Old 04-18-2013, 12:12 AM   #5941
MtnRider2
MtnRider2's Avatar
Oddometer: 142
Yes beautiful Northern CA weather and a nice ride for me today.....until I tipped over twice!!!!! Fortunately I was in the dirt and not going too fast but still ugh. On the ride home my temp was far higher than normal. Note both drops were on the right side. Haven't torn it apart yet but any suggests as to what possibly could have happend?
MtnRider2 is offline   Reply With Quote
Old 04-18-2013, 01:44 AM   #5942
Grinnin
Forever N00b
Oddometer: 2,843
Originally Posted by Diggerled View Post
Is there a trick to breaking loose the seized bolts that hold the heat shield onto the exhaust pipe?.
I use lots of time, a generous helping of PB blaster, and an impact driver (the hammer-and-driver kind). I've only taken the shields off during Maine winters though, so I have 2 or 3 days to let the BP work.
If you move on to the swingarm bolt and shock linkage it took me over 2 weeks of BP and other penetrants. It was absolutely immobile until it came out easily. I'd say take a look first time you have time -- these don't come from the factory with much grease.
"The belief that there is only one truth, and that oneself is in possession of it, is the root of all evil in the world."-- Max Born, Nobel Physicist
Grinnin is offline   Reply With Quote
Old 04-18-2013, 05:16 AM   #5943
akaDigger
Amateur Adventurer
akaDigger's Avatar
Oddometer: 501
I'll do the PB Blaster / patience method. If that fails I'll do the heat up and try. At that point I'm ready to break them off.
Life moves pretty fast. If you don't stop and look around once in a while, you could miss it. Ferris Bueller
Baja 2012, my first moto tour
Oaxaca, Estados Unidos Mexicanos
akaDigger is offline   Reply With Quote
Old 04-18-2013, 06:07 AM   #5944
sandalscout
blah blah blah
sandalscout's Avatar
Oddometer: 2,253
Ouch.... When I got my bike (1 year ago, it is a 2000 that had 14k miles on it), one of the very first things I did was strip it down and clean/lube all of the bearings (except the steering head, I still need to do that). The swingarm bolt on mine was a little bit difficult to get out, but it only took me about 10 minutes or so. Emery cloth to clean it up, and then a liberal coating of grease to keep it from seizing again.
sandalscout is offline   Reply With Quote
Old 04-18-2013, 06:18 AM   #5945
JBradley500
Oddometer: 60
I've had good luck by putting pb blaster, then heat immediately followed by PB blaster... it may catch fire but if you put the flame back to it it will go out. I had to do that to my GF's tie-rod end the other day and it came right out. The heat helps the PB wick into the threads i believe. The blue-wrench will get anything loose.
JBradley500 is offline   Reply With Quote
Old 04-18-2013, 06:59 AM   #5946
XDragRacer
Oddometer: 3,188
Just a comment in praise of the IMPACT DRIVER; less than $ 10, with bits, from Harbor Freight, et al. (A JIS bit set enhances its effectiveness.)
This device (I consider essential for working on steel screws in alloy cases, and motorcycles in general) torques the fastener ONLY when the threads are relieved from a hammer blow.
The "Better Living Through Chemistry" techniques, like penetrating oils, PB Blaster, etc., are useful. Yet for the final application of force, an impact driver may be essential to remove a fastener without mangling its head.
I replaced the fasteners on my exhaust heat shield with Allen-head (hex socket) machine screws.
XDragRacer is offline   Reply With Quote
Old 04-18-2013, 07:19 AM   #5947
Rode2Nowhere
Rode2Nowhere's Avatar
Oddometer: 2,213
Another vote for impact driver. CAN'T BELIEVE I went 10 years wrenching on old bikes before buying one. Some of the best money you can spend on the shop.
- Jonathan
'88/'96/'08/'09 KLR650 Amalgamation
IBA #45896
Adirondack Tags
Rode2Nowhere is offline   Reply With Quote
Old 04-18-2013, 07:25 AM   #5948
beemerjim
beemerjim's Avatar
Oddometer: 446
I've got the frozen swingarm bolt scenario now. I can get it to rotate, but no lateral movement. You've given me hope.
JIm
The older I get, the faster I was.
It's all about attitude & timing.
I'm not sure where we're going, but this road seems to be paved with good intentions.
beemerjim is offline   Reply With Quote
Old 04-18-2013, 07:27 AM   #5949
MacNoob
MacNoob's Avatar
Oddometer: 1,651
Last time I did this I had my wife spin the bolt with my air impact wrench, while I whacked on the other end with a brass drift. It came out eventually.
edit: this made me feel queasy about the bearings, but they did not appear to suffer any harm.
I think I have finally learned that life is just too short for cheap butt connectors. And that's all I'm going to say about that.
MacNoob is offline   Reply With Quote
Old 04-18-2013, 07:32 AM   #5950
beemerjim
beemerjim's Avatar
Oddometer: 446
This gives me more hope. Once you got it started moving, did it continue to fight the rest of the way out? I don't want it to be stuck 1/2 way out.
Old 04-18-2013, 07:35 AM   #5951
Rode2Nowhere
Oddometer: 2,213
Yeah, if you have a helper, or devise some sort of "press" to keep pressure on the opposite end while you spin, it seems to work better. Still difficult, but better.
- Jonathan
IBA #45896
Adirondack Tags
Old 04-18-2013, 07:41 AM   #5952
MacNoob
MacNoob's Avatar
Oddometer: 1,651
Actually it moved a little then got stuck so I had a little back and forth movement. Was able to work it back and forth, PB blaster in the hole, spinning with air impact and while 'removing' with drift, then whack it back into 'installed' position, more PB, repeat repeat repeat...
Old 04-18-2013, 07:42 AM   #5953
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 14,069
mine came out fighting and scereaming the entire way . .. Kroil, my electric impact driver (spun it one way, then the other), a brass drift and a BAH (Big Assed Hammer) finalluy did the tirck.
This experience induced me to install zerks on the rear suspension linkage.
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
bomber60015 is online now   Reply With Quote
Old 04-18-2013, 07:49 AM   #5954
Grinnin
Forever N00b
Oddometer: 2,843
After my first week of frustration I slowed down and hit mine with a 4Lb hammer and brass rod once every morning and once every evening then soaked it and walked away. It was not moving. Suddenly one hit it moved 2 or so inches and the next hit it landed under the workbench. There was no getting stuck partway.
Old 04-18-2013, 08:01 AM   #5955
Rode2Nowhere
Oddometer: 2,213
Its hilarious, the multitude of different experiences.
Bottome line: It sucks... and should be re-lubed pretty much straight from the factory. Unfortunately many of us don't buy them new.
- Jonathan
IBA #45896
Adirondack Tags
Times are GMT -7.   It's 11:41 AM.
