View Results: Would you consider participating in a group buy?
Yes, if the price is right. 13 86.67%
No, these cartridges are way to expensive. 0 0%
No, USD forks will work so much better 2 13.33%
Voters: 15. You may not vote on this poll
Old 07-27-2012, 10:30 PM   #706
Kokopelli OP
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,644
I am just glad that I haven't had time to install anything. I am sure you guys will have it sorted by the time I am ready . I am now wondering if I should go with the heavier weight oil, like Stagehand.
R1150GS
R80GS Basic
Kokopelli is offline   Reply With Quote
Old 07-27-2012, 11:01 PM   #707
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,214
Originally Posted by One Less Harley View Post
This sucks, don't know why I'm bottoming out (175 mm and gators are compressed thus bottoming), and this only under moderate increasing brake.
It's mystifying.
I'm set-up per the instructions and pretty happy.
Brake-dive seems half of what it was with the stock set-up, and my sag only one band off recommended initial settings using the preload spacer Herr Hofmann sent.
"If you want to fix it with a rock, you have to stick to stone-age technology" -Anton
"...solving the latest crisis that is preventing my Airhead from taking me to the bar." -Beater-
Renner is online now   Reply With Quote
Old 07-28-2012, 01:38 AM   #708
advNZer?
advNZer?'s Avatar
Oddometer: 2,863
well my stuff is still in Auckland and now the package has been opened.Racetech are adamant they have the correct address on it.I have emailed Koko s contact hoping for an easy resolution
aka BMWST?
advNZer? is offline   Reply With Quote
Old 07-28-2012, 02:19 AM   #709
ontic
Oddometer: 1,070
Originally Posted by supershaft View Post
The main advantage of using a shim stack in most of the models is finally being able to get enough rebound without too much compression. Separated damping? I don't think I would need a shim stack but that's just me. If I couldn't get what I wanted from different oil I suspect I would just modify my damper rods.
We are talking about forks here aren't we?
Doesn't having separate compression and rebound forks (such as the GS forks) accomplish that (at least to the point where you can manipulate each individually? Yet still they are found rather lacking by many (gold valve cartridge emulators seek to improve this).
I would think the main advantage of cartridge fork shim stacks over (orifice damping) damper rod forks would be the tunable non-linear damping?
This all gets a bit buried in confusing (to me) terms, however, where orifice damping gives you an extremely progressive (exponential looking) damping curve (often too soft at low speed and too hard at high speed), cartridge style shim stacks, due to their tunable non-linear damping, give you a much flatter (or to get real confusing, linear) damping curve- a curve that can be manipulated through the shim stack.
eg. from here
click for some explanation, but Q axis is veloicty, and P axis force, curve A is basically an orifice damper, and the solid line B something more like a shim stacked cartridge damper would provide.
My point about the compression and rebound adjusters and how in an ideal situation one should have the adjustment set closer to the maximum is that this means the shim stack is flowing most of the oil (giving the advantage of the desired damping curve it provides), rather than the bleed valve flowing the oil which is essentially just another (variable) orifice. (You get most of the oil flowing through the shim stack and a little bit of adjustment to play with if for some reason you want to get a bit more damping)
Does that makes sense? At least that is how I believe my (WP50) forks and adjusters work. I have read about different ways that damping can be adjusted (which might nullify this argument), but I was under the impression most damping adjustable forks worked this way.
Again, back to the whole point, if you are running a cartridge fork with adjustable damping (when the adjuster is a bleed valve) set on or near the minimum, then it might be worth looking into getting your forks re-shimmed.
and please understand, this is just a discussion to help me understand this stuff rather than a debate. I don't know enough to debate.
OLH. It seems something odd is happening to you. How did your sag numbers compare to the others again? Considering the others are having much better results, It sounds like it must be something something simple...
1974 R90/6
1981 R80G/S
1994 XLR250R
ontic is offline   Reply With Quote
Old 07-28-2012, 08:05 AM   #710
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,695
Originally Posted by Stagehand View Post
your gaiters are compressing, but are you clunking out on bottom? I am probably compressing the gaiters all the way, who knows but I am not feeling the thing hit any limits of any kind over 99% of what I'm hitting, and I'm hitting ti as hard as I dare.
No clunking, but if gators were removed I sure it would be easy to max the forks out....that's what I don't want or like. IMO this shouldn't be happening.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 07-28-2012, 12:38 PM   #711
supershaft
because I can
Oddometer: 9,116
eg. from here
I know cartridge forks are better but if I could get the damper rods working good enough I wouldn't need them I suppose. You can get forks working real well without them.
