Old 07-11-2013, 06:13 AM   #7456
8lives
Dharma Bum
8lives's Avatar
Oddometer: 2,018
good advice on the heat^^^^^^
What would you do if you weren't afraid?
Bobcat Goldthwait is my mentor.
8lives is offline   Reply With Quote
Old 07-11-2013, 06:26 AM   #7457
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,856
Originally Posted by bassplayinroach View Post
Sold!!
And I've had to replace several already. Some weren't on the bike when I got it to begin with but some have fallen out. I almost lost my rear rack (empty at least) down the road one time. And as grassroots said aint nothin' wrong with a little insurance =]
Loc-Tite is indeed great stuff,but its good to buy the right Loc-Tite,a steel bolt in an aluminum part doesnt get Loc-Tite.
When the bolt comes out the threads can come with it if its loc-tited solidly in place. Ive had this happen and it sucks.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 07-11-2013, 07:19 AM   #7458
Aprilia
Oddometer: 746
Loctite has a place but on my bikes it rarely makes an appearance. Most used is my Anti-Seize. Should be used anytime steel meets aluminum. On bolts that can not come loose due to safety I simply safety wire. Oil drain and 4 hex bolts holding the foot peg mounts are safety wired on my KLR as example. Properly cleaned and torqued bolts will stay in place. Side note for you "I love Loctite"...keep your loctite in the refrigerator when not in use.
Aprilia is offline   Reply With Quote
Old 07-11-2013, 07:47 AM   #7459
sandalscout
blah blah blah
sandalscout's Avatar
Oddometer: 2,250
Mine too, after reading so many problems with the backing out, this was one of the first things I did. I don't even have safety wire pliers, but just drilling the heads to accept bailing wire, and running that through twice in a figure eight to the other bolt provides some peace of mind.
sandalscout is offline   Reply With Quote
Old 07-11-2013, 08:09 AM   #7460
Bear Archer
Bear Archer's Avatar
Oddometer: 85
Ok good to know, thanks. I ask because I've sheared 3-4 trying to unscrew a few before. Probably just age and rust. I've looked over a lot of them.since and they look about the same condition. And it makes me uneasy to attempt working on anything if everyone I pull.out breaks off. Guess I just gotta try
I've done lots of machine work and I don't generally have a problem with shearing bolts off. If I have something that is sitting for a little bit I use that penetrating oil. It won't do much to the thread lock but it definitely helps with the rust.
I've also found that if the bolt is rusty/dirty and I put the blue locktite it's like having the red stuff on there. Just a FYI
Sent from my DROID RAZR using Tapatalk 2
Bear Archer is offline   Reply With Quote
Old 07-11-2013, 08:37 AM   #7461
8lives
Dharma Bum
8lives's Avatar
Oddometer: 2,018
all good info I'm learning a lot about how to keep fasteners together and getting them apart,tie wire is about as good as it gets,I had a R6 that was all wired together and it was nice when I was done with anything the wired bolt/nut was there until next time,I guess a nice small sharp drill bit and a hole is better in the long run than chancing LOC TITE.
Old 07-11-2013, 08:45 AM   #7462
sandalscout
blah blah blah
Oddometer: 2,250
Totally.... I still use loctite on the bike, but will probably safety wire more things over time. I used loctite on the safety wired bolts even.
Old 07-11-2013, 09:45 AM   #7463
jeepsandbikes
loneadventurer
jeepsandbikes's Avatar
Oddometer: 148
I use loctite AND Anti-Seize on each bolt and let them fight it out ...
A bad day of riding is better then a good day of work
jeepsandbikes is offline   Reply With Quote
Old 07-11-2013, 10:04 AM   #7464
One Fat Roach
One Fat Roach's Avatar
Oddometer: 1,585
I can't tell the difference so easily yet ...
Originally Posted by Mr. Fisherman View Post
This is an adventure, not a field trip!!
One Fat Roach is offline   Reply With Quote
Old 07-11-2013, 10:42 AM   #7465
sandalscout
blah blah blah
Oddometer: 2,250
Old 07-11-2013, 05:54 PM   #7466
Keating
Oddometer: 219
Red loctite'ed bolt still come out easier than salt corroded bolts without loctite.
The wife is still a little freaked by the whole thing but what ya gonna do? Stay at home and die in your sleep? - laramie LC4
'04 KLR650
Keating is offline   Reply With Quote
Old 07-11-2013, 06:17 PM   #7467
jules083
jules083's Avatar
Oddometer: 3,959
I always play the 'which one' game with bolts. Sometimes when I can't decide I go with neither.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
COBDR and UTBDR on my klx250:
http://advrider.com/forums/showthread.php?t=1003485
jules083 is offline   Reply With Quote
Old 07-11-2013, 06:27 PM   #7468
TheBlurr
Oddometer: 5,588
Apparently I am missing the add Images button
TheBlurr is offline   Reply With Quote
Old 07-11-2013, 09:10 PM   #7469
Mr50
Oddometer: 40
Ordered my new windshield, was really excited to have today off and was going to install it today. Unfortunately due to floods in Ontario the package is unaccounted for on UPS.com... Hopefully I still get it
Mr50 is offline   Reply With Quote
Old 07-11-2013, 09:19 PM   #7470
BuzzGrizz
BuzzGrizz's Avatar
Oddometer: 26
Originally Posted by fleshpiston View Post
Yep, love mine ...... maybe not the best option for soft bags but symmetrical, plenty of room for a tool tube on the left.
another vote here for the packratt love mine. how do you have your pelicans mounted?
07' KTM 250xc
08' Yamaha WR250r
03' KLR 650
Excuses are just a first class LIE.
BuzzGrizz is offline   Reply With Quote
Times are GMT -7.   It's 09:38 PM.
