Old 04-09-2013, 07:22 AM   #5851
Rode2Nowhere
Rode2Nowhere's Avatar
Oddometer: 2,221
Originally Posted by Mark_S View Post
replaced slightly worn cush drive bearing and discovered new bearing is a loose fit - somehow the bearing seat is damaged (never had a destroyed hub bearing)
I wonder about this as well. Seems to me it should be snug like the wheel bearings.
Check out my video a few pages back... is it as bad as that? I figured mine was due to heat distortion from riding with a bad bearing. I can't believe that its normal.
But I suppose maybe. Anyone?
- Jonathan
'88/'96/'08/'09 KLR650 Amalgamation
IBA #45896
Adirondack Tags
Rode2Nowhere is offline   Reply With Quote
Old 04-09-2013, 10:49 AM   #5852
BigWrench
BigWrench's Avatar
Oddometer: 135
Hub bearing
I wiped out my own sprocket hub bearing when I adjusted my KLR chain as if it was a CB750. This resulted in a chain way too tight (especially upon a hard landing), it wiped out the chain and bearing but I stopped before it was able to spin in the hub, my hub was still ok. You will likely have to replace or repair that sprocket hub. Also, the KLR chain should seem LOOSE when it is right.
God bless and best regards, BigWrench
God bless and best regards, Ken
BigWrench is offline   Reply With Quote
Old 04-09-2013, 03:56 PM   #5853
rodmuzwa
rodmuzwa's Avatar
Oddometer: 174
Hi all, just a quickie, my new KLR is just about run in and due it's 1k service. I really want to get it de-restricted. Can anyone tell me how to do it or am I better getting the dealer to do it at first service? Thanks.
Living the dream, everyday!
rodmuzwa is offline   Reply With Quote
Old 04-09-2013, 04:52 PM   #5854
8lives
Dharma Bum
8lives's Avatar
Oddometer: 2,022
spring in Nor Cal
What would you do if you weren't afraid?
Bobcat Goldthwait is my mentor.
8lives is offline   Reply With Quote
Old 04-09-2013, 04:54 PM   #5855
8lives
Dharma Bum
8lives's Avatar
Oddometer: 2,022
As opposed to winter in trinity County
Old 04-10-2013, 04:56 AM   #5856
Tsotsie
Semi-reformed Tsotsi
Oddometer: 1,949
Are no Aussie friends going to chip in here?
If no response here, I do recall seeing comments a few years back on one of the other KLR specific sites.
Tsotsie is offline   Reply With Quote
Old 04-10-2013, 05:05 AM   #5857
Rode2Nowhere
Oddometer: 2,221
What do we mean by "de-restricted"... airbox modification? Exhaust modification? Carb mods?
Tons of info over on KLRWorld.com
- Jonathan
IBA #45896
Adirondack Tags
Old 04-10-2013, 05:17 AM   #5858
Tsotsie
Oddometer: 1,949
The Australian delivered KLRs have a government directed restriction installed onto the bikes/carb. This severely limits the power. It (like the EPA controls placed on ours here in the USA, which does not affect the performance) can be removed.
I have an 08 works manual at home that I recall has the Aussie limiter illustrated. I will review it when I get home from work.
Old 04-10-2013, 05:49 AM   #5859
Rode2Nowhere
Oddometer: 2,221
Aha! Gotcha.
- Jonathan
IBA #45896
Adirondack Tags
Old 04-10-2013, 09:29 AM   #5860
Kent Glasscock
Kent Glasscock's Avatar
Oddometer: 170
Hey guys. I want to get the Trail Tech Digital Stryker Gauge for my 2012 KLR. Does anyone have this device on their KLR? And if you do, how did you mount it? Also any opinions if it's a good device or not will be helpul also. I have some ideas on mounting it wanted to double check before I spend the bucks on this device and the associated parts. Thanks!
Kent Glasscock is offline   Reply With Quote
Old 04-10-2013, 10:08 AM   #5861
06ltd
06ltd's Avatar
Oddometer: 148
I have a Vapor on my '08 and I love it. Mine is just mounted to the bars with the included clamp and bracket but there are more than a few people who have gone with a complete dash remodel. The battery will only last about a year or so but it's very easy to replace. Mine's been beat pretty hard and it's still in great shape.
'08 KLR 705
'14 Panigale S
06ltd is offline   Reply With Quote
Old 04-10-2013, 10:12 AM   #5862
KamikazeKLR
Shorty on the 650
KamikazeKLR's Avatar
Oddometer: 685
Random question.. the speedo doesn't work on my boyfriend's 2000. I have noooo idea where to look first.
What should I do?
- Mel
Long Way Back
Not all those who wander are lost
2002 Kawasaki KLR650 - Big Red
KamikazeKLR is offline   Reply With Quote
Old 04-10-2013, 10:33 AM   #5863
Rode2Nowhere
Oddometer: 2,221
What should I do?
Pull the cable off both the speedo and wheel hub. You may need a bit of help from some lightly-applied pliers. I'll bet you'll find one of the cable tips broken off. Hopefully its that and not the speedo unit itself.
- Jonathan
IBA #45896
Adirondack Tags
Old 04-10-2013, 10:38 AM   #5864
SkiBumBrian
DualSport Crazy !!
SkiBumBrian's Avatar
Oddometer: 1,051
+1. At the hub most likely......
"Where ever you are, there you go..."
SkiBumBrian is offline   Reply With Quote
Old 04-10-2013, 10:43 AM   #5865
KamikazeKLR
Shorty on the 650
Oddometer: 685
ok! thanks guys.
- Mel
Long Way Back
Times are GMT -7.   It's 01:59 AM.
