Old 06-11-2012, 07:38 PM   #1
flashover604 OP
tailgunner
flashover604's Avatar
Oddometer: 518
Will a RFS front fender fit my '03 640 Adventure?
I'm looking at changing the front fender on my 2003 640 Adventure to the newer style RFS front fender. Anyone know if they're interchangeable?
"That which does not kill You, usually makes you wish it did......."
flashover604 is offline   Reply With Quote
Old 06-11-2012, 09:15 PM   #2
gunnerbuck
I.Hopp.
Oddometer: 3,076
They are interchangable but you may have to shim the front up as otherwise the fender may rub the rad connecting hose... To do this install a couple washers on each side of the rear mounting points between the fender and the lower triple...
640 A x 2
gunnerbuck is online now   Reply With Quote
Old 06-11-2012, 09:51 PM   #3
flashover604 OP
tailgunner
Oddometer: 518
Awesome. I'm toying with the idea of trying the auto wrap vinyl on the tank and fairing to swap from the '03 silver to white. It's pretty easy to remove from what I've read if I decide I don't like it, but I wanted to change the shape of the fender to the new style.
Times are GMT -7.   It's 10:53 PM.
