Old 05-19-2013, 07:06 AM   #6676
ausfahrt
mach schnell
ausfahrt's Avatar
Oddometer: 1,806
Chain and sprockets
I will be due for a new set in the near future and I plan on going with the 16 tooth front sprocket. This looks like a good deal for an o-ring chain and sprockets delivered for under a c-note.
Have any of you guys gone this route?
http://www.amazon.com/Kawasaki-O-Rin...d+sprocket+set
You can always count on the Americans to do the right thing, after they have tried everything else.
-Winston Churchill
ausfahrt is offline   Reply With Quote
Old 05-19-2013, 08:20 AM   #6677
ausfahrt
mach schnell
ausfahrt's Avatar
Oddometer: 1,806
Originally Posted by draley View Post
Works for me. Seems to be good quality. The nerf bars may not be as heavy-duty as some other brands, but the combo package is hard to beat on price.
I Like the hiway pegs.
-Winston Churchill
Old 05-19-2013, 10:04 AM   #6678
Aprilia
Oddometer: 748
I've been using Primary Drive components for years on many different bikes...love them. I'd suggest buying directly from Rockymountainatvmc.com as its their house brand and they do a lot to support the motorcycle community.
Aprilia is offline   Reply With Quote
Old 05-19-2013, 10:23 AM   #6679
Woodenveins
Adventure Rider
Woodenveins's Avatar
Oddometer: 507
Originally Posted by Unstable Rider View Post
Shinko 705
75 / 25 tires. Mostly blacktop, some gravel roads, couple atv trails, no single track
This past summer my budget dictated that I would be shopping for another set of cheap, affordable rubber for my 2009 KLR 650. I ordered them from Motorcycle Superstore. I think the shipping was free.
I ran them over 3,000 miles into the fall. I must say, they are wearing evenly, no cupping, cracking or chunking. They are confident on pavement, they are great on tar snakes and re-assuring in the rain. Like the stock Dunlop's that came on my KLR, I think these are a softer rubber compound, but if that means a great ride, quite tire experience that is safe, affordable and not scary in all conditions, than its a top choice for me, especially based on price, and these are typically available. I don't want to hear about tires like the Continentals that are never available and on back order my whole riding season. If money was no object, I would run Avon Gripsters. But on my current budget, I can get a pair of Shinko's for considerably less than just the back in a Gripster.
They are considered from one source as being a 75-25 tire, which fits my riding style perfectly. About 25% gravel riding is my limit (seldom go very far off road alone) with the 540 pound weight of my bike trip-rigged. I do keep my tires aired down from what they say to run them at. Working great thus far with heavy loads!
Probably going to be a 4,000 mile tire. Thanks for reading. Just one ole rider's humble opinion. I have run 4 different tire brands and must say these are quite reliable with no quirks for the money for my riding style and bike weight.
Rear $57.99
130 X 80 X17
Front $49.00
90 X 90 X21
Thanks and thanks for those links as well. Will soon have a couple of those heading my way.
My Adventure Rides
KLR650
NC-NC Tags
Woodenveins is offline   Reply With Quote
Old 05-19-2013, 11:04 AM   #6680
MSrider
Rebel with a sixfiddy
MSrider's Avatar
Oddometer: 4,275
Originally Posted by dmottv View Post
Possibly the kick stand safety switch? I had the same thing happen in the middle of the Gaspe. I pulled the cover and disconnected the wiring and it worked fine after that. Just remember to put the kick stand up before you take off...
Good post on side stand switch, it could also be the clutch safety switch. I disconnected the cable to the switch(kickstand) and left the wiring plugged in just to keep the spooge out of the connectors. Same end result.
FWIW, I've seen them spitting O-rings @ 10k on KLRs. I have had great service life out of Japanese built Bikemaster O-ring chains installed on used factory KLR sprockets. I've got right at 40k on original sprockets with the BMOR chain installed at 18.5k . Still going strong and sprockets still look fine. IMO, you won't buy a better sprocket than OEM. I've seen Sunstar sprockets roll over in less than 15k on a KLR(not mine). YMMV.
KOKA
MSrider is offline   Reply With Quote
Old 05-19-2013, 03:00 PM   #6681
Stephen_m64
n00b AdvRider
Oddometer: 54
Thought i might derail the thread a little bit with a picture of my first ever bike purchase.
saw a decent deal on craigslist for a 1989 KLR650 with just 5K miles and quickly jumped on it. May not be the prettiest thing around but it sure is fun for a new rider.
Only problems with it is it leaks slightly from the drain plug and needs a new chain+clutch cable. No idea if the dohickey has been done. but no money to tackle that yet... so just trying to figure out what i should do to her and in what order.
