View Results: Would you consider participating in a group buy?
Yes, if the price is right. 13 86.67%
No, these cartridges are way to expensive. 0 0%
No, USD forks will work so much better 2 13.33%
Voters: 15. You may not vote on this poll
Old 09-01-2012, 02:41 PM   #766
Kokopelli OP
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,701
Originally Posted by One Less Harley View Post
Those 760's wear quick so you won't have to wait long. Dunlop 606's are good for rougher stuff, and maybe the Michelin T63, just not sure what sort of mileage you'll get, but my bet is more than the 760's. Heidenuas if you can get the rear are a good 50/50 tire, not a bad price and good miles onthe front and so so on the rear.
Mine with the 48's and +10mm spacer from the supplied one seem a little stiff. Still haven't tested well enough though. It's very hard to get a true feel one what to expect when switching from a DRZ to a G/S.
The K760 (front and rear) have only cost me $165 NZD fitted. I used to use T63, but I've never liked the front. It also depends what they have in stock when I turn up :-). Anyway, the K760 were already shagged, so I am just flogging the remaining few dollars out of it, but the noise is horrendous.
I'd love to fit a set of TKC80, I've always liked that tyre, just not the price. I'll also be looking at Mitas. The Heidenau are a cheap German brand, with an NZ premium price.
R1150GS
R80GS Basic
Kokopelli is offline   Reply With Quote
Old 09-01-2012, 04:44 PM   #767
akabeton
akabeton's Avatar
Oddometer: 427
Inserts
My inserts
[IMG][/IMG][IM
Your inserts
Now I don't feel so bad.
Any more performance reports?
Thanks Stagehand, sounds like you are enjoying yours.
1995 R100 GSPD
akabeton screwed with this post 09-01-2012 at 04:50 PM Reason: error
akabeton is online now   Reply With Quote
Old 09-01-2012, 05:04 PM   #768
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,816
My inserts, a few hundred road miles on them.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 09-02-2012, 03:43 AM   #769
advNZer?
advNZer?'s Avatar
Oddometer: 2,923
mine are still in the box too,just solved a no spark issue,(along with new ly powder coated battery box,newly recovered seat,and a new battery
aka BMWST?
advNZer? is offline   Reply With Quote
Old 09-02-2012, 04:05 AM   #770
igormortis
igormortis's Avatar
Oddometer: 1,380
Where’d you find your spark?
igormortis is offline   Reply With Quote
Old 09-03-2012, 02:07 AM   #771
advNZer?
advNZer?'s Avatar
Oddometer: 2,923
MD had a look,he reckons that 70 to 80 percent no spark is icu,so he swapped one out,but still no go,put the old one back and voila.So for th emoment i am running around with a new one to see if that solves the intermittent failure...the new battery and (maybe) ICU is great,starts up straight away,runs well.
I have to look at the steering head bearings i think i can detect a slight movement under hard braking
aka BMWST?
Old 09-07-2012, 10:49 AM   #772
naginalf
Handy Schtroumpf
naginalf's Avatar
Oddometer: 250
Originally Posted by OZbeemer View Post
So what made the difference? Seems like you were unhappy with the lighter springs and got the more stiff springs sent to you. Did you put in a bigger spacer? or?
I thought the spring rates were .48 and .58
edit: I have referred to them as 4.8 and 5.8 myself which is it...I'm so confused. ( as a matter of insignificance, my "heavy" springs with the HH settings fell right in the range with no initial adjustment.)
I just stumbled upon the answer to this today when looking at the WP extreme parts fiche. It noted 3 choices of springs, 4,2 (they use commas for decimals in other parts), 4,0 and 3,8 and a measurement in Newtons per millimeter. Newtons are a direct measurement of force that any self respecting German or Austrian engineer would use when measuring the FORCE applied to a fork spring. Most spring rates from metric speaking areas use kg/mm for springs, here in the US, we use lbs/in. These are both practical yet wrong because kg is a measurement of MASS and lbs is of course WEIGHT. But, they are practical because gravity is the same everywhere on earth. However, if you happen to be buying springs for your moon bike make sure you're doing your calculations in Newtons or you'll be flying off into space on every jump !
And I also did a quick conversion and found that it is quite easy to go between N/mm and kg/mm since 1N is about .098kg (here on earth) round that up to .1kg and you get a simple decimal move to convert (generally). So your HH measurements of 4.8 and 5.8 are in N/mm and are easily converted to .48 and .58kg/mm (actual numbers are more like .47 and .57kg/mm).
'91 R100GSPD
Adventures with a Type1 TARDIS.
naginalf screwed with this post 09-07-2012 at 10:58 AM
naginalf is offline   Reply With Quote
Old 11-07-2012, 09:15 PM   #773
Erland
Oddometer: 27
guts
Hello Gentlemen,
Akabeton and I are finally getting around to installing our sets.
One question remains- does the original top out spring and circlip at the bottom of the stantion get discarded from both sides? Is that what's meant by Racetech's instruction sheet? Or do we just toss the valve assembly bits but retain the spring and clip?
Was it Stagehand or Ozbeemer that left the spring in???
Also, what's been the conclusion on the 5 weight oil?
I'm guessing that because this thread has more or less gone silent, everyone is more or less satisfied?
Thanks,
Erland
Erland Kirste
n 49.291
w 123.142
Erland is offline   Reply With Quote
Old 11-07-2012, 09:25 PM   #774
Kokopelli OP
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,701
Mine are still waiting to go in. This should happen in about four weeks time. I am looking forward to fitting them, but soon after I will use them for a ride, so I need to be sure I've installed them correctly. I am also interested in other peoples' experiences.
R1150GS
R80GS Basic
Old 11-07-2012, 09:37 PM   #775
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,361
I knew it. Just garage bling then...tommorrow never happens
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is offline   Reply With Quote
Old 11-07-2012, 09:56 PM   #776
Kokopelli OP
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,701
You're just jealous
I had to spent all my time on the G/S and I have a day job, which I can't afford to give up. The G/S is moving out next Tuesday and I'll soon have time to install them. The DB1K will be the proof in the pudding, or maybe it's in the eating. Anyway, they are going in. The bling, I mean the inserts, will intimidate all the other riders (on R80GS bikes) and they will let me pass. maybe.
R1150GS
R80GS Basic
Old 11-08-2012, 02:09 AM   #777
advNZer?
advNZer?'s Avatar
Oddometer: 2,923
i still got mine too....seriously considering selling the bike tho
aka BMWST?
Old 11-08-2012, 07:55 AM   #778
akabeton
akabeton's Avatar
Oddometer: 427
Lost question
The question got lost while Alex and his friends were chatting over their morning beer
So just a friendly bump
Originally Posted by Erland View Post
Hello Gentlemen,
Thanks,
Erland
1995 R100 GSPD
Old 11-08-2012, 07:57 AM   #779
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,970
Havent been riding my PD a lot lately... as soon as I got the oil pan fixed it got really cold! ha! Nevertheless I like them a lot. I need to do more adjusting, and getting a real feel for the differences.
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 11-08-2012, 09:03 AM   #780
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,297
yes.
remove all the old guts.
"If you want to fix it with a rock, you have to stick to stone-age technology" -Anton
"...solving the latest crisis that is preventing my Airhead from taking me to the bar." -Beater-
Renner is offline   Reply With Quote
Times are GMT -7.   It's 09:04 PM.
