View Results: Would you consider participating in a group buy?
Yes, if the price is right. 13 86.67%
No, these cartridges are way to expensive. 0 0%
No, USD forks will work so much better 2 13.33%
Voters: 15. You may not vote on this poll
Old 07-31-2012, 11:24 AM   #736
Kokopelli OP
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,721
Originally Posted by Beemerboff View Post
So if you are aiming to go soft/ long travel on an Airhead you are going to have to achieve something neither the factory or HPN or whoever built the bikes could do.
I had soft long travel on the old shock of My G/S. It was a Koni with the oil on the outside.
R1150GS
R80GS Basic
Kokopelli is offline   Reply With Quote
Old 08-02-2012, 12:00 AM   #737
advNZer?
advNZer?'s Avatar
Oddometer: 2,943
Originally Posted by SOLO LOBO View Post
The Ohlins on my G/S sure does, and the adjustments only take a few clicks to make big differences....
the ohlins on my gs does too its a whole magnitude better than the POS that came of it,but i am aware often that the shock can barely control that mass back there.
aka BMWST?
advNZer? is offline   Reply With Quote
Old 08-03-2012, 04:23 PM   #738
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,957
Got the spring from HH today- included are a couple of extra spacers, two nylon 35mm longer spacers (25mm AL ones were supplied w/ original order) to be tried with the 4.8 springs and 5.8 springs along with a 20mm spacer. What has me a little confused is the 5.8 spring has the 20mm spacer attached via a wire, and the spring is the same length as the 4.8 spring.
Here's the measurements of the 5.8 spring.
Brand..................Kg/mm.................. OAL............... OD............. ID........... Wire diameter......
HH Race Tech..........4.8................... 451mm...........32.86...........24.10............. 4.40...............
HH Race Tech..........5.8....................451mm........ ..32.97...........23.05..............4.60......... ......
SAG Measuremens- R80G/S, rider 74kg, 5wt fork oil
Brand..................Kg/mm..................# of rings.....Spacer ........SAG laden.........Petrol...........Comp / RB
HH Race Tech....... 4.8.........................4...........25mm..............66mm..............20L.............+1 .5/+1.5
HH Race Tech........4.8.........................2......... ..35mm..........+/-56mm..............12L.............+1.5/+1.5
HH Race Tech........4.8.........................3......... ..35mm..........53-55.1mm...........12L.............+1.5/+1.5
HH Race Tech....... 4.8.........................4...........35mm..........+/-54mm..............12L.............+1.5/+1.5
HH Race Tech....... 4.8.........................5...........35mm..........+/-56.8mm............12L............+1.5/+1.5
HH Race Tech........5.8....................
Note- I had some major variations on SAG measurements for the latest measurements w/ the 35mm spacer.
Looks like I've got some spacers and springs to mess around with for a while.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 08-04-2012 at 07:58 AM
Old 08-03-2012, 08:56 PM   #739
supershaft
because I can
Oddometer: 9,116
FWIW the standard springs in the HPN inserts give around 55 mm rider sag with a 90 KG rider, and are a perfect match for for the 450 lb spring which is stock issue on an Ohlins., which gives around 45 mm rider sag.
Preload on the fork springs is not a lot more than the depth of the thread on the cap, and preload on the shock as supplied by Ohlins at 18mm.
With this setting I need very little compression damping and a bit more rebound than the recommended mid point, but this depends on the tracks I am riding, and is adjusted on the move to suit.
You also need to adjust it to match the damping on the Ohlins, which changes as the fluid, etc, deteriorates with use, and the deterioration is quite noticeable when you are close to optimum with your settings.
How is Ohlins shock oil suppose to deteriorate? Other than water and dirt getting in?
Old 08-03-2012, 09:02 PM   #740
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 27,207
Heat?
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Old 08-03-2012, 11:53 PM   #741
Padmei
enamoured
Oddometer: 3,758
Perhaps BB means the fork oil deteriorating?
