imperfections, etc. I liked the idea of the extra fuel and the protection it provided for the the radiator but it was UGLY!
All the info was, "Nope, can't paint an IMS tank, paint won't stick, stickers won't even stick." Wasn't sure why so I did some research. Most plastic tanks "breathe" hydrocarbons that don't allow for painting and such. OK, how about sealing the tank. Lots of sealers out there but they all say won't work with Polyethylene, Hmm. What is the IMS tank made of anyway? Yep. Polyethylene. XLPE, to be exact, cross linked polyethylene. Caswell has a nice looking 2 part epoxy sealer, oops. Won't stick to Polyethylene.
I finally came across a sealer that the manufacturer wasn't sue if it would work or not but thought it would. I found some blogs that some guys had used it and it worked great but I didn't know if their tanks were XLPE.
Long story short (too late) I ordered some and after a lengthy prep process I sloshed it around and let it cure. Seems to have dried to a flexible, strong bond, time will tell.
IMS tank is not ugly anymore! I have a bit of wet sanding the clear and some polishing to do but that is going to wait a month or so to see if she holds up.
Update on the paint. It's been a few weeks and it is pretty obvious the sealer works. It was also obvious fairly early that the Krylon paint was a bit "soft" and even though I had sanded the tank well before I painted it (Krylon says "No need for primer") it was fairly easy to mar the paint, get down to the base and actually peel the paint from the tank..... Eh, start over! I took the tank off and wondered why the paint never adhered well. After getting all the paint off the tank (and checking out the sealer on the inside.... looked fine)I realized that my scuff sanding just scuffed the gel layer or whatever they use to mold these things, did only that. Scuffed a coat of gel that has no good adhering qualities. So I took a DA sander and took that whole coating off and bought a high quality primer and hit the tank and let it cure. This primer was sticking well... So I shot it with a full coat and let it dry to a sandable state and hit it with some 800 grit, then another coat. I finally got a good bonding surface and some good primer to adhere to. Anyway, There the tank sits with 4 coats of primer on it, waiting for 48 hrs. to cure totally and I am now going to use automotive enamel instead of Krylon. I don't foresee anymore issues and I will post the new pics in a few days after the tank is back on. Hopefully anyone going this route can use my mistakes as a "don't do it like this..."
"Where ever you are, there you go..."
SkiBumBrian is offline   Reply With Quote
Times are GMT -7.   It's 10:02 PM.