Stephen_m64 screwed with this post 05-19-2013 at 03:05 PM
Stephen_m64 is offline   Reply With Quote
Old 05-19-2013, 03:04 PM   #6682
XDragRacer
Oddometer: 3,188
Originally Posted by Stephen_m64 View Post
Only problems with it is it leaks slightly from the drain plug and needs a new chain. No idea if the dohickey has been done. but no money to tackle that yet... so just trying to figure out what i should do to her and in what order.
If you're talking oil drain plug, a new crush washer (or maybe an oversize oil drain plug) might fix that; new chain? Not much mileage in normal service life of a chain, but . . . replacement remains a doable do.
XDragRacer is offline   Reply With Quote
Old 05-19-2013, 03:05 PM   #6683
SkiBumBrian
DualSport Crazy !!
SkiBumBrian's Avatar
Oddometer: 1,051
Hopefully the drain leak can be fixed with a new crush washer. Be careful, many a drain plug has been stripped by overzealous owners. Torque to only 17 ft. lbs.
"Where ever you are, there you go..."
SkiBumBrian is offline   Reply With Quote
Old 05-19-2013, 03:15 PM   #6684
Stephen_m64
n00b AdvRider
Oddometer: 54
The bike looks like it has been primarily sitting for most of its life, so going to change the oil asap. Planned to try to new crush washer then move to a over-sized drain plug already. really hope to not have to try and helicoil the damn thing.
Since I'm a computer technician and not a motorcycle mechanic, doing the doohickey next is going to be a interesting small project. lol
Old 05-19-2013, 03:29 PM   #6685
astrolump
astrolump's Avatar
Oddometer: 863
i usually put a bit of grey rtv silicone on the threads and crush washer of the drain plug when i change oil...just an old habit that stops any drips for me.
just a little bit though...don't go crazy.
HEY. did you see something fall off my bike? I mean other than me.
"They see me coming on my KLR......They hide their daughters and their PBR......
I'll take the beer,no time for girls......Got a date in the Forest, chasing squirrels. "
astrolump is online now   Reply With Quote
Old 05-19-2013, 03:47 PM   #6686
Tsotsie
Semi-reformed Tsotsi
Oddometer: 1,869
I have tried the PD chain. It was throwing O rings at 12k miles. I orginally changed out the stock one at 18+K as I was due to do a 4 k ride and was not sure. I now have 16+k on a DID X ring and it looks as good as new. PD does not get my vote. RM Atv is a good company to deal with and also stock most of EMikes' parts too.
Tsotsie is offline   Reply With Quote
Old 05-19-2013, 03:53 PM   #6687
Tsotsie
Oddometer: 1,869
Originally Posted by swaino View Post
Hello all, i'm seeking some opinions
I was riding my 08 KLR yesterday when, after about a half hour ride my bike just cut out.
I rolled to a stop and tried a quick fix fuel check but all seem fine.
I have to go and retrieve it in the morning and was hoping for a few ideas.
Does the KLR have a low oil cut out?
Thoughts anyone.
Adrian
Have you checked the fuses? The only time my 08 stopped likthat was when the main 20amp fuse under the side cowel next to the petcock went. I replaced that and all has been wel for several years. I never was able to find out why it went.
Has this bike had its main wire harness replaced under warranty but Kawa - fixed by yourself?
Old 05-19-2013, 04:20 PM   #6688
One Fat Roach
One Fat Roach's Avatar
Oddometer: 1,586
I'm looking to upgrade from my first bike, a XL250, and seriously contemplating this bad boy :
http://yakima.craigslist.org/mcd/3811410907.html
Just wondering what your guys thoughts and areas of concern would be with this sexy beast...
Originally Posted by Mr. Fisherman View Post
This is an adventure, not a field trip!!
One Fat Roach is offline   Reply With Quote
Old 05-19-2013, 04:45 PM   #6689
DutchVDub
Oddometer: 1,310
Buy it man, that thing is sweet.
2008 Honda Shadow 750 Spirit
2013 Victory Cross Country
DutchVDub is offline   Reply With Quote
Old 05-19-2013, 05:05 PM   #6690
One Fat Roach
Oddometer: 1,586
I want it bad. A fellow inmate offered to go check it out and test drive it for me, he lives a mile away from the dealer. Just wondering what kind of mechanical stuff I should ask the dealer about when I go see it. And when I get it home what major things should I xheck checkout etc. I've wanted a KLR for so long and this one is in my price range right now. If I save up til end of June I can buy an early 2000s model. But I lack patience.... I wanna pull the trigger but I'm.nervous for some reason.
Times are GMT -7.   It's 07:30 PM.
