Old 03-04-2013, 12:12 PM   #5401
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 13,106
Thankee, Flesh -- perfectly clear!
I appreciate the backup greatly!
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance.” T.R.
Old 03-04-2013, 02:51 PM   #5402
schaffer40
I look lived in.....
schaffer40's Avatar
Oddometer: 408
@sub5pac3
The 2nd picture is how it goes together. I was way over thinking it. It just did not look right to me at the time, or now honestly.
The massive Raider Nation is beyond doubt the sleaziest and rudest and most sinister mob of thugs and wackos ever assembled. Hunter S. Thompson
Punk Rock Changed My Life- The Minutemen
schaffer40 is offline   Reply With Quote
Old 03-04-2013, 03:59 PM   #5403
Aprilia
Oddometer: 722
Originally Posted by GO_OUTSIDE! View Post
In the interim looking at your voltage while the bike is cranking (before it starts) will give you some idea. If your voltage stays above 11 volts at the battery and you still have slow cranking I would look further down the line.
Thats a good test however many digital meter's won't react fast enough. Good ole analog works very well! Also, I've found the KLR starter will actually pull total voltage down closer to low 10vdc even with a good battery. A backyard mechanic load test would be to simply leave your key on for 3-4 min then test voltage. Depending on battery chemistry/type (Wet, Gel, LiFePo) acceptable voltages will vary but its pretty easy to determine the overall state of the battery as well. Example: A 50% discharge would be 12.1 for wet cell and 12.5 for maint free types.
Aprilia is offline   Reply With Quote
Old 03-04-2013, 08:59 PM   #5404
DesertDuster
Old Pueblo Rider
DesertDuster's Avatar
Oddometer: 193
Originally Posted by desertmedic View Post
Greetings,
After much research I decided to trade in my Victory Vegas for an adventure bike. I chose a 2013 KLR 650 in yellow :)
My back ground is desert racing so I was bound to get rid of the Victory at some point to get back to the dirt. I have riden my KLR 100 miles now and i love it, though i have bottomed the rear shock out a few too many times (I'm 240 6'1). Hope to begin the modifications or as It's put here to farkle and plan some trips, my goal is to ride to alaska next year.
Thank you guys for all the great info on this site.
A couple of things to do that are free:
Check the preload and rebound. The preload adjustment is a 12mm bolt near the top on the left side of the shock. It may be behind a small black vacuum canister. The factory adjustment is set on one which is for a 160 pound rider. Set it at around three or four for starters. Any heavier load, adjust it up a notch. The bolt only turns clockwise and after reaching position five it will pop and go back to position one. The rebound is a small screw on the bottom of the shock on the right side. It should be set at ½ turn counter-clockwise. The more clockwise the screw is turn the quicker the rebound, which will keep the rear shock ready for the next bump.
DesertDuster is offline   Reply With Quote
Old 03-04-2013, 09:06 PM   #5405
XpressCS
Must. Have. Lumens..
XpressCS's Avatar
Oddometer: 1,259
I would up putting the Sylvania bulb back into my KLR today. Hooked it up to low beam this time, rather than high beam. Noticed the cutoff is sharp like I like it, and there is an even distribution of light in the playing field. So maybe the light isn't all that bad from this bulb.
Will have to adventure into hooking up the high beam as well to get even more light output
2004 KLR650
My KLR is my therapy session. My quiet time. My deep tissue massage. Me without my KLR is reason enough to be deeply concerned. It is what calms me the most. Soothes my mind. Eases my stress. -Me
XpressCS is offline   Reply With Quote
Old 03-04-2013, 10:01 PM   #5406
Danger4u2
'04KX500isDanger4u2
Danger4u2's Avatar
Oddometer: 643
I noticed I had a little more vibration than the normal buzz. I never changed my doo and thought maybe the vibes could be doo related. The bad part of this is, I bought a doo from Eagle Mike back in 2007 and never stopped riding to install it.
As for the buzz, I could put my foot on the Happy Trails forward foot peg and some of the buzz would go away. Put the bike up on the lift and found this. Part of the mystery solved.
I decided to make my own flywheel wrench, picked up an old school, 1¼" Proto open/box end wrench at Mary's Swap Meet for $5 bucks.
Now as far as which way to bend the wrench for holding the flywheel it doesn't matter unless you plan on using the wrench for something else, other than just a KLR flywheel wrench. Bend it with the off set of the box end and the open end will be up like this. If you bend it the other way the box end won't sit flat around the head of a bolt.
I greased up the Eagle Mike flywheel puller.
Turned to set the tub of grease on the table behind me and heard a pop. I didn't need the puller, turned around to find this.
The wrench held it from hitting the floor.
