View Results: Would you consider participating in a group buy?
Yes, if the price is right. 13 86.67%
No, these cartridges are way to expensive. 0 0%
No, USD forks will work so much better 2 13.33%
Voters: 15. You may not vote on this poll
Old 12-17-2012, 02:38 PM   #796
Kokopelli OP
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,631
Well, I am already stuck, I'd completely forgotten that they use slotted nuts to hold the spring in. I don't have the tool for that, bummer. I thought I had changed a fork seal before, but that must have been on a different bike. I was expecting a retaining spring, or at least a proper nut, like on the G/S.
Is there a workaround, or do I need to ring my friendly dealer?
R1150GS
R80GS Basic
Kokopelli is offline   Reply With Quote
Old 12-17-2012, 02:44 PM   #797
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,131
A big plumbers wrench or a punch wont do the trick? :wink
how bout a shock spanner?
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 12-17-2012, 02:49 PM   #798
Kokopelli OP
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,631
I guess I won't need reuse that nut. My plumbers wrench just fell apart :-). But I'll try a punch. The problem is that the assembly is under pressure and with a punch there is little control.
R1150GS
R80GS Basic
Old 12-17-2012, 02:49 PM   #799
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,465
I can't picture the slotted nut in question here, but a flathead and hammer won't work? Works fine for shock preload adjustment.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 12-17-2012, 02:53 PM   #800
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,131
Old 12-17-2012, 02:56 PM   #801
Kokopelli OP
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,631
Thanks, I got it off, It's just that I've had too many bad experiences using the wrong tools.
R1150GS
R80GS Basic
Old 12-17-2012, 02:56 PM   #802
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,131
ACtually, now that I am thinking about it, forget the crenellations, just use a 13mm or 17mm hexhead in the center of the thing to get it off. Attack it from the inside out This is what I use.
Stagehand screwed with this post 12-17-2012 at 03:14 PM
Old 12-17-2012, 02:56 PM   #803
Airhead Wrangler
Adios Mexico
Oddometer: 6,465
Yeperino. I vote punch/dull chisel/flathead screwdriver plus a hammer, unless you really want to keep it pretty lookin'. Loosen your top triple first and give the fork leg (not the cap) a little heat and it shouldn't take much.
Old 12-17-2012, 03:01 PM   #804
Kokopelli OP
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,631
That slotted nut only hold the indicators on, . Looks like I need a giant hex socket to get the rest out.
R1150GS
R80GS Basic
Old 12-17-2012, 03:03 PM   #805
Kokopelli OP
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,631
I've always wondered what those hex socket type tools in the tool set were for. Now I know. It's all there.
R1150GS
R80GS Basic
Old 12-17-2012, 03:11 PM   #806
Kokopelli OP
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,631
OK, I am in. Thanks for the support. It should be reasonably straight forward from here, I hope.
R1150GS
R80GS Basic
Old 12-17-2012, 06:30 PM   #807
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,668
find the appropriate size bolt and weld it to a 3/8 drive socket, that works well.
I had made a tool for the nut, with some flat stock and drilled two holes in it for pins that would catch the slotted ring and on the other side welded a nut for the inner plug. Too much work since your gonna toss that stuff.
Your gonna have to relocate the turn signals. I used fork clamps and turn signals from an F650 , had to make a small backer plate for the turn signals. (look here) Make sure the brackets don't hit the tank, flip around if needed.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 12-17-2012, 08:20 PM   #808
Kokopelli OP
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,631
I still need to buy new indicators. Before I get to that, I have another question. It says to tighten the screw at the bottom of the fork tube to 40nm. I could do it with one, but the other just keeps on rotating. I'll try again once the stanchion is back in the triple clamp. Also, I am not sure if I got the air gaps right. I did put an equal amount of oil in, so I am hoping that it will work out.
I had bought new bushes for the forks and had been deliberating whether to install them, as the old ones were still pretty good. When I checked the fit, I found that I had been sent the wrong bushes, so that took care of that decision.
Installing the spring is a pita. Thankfully my son is at home, so he could give me a hand.
R1150GS
R80GS Basic
Old 12-17-2012, 08:40 PM   #809
One Less Harley
Oddometer: 4,668
it might tighten down better w/ a load on the spring??? I can't remember if that worked for mine.
You'll get used to tightening the cap with the spring in the way. Three hands is best but it's doable with two. Just lightly tie a string around the nut to pull the inner rod up, when the rod is up, push down on the spring, get the spacer to hang on the nut, tighten the cap by hand, then snug things up.
I seem to remember turning the adjusters so the letters ("C" and "R") were pointing in the same direction at all the way out or in. Something like that.
Ok now I remember, loosen the triple clamps and turn the chrome slider to get the letters on adjusters to point to the same spot. Hope this make since. Think both letters at 12 o'clock with one ring showing.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 12-17-2012 at 08:52 PM
Old 12-17-2012, 09:25 PM   #810
Kokopelli OP
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,631
Nope, I can't get it to tighten. It looks like the old washer was left in there as well. Now there are two washers in there. If I open it up again the fork oil will piss out. I will have to keep an eye on this.
R1150GS
R80GS Basic
Times are GMT -7.   It's 08:08 AM.
