Old 04-18-2013, 04:19 PM   #5971
Grinnin
Forever N00b
Oddometer: 2,892
Originally Posted by Diggerled View Post
Everything looks OK at this point. Valve clearances are great. Is this a weeper or just draining off outside of tube by gravity?
This is an '09, does the timing chain tensioner need any attention at 3100mi?
Do the stock tensioners tend to stretch chains? This early?
Also some silicone-ish sealant was applied to the cover gasket, at the factory I assume. But only on the area around the cam chain. Anyone know what the sealant is exactly? It was very thin when applied.
That oil on the cam bearing could easily be there because of splash. I cannot imagine that the O-ring is bad after only 3100mi. But what I believe won't help. You may want to check the integrity and snugness of the O-ring.
I don't think tensioners are over strong.
The Clymer manual and the Kawi manual for the KLR600 both say to apply sealant only around the chain case. Not too much or you risk pieces breaking off and clogging the oil intake. I use high-temp copper RTV. Only a thin bead. The bolts are not all that close to the chain case. Did I say "Not too much"?
"The belief that there is only one truth, and that oneself is in possession of it, is the root of all evil in the world."-- Max Born, Nobel Physicist
Grinnin screwed with this post 04-18-2013 at 04:43 PM
Grinnin is offline   Reply With Quote
Old 04-18-2013, 04:36 PM   #5972
Tsotsie
Semi-reformed Tsotsi
Oddometer: 1,911
Use any one of the following; Yamahabond , Hondabond HT (available also at Honda car dealers parts dept - and there are more than them than bike dealers around) - they are high temp 'liquid gasket' - just brand named differently. Great excellent seal and easy off - what the factories use.
I dont recall seeing oil weep out of the oil transfer transfer pipe. Since you have the valve cover off, replace the o ring - it will be cheap insurance.
Stock cam chain tensioners are automatic ratchet type - no 'adjustment necessary'. Mine (and the chain) have been in for 50K miles and are still good. Streach the chain - no. Be carefull. If you take it out, it has to be reset before you put it back in.
Tsotsie is offline   Reply With Quote
Old 04-18-2013, 04:42 PM   #5973
Grinnin
Forever N00b
Oddometer: 2,892
He's right. I was wrong above.
I claim too many bikes as the "problem".
Old 04-19-2013, 09:15 AM   #5974
akaDigger
Amateur Adventurer
akaDigger's Avatar
Oddometer: 498
New KLR owner question: Only the left side headlight burns on low beam. Is this normal?
Life moves pretty fast. If you don't stop and look around once in a while, you could miss it. Ferris Bueller
Baja 2012, my first moto tour
Oaxaca, Estados Unidos Mexicanos
akaDigger is offline   Reply With Quote
Old 04-19-2013, 09:17 AM   #5975
KamikazeKLR
Shorty on the 650
KamikazeKLR's Avatar
Oddometer: 681
Yes. Nothing to worry about. Many bikes do that, actually.
- Mel
Long Way Back
Not all those who wander are lost
2002 Kawasaki KLR650 - Big Red
KamikazeKLR is offline   Reply With Quote
Old 04-19-2013, 09:19 AM   #5976
8lives
Dharma Bum
8lives's Avatar
Oddometer: 2,021
Oh I'll bet it is just 1 side on low,my oldie KLR would really be cool at night if I had 2 headlights to chose from,I'll go out and ask her if she would like a 08 and newer facelift!
What would you do if you weren't afraid?
Bobcat Goldthwait is my mentor.
8lives is offline   Reply With Quote
Old 04-19-2013, 09:23 AM   #5977
KamikazeKLR
Shorty on the 650
Oddometer: 681
The 08+ Fairing doesn't fit on the oldie, does it? that would be awsome.
- Mel
Long Way Back
Old 04-19-2013, 09:30 AM   #5978
8lives
Dharma Bum
8lives's Avatar
Oddometer: 2,021
No I don't think it does fit,and when I asked the Green Lady in the garage she got kinda pissed and wanted to know if I thought she wasn't pretty any more,I told her she's beautiful and asked if she wanted to go get dirty someplace!
Old 04-19-2013, 09:48 AM   #5979
KamikazeKLR
Shorty on the 650
Oddometer: 681
made my day.
- Mel
Long Way Back
Old 04-19-2013, 10:10 AM   #5980
akaDigger
Amateur Adventurer
akaDigger's Avatar
Oddometer: 498
Old 04-19-2013, 12:22 PM   #5981
8lives
Dharma Bum
8lives's Avatar
Oddometer: 2,021
Made my day to make your day.Smile and pass it on!
Old 04-19-2013, 02:18 PM   #5982
OKlr
25mph gate inpector
OKlr's Avatar
Oddometer: 857
does. just takes about half a gen2 to do it.
OKlr is offline   Reply With Quote
Old 04-19-2013, 06:17 PM   #5983
rodmuzwa
rodmuzwa's Avatar
Oddometer: 174
Does anyone know where I can buy a carb slide for a 2012 model? I want to get the US version as it doesn't have the holes in the top which restrict the power!
Living the dream, everyday!
rodmuzwa is offline   Reply With Quote
Old 04-19-2013, 06:28 PM   #5984
SkiBumBrian
DualSport Crazy !!
SkiBumBrian's Avatar
Oddometer: 1,051
Ron Ayers or cheapcycleparts.com
"Where ever you are, there you go..."
SkiBumBrian is offline   Reply With Quote
Old 04-19-2013, 07:43 PM   #5985
XDragRacer
Oddometer: 3,212
Or, visit your friendly local Harley-Davidson dealer (does WA have Harley-Davidsons?), and buy a slide for a CV40 (Sportster carb). Same part, lower price than Kawasaki's CVK40 slide, in the USA.
Ask for, "CV Carburetor Vacuum Piston," H-D OEM Part # 27585-88.
Lower-cost option, still: Fill the too-big vacuum port hole in the slide with J-B Weld, or other goop, and re-drill to 7/64" diameter hole. (You guys still sometimes use inches ("), right?)
XDragRacer screwed with this post 04-19-2013 at 07:52 PM
XDragRacer is offline   Reply With Quote
Times are GMT -7.   It's 10:03 AM.
