Old 04-22-2013, 11:37 PM   #6091
Airjunky
Oddometer: 25
Scored a Hennessey hammock off ebay. Hoping to do a little motorcycle camping this summer.
-Bill
Airjunky is offline   Reply With Quote
Old 04-23-2013, 01:06 AM   #6092
XDragRacer
Oddometer: 3,191
Originally Posted by 8lives View Post
Hey I like the FAT BOY bulb idea,Any issues with powering it,I ride at night a lot and your correct Gen1 is sketchy in the dark.
The Generation 1 alternator has enough "juice" to power the FAT BOY H4, in my experience.
If you use a relay harness, a solid, low-resistance frame ground connection near the headlight socket is essential.
XDragRacer is offline   Reply With Quote
Old 04-23-2013, 02:40 AM   #6093
rodmuzwa
rodmuzwa's Avatar
Oddometer: 174
Originally Posted by viper770 View Post
i finally got the stickers off my new 2013 klr650
How did you do it?
Living the dream, everyday!
rodmuzwa is offline   Reply With Quote
Old 04-23-2013, 03:03 AM   #6094
viper770
viper770's Avatar
Oddometer: 591
the sticker just peals off took me like 2 minnets lol
2012 YAMAHA WR250R
2013 KAWASAKI KLR650
"Take the long way home"
MY SPOT LOCATION http://share.findmespot.com/shared/f...vi71zS820h7TbU
viper770 is offline   Reply With Quote
Old 04-23-2013, 03:13 AM   #6095
8lives
Dharma Bum
8lives's Avatar
Oddometer: 2,019
Do you need the relay harness?
What would you do if you weren't afraid?
Bobcat Goldthwait is my mentor.
8lives is offline   Reply With Quote
Old 04-23-2013, 06:02 AM   #6096
sandalscout
blah blah blah
sandalscout's Avatar
Oddometer: 2,258
-Bill
I just have a cheap $25 hammock with an upgraded harness that actually cost more than the hammock, but it's some of the best nights sleep I've had. I am really happy with mine!
I've got a tiny tarp that I made to go camping, but it's too small for the hammock. I've rigged up some cheap plastic sheeting to be a tarp, and I'll be using it all for 3 nights next weekend at a local D/S event. Apart from the RV guys, I guess I'll be one of the most well rested guys out there.
sandalscout is offline   Reply With Quote
Old 04-23-2013, 07:31 AM   #6097
redog1
KLR650-2009
redog1's Avatar
Oddometer: 1,803
There's supposed to be a vacum operated air pump...
Originally Posted by LilGreenBooger View Post
Hey folks.
I recently moved up to KLR - I traded a buddy an 09 sherpa for an 08 KLR.
Anyway, I had the tank off today, and noticed this tube coming out of the head. the hose on the end had burned off, and there was a bunch of soot on the end of the pipe. What is it, and where is the hose supposed to go??
On the right side behind the shroud, you should be able to see it though the vent hole of the shroud if it's still in place. What's remaining of the hose in your picture should be pointing towards it. I can tell you that the Clymer manual if you have one doesn't say anything about it.
No, I don't know where that road goes, let's find out!
redog1
redog1 is offline   Reply With Quote
Old 04-23-2013, 09:22 AM   #6098
akaDigger
Amateur Adventurer
akaDigger's Avatar
Oddometer: 501
Heat Shield Grommets
What can you substitute for the grommets that melt away on the exhaust pipe heat shield?
Life moves pretty fast. If you don't stop and look around once in a while, you could miss it. Ferris Bueller
Baja 2012, my first moto tour
Oaxaca, Estados Unidos Mexicanos
akaDigger is offline   Reply With Quote
Old 04-23-2013, 01:00 PM   #6099
CallMeBoog
hi functioning idiom
CallMeBoog's Avatar
Oddometer: 6,288
okay. i (uhhh) "obtained" (uhhhh) a copy of the factory service manual, and you are right, there is some vacuum pump thing on the right side near the rad puke bottle. I do not have one, so one of the PO's removed it, and probably just plugged the hose.
I got this bike from FredGreen, who got it from JDRocks, who also got it used...it's changed hands alot in 5 years!
It's got the IMS tank, highway peg guard / skidplate combo from HappyTrail (ithink), custom seat, and all the fairings removed, and the headlight changed.
I'm looking to swap the headlight (small square thing with tiny shroud) to something like a trailtech baja, or one of the dominator dual 4" lamp setups.
Photobucket is being a PITA right now, but pics are coming!
love this bike
Don't Ride With Nate!
CallMeBoog is offline   Reply With Quote
Old 04-23-2013, 02:31 PM   #6100
road_apple
Hit the Trail
road_apple's Avatar
Oddometer: 151
Ais
Air Induction System blockoff plate or make your own by making sure the tube is airtight. There's a little oring under that plate with the tube coming off it, no air leaks. There is a tee connection on the top of the carb that provides vacum for this and a vacum oprated fuel petcock, make sure that is sealed too. All got modded with the IMS tank probabily. It caused backfiring and it's thought to contribute to cherry red exhaust syndrome so people removed it.
http://www.eaglemike.com/Air-injecti...ff-kit-AIS.htm
road_apple is offline   Reply With Quote
Old 04-23-2013, 02:35 PM   #6101
KamikazeKLR
Shorty on the 650
KamikazeKLR's Avatar
Oddometer: 665
I have a question about a KLR tank...
Mine, when you lay the bike down, will kinda leak gas out the gas cap.It doesn't come POURING out, but... It doesn't look like it should be doing that is what I'm saying.
What's a good, easy fix for that?
- Mel
Long Way Back
Not all those who wander are lost
2002 Kawasaki KLR650 - Big Red
KamikazeKLR is online now   Reply With Quote
Old 04-23-2013, 02:49 PM   #6102
redog1
KLR650-2009
redog1's Avatar
Oddometer: 1,803
Good question...
My 09 does the same thing since new, never worried about it but my 1990 doesn't leak. I'd like to see some feedback. ????
redog1
Old 04-23-2013, 03:15 PM   #6103
bdcorrigan
bdcorrigan's Avatar
Oddometer: 650
Easy fix... Ride it more so there is less gas in it and don't lay her down.
bdcorrigan is offline   Reply With Quote
Old 04-23-2013, 03:41 PM   #6104
CallMeBoog
CallMeBoog's Avatar
Oddometer: 6,288
perfect, thank you.
The vacuum petcock is still on it, and it has it's own line from the carb, no tee. it does backfire a little under deceleration, and there's a little black in the lip of the exhaust...this could be what's going on there. I'll look into blocking that off.
Old 04-23-2013, 06:12 PM   #6105
Unstable Rider
10,000 Lakes
Unstable Rider's Avatar
Oddometer: 2,588
It needs to be able to breath or fart on occasion.
If we were fuel injected, it would be sealed. Our caps are vented".
Be glad we don't have the gay rubber hose coming out of it like real dirt bikes.
Watch this video, you will see his gas cap leak as well.
http://www.youtube.com/watch?v=OOCTsna2jiI&feature=context&context=C4d3dbceVAvjVQa1PpcFNkMJfxvUnS1xaM1duicfTC jjatarDfcME=
-“Ah, you're wasting you're time. They can't track us over rocks.
Tell them that.......... --Who are those guys?”
~Butch Cassidy
Unstable Rider is offline   Reply With Quote
Times are GMT -7.   It's 11:38 AM.
