Old 06-12-2012, 02:44 AM   #1
gmtcm OP
KTM RIDER
Oddometer: 316
2002 ktm lc4 rectifier readings
My 2002 KTM 640 Hard Enduro quit running on me yesterday with what seemed like a low battery. After I towed it home I did a voltage test across the battery terminals and it was only putting out 11.8 volts while the engine is running. Does anyone have the various resistance readings for the voltage regulator/rectifier, and the stator coil? I have the repair manual on a CD but can't sem to find them in the manual. It only says to check the electrical fittings on the rectifier and stator coil. It also implys that it could be the ignition switch, which seems slow to shut off the engine when I turn the key off. Any advice is appreciated.
gmtcm
Stand Behind Our Troops or Feel Free to Stand in Front of Them.
gmtcm is offline   Reply With Quote
Times are GMT -7.   It's 04:21 AM.
