Old 11-23-2011, 02:44 PM   #1
oldroadie OP
Two wheel addict
Oddometer: 472
/5 airhead torque value
Okay, it's fall/winter project bike time and I'm already battling Clymer who seem to have hidden the torque value quite cleverly. I know the 1972 R75/5 had issues with folks over tightening these bolts, I've got my inch pounds wrench at the ready...who knows the number and will you post it, please?
edit: forgot to specify - Torque value for the oil pan bolts, please.
oldroadie screwed with this post 11-23-2011 at 02:56 PM
oldroadie is offline   Reply With Quote
Old 11-23-2011, 02:47 PM   #2
pommie john
pommie john's Avatar
Oddometer: 1,486
We need to know which bolts you're talking about.
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt.
Bertrand Russell
pommie john is offline   Reply With Quote
Old 11-23-2011, 02:55 PM   #3
oldroadie OP
Two wheel addict
Oddometer: 472
Yes, I suppose that would help. Torque value for the oil pan bolts, please.
Old 11-23-2011, 03:17 PM   #4
Houseoffubar
fine beer sampler
Houseoffubar's Avatar
Oddometer: 1,819
I would go by feel, if it were my bike.
Old 11-23-2011, 03:36 PM   #5
Horsehockey
A GPS? Huh?
Oddometer: 333
For the oil pan bolts, it's something like 6 or 7 foot pounds. In other words, just snug. A dry oil pan is a function of how clean you prepare the metal surfaces (use acetone to get it all....no residual anything), and tighten the 14 bolts in a crosswise star pattern beginning in the middle of the two long sides. Tighten sequentially, not all at once on a single bolt.
For torque specs:
http://bmwmotorcycletech.info/torquevalues.htm
Horsehockey screwed with this post 11-23-2011 at 03:44 PM Reason: correct the inch pound/foot pound reference
Horsehockey is offline   Reply With Quote
Old 11-23-2011, 03:37 PM   #6
pommie john
Oddometer: 1,486
This seems to say 6lb ft (72 inch pounds)
That sounds about right to me.
http://www.bmwscotter.org/tools/torq...rque-specs.pdf
Bertrand Russell
Old 11-23-2011, 03:42 PM   #7
Horsehockey
A GPS? Huh?
Oddometer: 333
Right you are Pommie. Here's Snowbum's work on the subject:
Oil pan mounting bolts: book values 6.5-8 (some books show to 8.5)foot-pounds.......I suggest less, perhaps 5.5-6, carefully tighten in a staggered
cross-pattern, starting at the center ones, and do it very evenly. NO GOO! Put the lettered side UP. There is a heat-activated glue on these.
The old cork gaskets are NLA. I do these bolts BY HAND, not torque wrench. YOU may want a torque wrench MOST torque wrenches
of the type that have a range of maybe 5 to 75 foot-pounds, can NOT be used for this, as their accuracy is NOT good, nor is the FEEL for the click.
If you plan to use a torque wrench, use an INCH-pound wrench. Multiplying my 5.5-6 foot-pounds by 12, you can see that I would be
recommending 66 to 72 INCH-pounds.
Old 11-23-2011, 04:04 PM   #8
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,533
Snug but not too snug. Get a 0-200 inch-lb torque wrench and use 70-75 inch-lbs. On aluminum, your best friend is a 3" palm ratchet, 3/8 drive.
Pan bolts, run through the pattern, snug them and run it for a week and re-snug. The gasket tends to "settle".
'73 R60/5 Toaster
Old 11-23-2011, 09:30 PM   #9
wmax351
Oddometer: 743
I did them via a screwdriver type socket to hand tight, then snugged them with my hand around the middle of a 3 inch flex ratchet. Less is better. A couple stripped out anyhow (when they are ready to go, they go with the slightest torque). Loosen, then retighten as you are taking the pan off: that way you strip the threads which are shot before you put the pan back on. Helicoil is your friend.
wmax351 is offline   Reply With Quote
Old 11-24-2011, 05:06 AM   #10
oldroadie OP
Two wheel addict
Oddometer: 472
thank you
Thanks everybody. I knew I had read that number somewhere and when I didn't find it in the Clymer I just stopped working and walked away; too many months of prep reading and I hadn't bookmarked the proper spot. It seems that I read and absorbed Snowbum's procedure and my tiny brain just didn't remember...
Old 11-25-2011, 11:51 AM   #11
lkchris
Albuquerque
lkchris's Avatar
Oddometer: 1,041
Good place to use Loctite
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
lkchris is offline   Reply With Quote
Old 11-25-2011, 01:29 PM   #12
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 10,219
I don't use a torque wrench on these and I also use Locktight, Blue, most times. However on occasion when I could not find the tube of Locktight it worked fine, they held, dry. Still did not use a torque wrench.
disston is online now   Reply With Quote
Times are GMT -7.   It's 01:35 AM.
