Old 03-13-2013, 07:13 PM   #5506
KustomizingKid
Oddometer: 679
I got a big box of parts from Eagle Mike today
Then I went and dropped my carb off after work to get ultra sonically cleaned, because it was NASTY. Gonna be a busy weekend of wrenching
2000 Xr650r!
KustomizingKid is offline   Reply With Quote
Old 03-13-2013, 07:25 PM   #5507
dmottv
Take the Long Way Home
dmottv's Avatar
Oddometer: 415
Originally Posted by Rode2Nowhere View Post
Cool.
How is it at... say... 80mph?
I used to have a Madstad on my '08 ...... Wonderful screen. I'm all but decided that there's no substitute.......
Yeah, I agree with you there! Britannia Composites is worth a look for the KLR-A, I think that's what the original "Wheatwacker" eventually went with. I don't run the KLR long distances on the highway very often. We did run up the Gaspe from Cambellton, NB to Perce, QC 150 +/- miles at about 70 or so, the windshield worked well.
Dave - NH Seacoast; RT-NH1; AMA; MVTR; NETRA;
'07 KLR650; '02 R1150RT-P; '01 R12C Montana; '00 KDX200;
Gone: '05 450EXC; '99 K12LTC; '94 KDX250; '92 R100GS; '77 R75/7; a few others...
dmottv screwed with this post 03-13-2013 at 07:30 PM Reason: spelling edit!
dmottv is offline   Reply With Quote
Old 03-13-2013, 07:29 PM   #5508
SkiBumBrian
DualSport Crazy !!
SkiBumBrian's Avatar
Oddometer: 1,048
you're really going through your bike!!! Post some pics....
"Where ever you are, there you go..."
SkiBumBrian is offline   Reply With Quote
Old 03-14-2013, 06:25 AM   #5509
GO_OUTSIDE!
dirty hippie
GO_OUTSIDE!'s Avatar
Oddometer: 293
Originally Posted by Grinnin View Post
KLX needle, 140 main jet, stock exhaust, L-mod airbox w/Hi-flo Filtro foam, 16t countersprocket, no windshield (which tempers my top speed), Kenda 761 tires, Pelican storm boxes extend to 33" total width, mongo top box.
Here are MPG figures at each fill-up for two different trips of 2,106 and 2,136 miles. Each of these groups starts and ends on slower Maine roads. The middle of each trip includes some of I-80, I-76, and I-71 to Central Ohio. These are calculated from the odometer so actual mileage will be about a half-percent lower.
53.42MPG
53.51
51.41
52.70
52.51
47.79
50.16
55.26
54.79
51.96
56.95
53.00
53.66
56.48
54.04
48.57
48.62
47.68
55.83
54.34
54.75
(Yea, I keep spreadsheets of my gas receipts. Waddaya mean Amal retentive? I don't have a Brit bike.)
Boogers. I really dont want to go back into the carb to change the main jet again. Luckily I ordered a 140 main when I got my 142.5.
Thank you!
Now Go Outside!
GO_OUTSIDE! is offline   Reply With Quote
Old 03-15-2013, 01:32 AM   #5510
Dirtnrocks
Oddometer: 43
Inflation sucks
Picked up an 07 KLR a few weeks ago. I just did the 22 mod and it cost me 30!
Dirtnrocks is offline   Reply With Quote
Old 03-15-2013, 01:34 AM   #5511
SkiBumBrian
DualSport Crazy !!
Oddometer: 1,048
Inflation.
Old 03-15-2013, 04:55 AM   #5512
Murphy Slaw
Murphy Slaw's Avatar
Oddometer: 1,524
Bwahahahahahahaa.
The Murph Channel
Acoustic Originals and some Double Aught
http://www.youtube.com/channel/UCkomGsMJXH9qn-xLKCv4WOg
Murphy Slaw is offline   Reply With Quote
Old 03-15-2013, 10:20 AM   #5513
faller
Oddometer: 3
Free HP
Anyone have any info on an Eagle Mike cheap HP and Torque mod by advancing the exhaust cam 1 tooth? There is a dyno sheet on one of the other forums. Any KLR riders try this mod?
faller is offline   Reply With Quote
Old 03-15-2013, 10:33 AM   #5514
SkiBumBrian
DualSport Crazy !!
Oddometer: 1,048
Many have done it and it is that simple, advance exhaust cam 1 tooth. Have heard of no drawbacks of the"MC" mod but I know the 2 Mikes are still working on finding what degree advance is actually the best. Possibly an adjustable cam gear is in order..
Old 03-15-2013, 11:40 AM   #5515
Hessian42
Hessian42's Avatar
Oddometer: 169
Doing the valves on my klr and need to get some valve shims ASAP. hoping to find them today locally in L.A. needing 3x 2.50 and 1x 2.45
hoping someone local can point me in the right direction
It's just a ride...
http://hessianforpatagonia.blogspot.com/
Hessian42 is offline   Reply With Quote
Old 03-15-2013, 01:38 PM   #5516
road_apple
Hit the Trail
road_apple's Avatar
Oddometer: 147
valve shims
BMW shop. Older Beamers use the same 29.5 shims. Take one to show the parts guy because he won't believe you and they are cheaper than at the BigK shop.
road_apple is offline   Reply With Quote
Old 03-15-2013, 02:06 PM   #5517
KustomizingKid
Oddometer: 679
Just picked my carb up from getting ultrasonicly cleaned... Man does it look nice
Now I just have to put in my KlX needle and I will be ready to rock. I will try and post up some pictures after my weekend wrench efforts are complete.
2000 Xr650r!
Old 03-15-2013, 02:25 PM   #5518
Danger4u2
'04KX500isDanger4u2
Danger4u2's Avatar
Oddometer: 625
Before I finished the doo replacement I found that the adjuster was hammering the inside of the case. With a broken doo and a spring that was to long it was just flopping around as I drove. I cleaned it up with a file but I don't think it created any problems.
On the net there are several links/video's of where to drill the torsion spring retaining hole that DON'T sync with what Eagle Mike (E.M.) says. I drilled just left of 6 o'clock like it says on the E.M. packaging.
I was concerned that the hook end of the torsion spring did not lay flat on the doo. Starter gear clears the spring so no problem. As I went back together I installed the stainless steel allen head cap screw engine set I bought back in '07 when I bought my doo parts.
There's no real way to tell how long I was driving with the doo problem before total failure. Fixing the doo and welding the broken tab on my crash bars took away 70% of the buzz I felt in the handlebars. Don't wait around like I did, change your doo now. For sure on the Gen. 1 bikes. My bike is quite again, you only hear the exhaust and it's stock without the whistle.
Go faster than everyone.
Only worry about what's in front of you.
Danger4u2 is offline   Reply With Quote
Old 03-15-2013, 06:13 PM   #5519
KustomizingKid
Oddometer: 679
Carb has been reassembled and looks freaking awesome!!!
2000 Xr650r!
Old 03-15-2013, 06:30 PM   #5520
SkiBumBrian
DualSport Crazy !!
Oddometer: 1,048
Fire it up!!!!!
Times are GMT -7.   It's 07:54 PM.