I understand your point about re-shiming your stack in order to get into the middle of the adjuster where ever that is for you. That all makes sense and is probably what I would do but my advise about running as little damping as possible still holds water with that in mind. How many shims are on your stack always changes everything as far as how many click gets you so much damping.
The main thing is I am glad you guys are figuring out that the adjusters barely adjust. They are for FINE tuning the right number of shims whatever that might be for you or for fine tuning the preload AFTER you get it real close to what you want with spacers. It's a LOT of work and a LOT of money if you want to check out different springs. Good luck and thanks Sh.
supershaft is online now   Reply With Quote
Old 07-28-2012, 06:10 PM   #712
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,214
BTW- HH did mention a couple of times a 10mm spacer could be used to increase preload if needed.
Can one of you guys measure the O.D./I.D. of the spring spacer and share those dimensions with me?
I want to turn down a pair of shims and install them with little down time.
Old 07-28-2012, 06:47 PM   #713
Kokopelli OP
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,644
The OD of the spacer is 30mm (1.182 inches), the step in that fits into the spring is 23.13mm (0.911 inches) and the hole through the spacer is 18.73mm (0.747 inches)
I hope that makes sense.
R1150GS
R80GS Basic
Old 07-28-2012, 08:22 PM   #714
One Less Harley
Oddometer: 4,695
why the spacer??? I thought you were pleased. So you're no where near full compression of the gators under even hard braking??? Springs seem soft to me, but bad thing is I know nothing about suspension setup. They seem to take road bumps ok, need to get out on some dirt/gravel though.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 07-28-2012, 08:30 PM   #715
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,478
Here is huberts response to me regarding sag and spacers:
70mm sack is ok. 75mm sack is little more is not bad. You sink is too soft , make 10 mm more preload spacer.
Between *spring und the catridge tube. Is possible for you make spacer tube *with inside 24mm outside 30,mm and 10mm long ? Is this still too soft for you I can send you the harder spring and spacer
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 07-28-2012, 09:18 PM   #716
Kokopelli OP
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,644
Couldn't help it :-)
R1150GS
R80GS Basic
Old 07-28-2012, 10:33 PM   #717
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,214
why the spacer???
Playing with the geometry.
My first time with the R100GS forks on the R80ST and I want to reduce trail by raising the stanchions in triple tree.
It's now up 7mm but no further due to the bars being in the way, and I'm reluctant to go with bar risers.
So I'm thinking to put some of the adjusted preload inside the forks to gain clearance.
Renner screwed with this post 07-28-2012 at 11:06 PM
Old 07-29-2012, 01:54 PM   #718
Kokopelli OP
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,644
Sorry, slightly off-topic question, could someone please confirm that I need a 37mm socket to undo the nut at the top of the fork triple clamp? I need to do the steering head bearings on my G/S.
R1150GS
R80GS Basic
Old 07-29-2012, 07:29 PM   #719
One Less Harley
Oddometer: 4,695
My impressions of the .48 springs on the road- absorbs bumps well not harsh at all, mostly focusing on compression for now +1.75 turns in from topped out("0.00" being topped out +3.50 fully bottomed out), doesn't seem to bottom out when hitting 3" curb or 4" gravel "bump". I need to get out to some gravel and play with settings more. I've got about 65 mm of SAG (5 rings on preload), but would like less, maybe 58mm, as that is 1/3 of 175 mm. Reason I'm quoting 175mm is because that is the max usable travel with gators in place. Gators act as a rubber bump stop. I haven't actually confirmed the spec of 225mm that BMW list as fork travel. The front dives quickly under braking and uses all of the 175mm of fork travel when coming to a fairly quick stop (quicker than my usual sedate stops), I don't like that!!
Herr Hofmann, is sending me .58 springs and some spacers to try. Not sure if spacers will be 10mm and 20mm as he mentioned sending 20's. I don't like the idea of putting the AL spacer at the bottom of the spring as it will be hard to retrieve, but a temporary solution may be to tie it to the spring so it can be switched out easily. If the spacer is needed then I'll turn a new top spacer but make it longer, this will make changing easier.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 07-29-2012 at 08:56 PM
Old 07-29-2012, 08:30 PM   #720
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,478
I think in real world situations, the gaiter wouldnt really do anything in terms of acting as a compression stop. It might be tough to compress it by hand, but a 600 lb bike/rider combo at 45mph is a lot more than a little rubber boot can hold back, I would think, no?
Times are GMT -7.   It's 12:38 PM.
