Old 11-20-2011, 06:28 PM   #1
Bill Harris OP
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,013
Airhead stud tool dimensions
Does anyone have, or or know of an online source for, the distances between the cylinder studs on a BMW R-bike? I'm working up a stud repair drilling jig.
'73 R60/5 Toaster
Bill Harris screwed with this post 11-20-2011 at 06:34 PM
Old 11-20-2011, 09:37 PM   #2
robtg
Oddometer: 690
Oddly enough, the stud spacing is really close to the same spacing as the holes in the cylinder, head gasket,and the cylinder head. Although you may
want to use an actual crankcase for an exact fit.
robtg is online now   Reply With Quote
Old 11-21-2011, 11:06 AM   #3
batoutoflahonda
Oddometer: 1,386
I'm pulling the jugs off mine this weekend. I could measure, photo, etc if you like. But you are probably looking for engineering drawings. I recall see it some where. I'll look around.
It's eight and a half gallons of gas; and an engine. What more do you need?-- BMW R80G/S
Save lives. Legalize lane sharing.
Cow eyes don't glow.
batoutoflahonda is offline   Reply With Quote
Old 11-21-2011, 12:30 PM   #4
Bill Harris OP
Oddometer: 8,013
I'll use a head gasket or a /5/6 base gasket for a "template", though there is the possibility of dimensional errors that can creep into transferring measurements from the gaskets. The better way would be to use a bare case and measure the stud distances. I'm doing my top end as we speak, but it's going through it's second stud-thread repair and I'm sure that some creep has crept since I've not always used a mil-spec drilling jig. Just double-checking-- I'm sure that the "correct" dims will be to the nearest millimeter.
I recalled seeing that stud dimension layout, along with the transmission shim plate dims at one time.
For 30 years I've used a drilling jig that you have to index to the stud you're repairing, and currently am using a rental jig from Northwoods, but I thought I'd make myself a nice self-indexing jig. Not hard, a couple of dims and a Bridgeport & a lathe and you're done.
And I might go commercial develop with a nice mahogany or teak drilling jig for the connoisseur...
Oh, this top-end work is coming along so nicely...
'73 R60/5 Toaster
Old 11-21-2011, 12:52 PM   #5
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
no need bill, I've got plenty of open engines on the bench at the moment.
I'll go measure and be right back.......................
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 11-21-2011, 01:11 PM   #6
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
I'm reading 72mm x 93mm center to center.
I agree with ROBTG about using an actual block though.
I have an R65 block that threw a rod, I'll see if one side is good enough for a jig.
Maybe I could even cut out the section and send it to you for the shipping.
I'll check and see, it's in the bottom of my scrap metal drum.
www.wirewerkes.com
wirewrkr screwed with this post 11-21-2011 at 01:28 PM
Old 11-21-2011, 04:10 PM   #7
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
So here ya go Mr Harris,
went through 3 sawzall blades to get'er done, but was worth it.
www.wirewerkes.com
Old 11-21-2011, 04:20 PM   #8
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
Robert.
You just brought a new level of awesomeness to this forum.
datchew is offline   Reply With Quote
Old 11-21-2011, 05:01 PM   #9
Bill Harris OP
Oddometer: 8,013
Omygosh, how neat. If you're wanting to part with that prize, I'll take it (check your PM for address).
93x72mm sounds right (I measured mine, in inches, and those numbers are in the shop at the other end of the house now). I'll check later. The spigot is 97mm for pre-nikasil and 99mm for Nikasil cylinders.
'73 R60/5 Toaster
Old 11-21-2011, 05:19 PM   #10
baldwithglasses
Godspeed, Robert
baldwithglasses's Avatar
Oddometer: 799
wirewrkr, what datchew said.
Awesome. Sublime.
baldwithglasses is offline   Reply With Quote
Old 11-21-2011, 05:31 PM   #11
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,820
Actually the Nikasils are 99mm but there are some pre Nikasils also 99mm. The division is the last year of /6. 1975 and older are 97mm. 1976 and up are 99mm. So some iron cylinders are 99 but can be updated to Nikasil.
Nice looking slice from your block. If you welded them back in at an angle you could make it a Moto Guzzi.
disston is online now   Reply With Quote
Old 11-21-2011, 05:57 PM   #12
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
luckily, the stud holes are all the same distance from 1970-96.
This chunk is from a 79 R65.
www.wirewerkes.com
Old 11-21-2011, 06:04 PM   #13
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Bill, PM ed you the info.
www.wirewerkes.com
Old 11-21-2011, 06:35 PM   #14
Mugwest
Mugwest's Avatar
Oddometer: 6,645
Cool ++
That R65 block gave itself to the Larger Good
Mugwest is online now   Reply With Quote
Old 11-22-2011, 02:44 AM   #15
Bill Harris OP
Oddometer: 8,013
More than cool. This is art!
Charlie, thanks for the extra info. I remembered that the early cast iron cylinders were 97mm and the later Nikasil were 99mm and assumed that the division was by cylinder type and not model year.
'73 R60/5 Toaster
Times are GMT -7.   It's 02:27 PM.
