Old 11-14-2011, 01:24 PM   #1
garyinalt OP
garyinalt's Avatar
Oddometer: 73
Seeking opinions on noise 78 R100
I have a noise coming from what I think is just the left cylinder. It is a tapping sound only from 3000 to 3200 rpm. No other symptoms anywhere else on the rpm band. I checked my plug and it has black soot as opposed to the right side which is a nice grey. The top of the piston has a soft coating of black stuff which I can remove with a screw driver inserted. I have checked rocker end play and valves and they are spot on. The bike has just 15k on it and no valve recession just yet. The only thing that just might be coincidental is that 500 miles ago I added 1/2 gallon of aviation fuel for its lead content. Any ideas before I start tearing into this?
77 R75/7
78 R100/7
93 R100R
garyinalt is offline   Reply With Quote
Old 11-15-2011, 02:46 PM   #2
97oilhead
97oilhead's Avatar
Oddometer: 189
Have you checked to see if there is anything loose and vibrating on the frame or engine?
I know that my 100's seem to vibrate the most when they are in the 3000-3200 range.
'05 R1200RT
'00 R1100S
'04 R1200C Montauk
'95 R100R Classic
97oilhead is offline   Reply With Quote
Old 11-17-2011, 02:05 PM   #3
garyinalt OP
garyinalt's Avatar
Oddometer: 73
Mine vibrates there too but this almost sounds like the valve making the noise. I plan on taking it apart to inspect/clean the head. Then I will run it again to see if it made a difference.
77 R75/7
78 R100/7
93 R100R
Old 11-17-2011, 02:34 PM   #4
danedg
Horizontally Opposed
Oddometer: 6,665
Make sure your sparkplug wires and caps and stuff are nice and tight. The difference in plugs indicates either a carb or spark problem, as in, it's not firing correctly, if at all. Throw fresh plugs in...Light grey is almost too hot...black is fouling. You're looking for something in between on both sides.
54' R51/3, 65' R60/2, 68' R60US, 74' Moto Guzzi Eldorado, 95' Mystic
danedg is online now   Reply With Quote
Old 11-24-2011, 08:24 AM   #5
garyinalt OP
garyinalt's Avatar
Oddometer: 73
In case anyone is still interested in the noise problem, its been resolved. I removed the head off the left cylinder and found the reason that one had soft carbon on the top of the piston. That is the side that has the crankcase pressure relief valve that allows the oil to be reburned. I cleaned it and decarbonized the head and put it back together. Then on a slow ride at around 3000 rpm the clacking noise returned. I bent over to try and hear it a little better and then I saw the horn shaking wildly. That was the noise! Once I removed the broken horn, problem solved! Wish I would have checked that first and save me all the trouble. Live and learn.
77 R75/7
78 R100/7
93 R100R
Old 11-24-2011, 09:45 AM   #6
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,190
LOL
Glad you found it and was so easily handled.
I had an old Volvo that would make a buzzing/vibration at certain RPMs. I couldn't find it no matter how hard I looked and since it didn't seem to affect running, just lived with it. Many thousands of miles and a few years later I discovered that the Intake Plenum brace at the block end attachment was missing its bolt! Problem solved.
Times are GMT -7.   It's 06:01 PM.