Padmei is offline   Reply With Quote
Old 08-04-2012, 05:47 AM   #742
Beemerboff
Oddometer: 2,348
Ohlins recommends that you have the shock serviced at 20,000 km intervals, and that includes a fluid change.
And with a quality, well set up shock you notice the decline, from just serviced out to service time.
But with the WP on my G/S matched to the stock forks it doesnt make much difference, it didnt change much in 70,000 km and servicing it didnt make much of a improvement - a second rate set up just stays second rate, as SS has confirmed.
Any oil degrades in use, fork and shock, but the shock fluid seems to go quicker than the full synthetic 7 1/2 wt HVI suspension fluid I use in the forks, probably due to the closer tolerances in the shock.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is offline   Reply With Quote
Old 08-04-2012, 12:12 PM   #743
supershaft
because I can
Oddometer: 9,116
Fork oil doesn't degrade in so much as it gets contaminated. There is very little shearing and the heat isn't that much. What is wearing out in those Ohlins besides needing to recharge the gas? Bushings? Having to rebuild your street bike shock every 12k miles is unacceptable to me. I picked Fox when I got a shock for my Mono for all the oil leaks and trouble I have seen with Ohlins. Hopefully it isn't the shock body wearing out?
Old 08-04-2012, 12:20 PM   #744
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 27,207
Of course they would spec a short service interval, to cover ass, much like the 70 hour bottom end replacement spec on the G450X and the minute you take it (the fluid) out of the shock to do anything, you would be silly to put it back in.
Old 08-04-2012, 02:20 PM   #745
supershaft
because I can
Oddometer: 9,116
That part of the story I can understand. It's the rest of it that I can't figure and since that is the whole reason for going into it in the first place it's not the answer I was looking for.
Old 08-04-2012, 02:56 PM   #746
One Less Harley
Oddometer: 4,957
Took the bike out for a short ride due to a kick ass thunder storm coming in...yeah I know. But anyway used only 150mm of fork travel on the ride. After riding w/ the 4.8 spring today I'm thinking the 5.8 will be too stiff. I'll still give it a go at a later date, but still want to fiddle with the 4.8 spring.
Running the 4.8 spring and 35mm spacer seems more acceptable to me. But dang I wish I knew what I was doing on the comp and rebound adjustments. My butt gauge just isn't that sensitive. It may just take A LOT of fiddling for me.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 08-04-2012, 04:00 PM   #747
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 27,207
Run em all the way in, and then all the way out a few times over the same piece of uneven ground. YOu'll feel a difference, I think. I agree, the .48's are a pretty good size spring. Doesnt pay to overthink it.
Old 08-04-2012, 05:21 PM   #748
Beemerboff
Oddometer: 2,348
The rougher the road the easier it is to tell what is wrong - I farted and fiddled around with the road set up my VFR , getting nowhere, but one run down a potholed and corrugated dirt track and I new what I needed.
Apart from clean underpants, that is.
Old 08-09-2012, 11:33 AM   #749
Kokopelli OP
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,721
One Canadian inmate has his cartridges sitting at customs in Toronto. He needs to pay the duty and pick them up. I haven't got time to look up who it is, but I would appreciate if this was done promptly. I guess they would be sent back to Racetech, if this is not done asap.
R1150GS
R80GS Basic
Old 08-09-2012, 12:46 PM   #750
akabeton
akabeton's Avatar
Oddometer: 437
That would be me :), Alex.
Out of contact for a few days. Riding in The Kootenays in Beautiful British Columbia.
[IMG][/IMG]
Customs and Duty all paid, now.
Strangely enough my shipment is doing the final 3500km of its 8000km journey by FedEx Ground ????
Any more reports on the inserts ???
1995 R100 GSPD
akabeton is offline   Reply With Quote
Times are GMT -7.   It's 05:10 PM.