Removed the flywheel and ...........................
Now I'm on a fishing trip.
I poked and poked with the 2 magnets, no luck finding the chunk of doo. Nothing on the drain bolt magnet. I'll give it another try in the morning. No telling how long it's been like this. I'm at 23,851 miles. 2007 bike. First time I've opened up a KLR engine.
1. If I don't find it should I button it up and hope for the best?
2. Should I pull the clutch side case and check that little screen?
3. With the clutch side off, is there access to the sump with my fishing magnets?
4. The broken part has a little bit of weight to it, is there enough oil flow to lift it into the screen?
I would be very appreciative of any suggestions.
Go faster than everyone.
Only worry about what's in front of you.
Danger4u2 is online now   Reply With Quote
Old 03-05-2013, 02:54 AM   #5407
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,390
Actually, the more clockwise (closed) the adjuster is turned, the harder and slower the rebound will be due to more hydraulic resistance working against the spring that is trying to return the tire from compression.
And the more counterclockwise (open) will be softer and faster due to less hydraulic resistance to the spring, to the point if you go to far open the rear end can feel like a pogo.
2008 KLR 705-2004 ST1300-2001 FZ1
2001 GAS GAS 321
IBA # 23,716
http://gasguysadventures.blogspot.com/
GAS GUY is offline   Reply With Quote
Old 03-05-2013, 03:07 AM   #5408
PWRCRZR
Grumpy Old Bastard
PWRCRZR's Avatar
Oddometer: 7,585
Try contacting Eagle Mike directly, he walked a local friend through the procedure of where to look for the missing part. You will need a flexible magnet I am told...Good Luck
However, I am not complaining because I know that I am probably better today then I will be tomorrow, so I try and enjoy every day as it comes, and stay determined to live well and be appreciative of what I still can do..."Stromsurfer"
PWRCRZR is offline   Reply With Quote
Old 03-05-2013, 05:21 AM   #5409
Danger4u2
'04KX500isDanger4u2
Danger4u2's Avatar
Oddometer: 643
Thanks, go to the experts. Duh, I should have thought of that.
Looks like a trip to Harbor Freight for a flexible magnetic fishing tool.
Old 03-05-2013, 05:27 AM   #5410
Aprilia
Oddometer: 722
WARNING The pictures above are photoshopped. Another exploitation of the internet broken Doo myth....
You'll find it. I've fished successfully 4-5 myself.
Old 03-05-2013, 05:33 AM   #5411
Unstable Rider
Fart and run
Unstable Rider's Avatar
Oddometer: 2,494
Hey Danger,
Great pics and verbiage you posted collectively above.
Just sayin. I am in agreement, it's a valid problem and replacement is a good idea.
My '09 really smoothed out and runs great with a new doo and the torsion spring. One of my riding chums has broke a couple of the non-torsion springs... couple of E. Mikes conventional springs too.... go torsion spring if you can people.
-“Ah, you're wasting you're time. They can't track us over rocks.
Tell them that.......... --Who are those guys?”
~Butch Cassidy
Unstable Rider is offline   Reply With Quote
Old 03-05-2013, 07:33 AM   #5412
bomber60015
Oddometer: 13,106
Nuther Question -- Coolant Reservoir Guard -- Necessary?
In the process of buttoning up my gen 1 KLR, and got the cooling system full, burped, full agian, re-burped . . . . . .
and it occured to me, again, that, once the IMS tank is back on the bike, there will be no way whatsoever to add coolant, if neceesary.
Is there a reason I shouldn't trim the reservoir guard to I can reach the cap without field-stripping the bike?
thanks!
Old 03-05-2013, 07:45 AM   #5413
fleshpiston
fleshpiston's Avatar
Oddometer: 599
thanks!
Just 2 bolts and the plastic "guard" comes right off
SRX600
SRX250
SR500
KLR650
fleshpiston is offline   Reply With Quote
Old 03-05-2013, 08:12 AM   #5414
bomber60015
Oddometer: 13,106
Very true -- they are extremly tough to reach, with the IMS tank . . . .
Old 03-05-2013, 09:20 AM   #5415
Brunssd
Potemkin villager
Brunssd's Avatar
Oddometer: 362
Greetings,
I don't know if you've sorted this yet but the best modification (handling-wise) that I made to my KLR is a new rear spring from TopGun. Better than Progressive fork springs, better than a fork brace, better than a low mudguard. I used the white one, YMMV.
“Those who do not move, do not notice their chains” - Rosa Luxemburg
Brunssd screwed with this post 03-05-2013 at 09:27 AM
Brunssd is offline   Reply With Quote
Times are GMT -7.   It's 03:33 PM.
