View Results: Would you consider participating in a group buy?
Yes, if the price is right. 13 86.67%
No, these cartridges are way to expensive. 0 0%
No, USD forks will work so much better 2 13.33%
Voters: 15. You may not vote on this poll
Old 01-08-2013, 12:25 AM   #841
Kokopelli OP
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,688
The inserts have now been thoroughly tested. While I am not the best suspension tester around, I have a reasonable idea of what I like.
The front feels very planted on the road. It is firm, but still suck up what it needs to. However, I have not bought them for the road, I've bought them for stuff like this.
On very undulated tracks with cross ruts and the odd step, I was able to go pretty fast (well faster than I would have before). A few times I was caught out be unexpected holes or steps and was expecting trouble, but the suspension just dealt with it. Not once did it bottom out.
We went along some dry riverbeds with gravel that looked like sand. I was very happy the way the bike tracked and it was very stable at speed. Of course you still get the initial wobble while starting and stopping, but I don't think that's suspension related.
I have already forgotten how much I paid for the cartridges, but the grin on my face is still there.
R1150GS
R80GS Basic
Kokopelli is offline   Reply With Quote
Old 01-08-2013, 12:49 AM   #842
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,321
Then it was absolutely worth it. Top job...
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is online now   Reply With Quote
Old 01-23-2013, 02:40 PM   #843
akabeton
akabeton's Avatar
Oddometer: 420
I'm Happy.
I have had the bike out on the road a couple of times.
My initial observations are positive. I can feel quite an improvement compared to the stock set up.
As soon as the weather improves, I'll have a chance to ride some off road conditions, that will be a more realistic test.
Happy with the product.
The install was easy ( with help from Erland , Thanks again. )
The hardest part was trying to figure out where to put the stickers.
1995 R100 GSPD
akabeton is offline   Reply With Quote
Old 04-25-2013, 06:22 AM   #844
akabeton
akabeton's Avatar
Oddometer: 420
Originally Posted by Tobz View Post
Does anyone happen to have 4.8 springs that they're not using?
I purchased an 89 GS with the inserts and I'm working on setting em up. I'm shorter/lighter than the PO and he only had the heavy spring.
You could PM OneLessHarley?
1995 R100 GSPD
Old 10-01-2013, 12:44 AM   #845
Phreaky Phil
Oddometer: 1,855
Just thought I wold bump this thread.
Interested in long term feedback on these kits. Just how good are they.? How would they compare to a set of late model forks with the same travel ? I guess in theory they should be as good
What did you think of the quality of manufacture. ?
Cheers guys
Phreaky Phil is online now   Reply With Quote
Old 10-01-2013, 09:08 AM   #846
akabeton
akabeton's Avatar
Oddometer: 420
Very satisfied
I have been very happy so far.
I set them up as HH suggested and have had no problems in any riding conditions.
I have not made too many adjustments, simply because I don't understand the complexities of this simple system
When do I need more rebound or less compression ?
1995 R100 GSPD
Old 10-01-2013, 09:46 AM   #847
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,550
More rebound damping if you feel any bouncy pogo feeling. Less rebound if you find the forks "packing" or bottoming out due to not being able to rebound fast enough to absorb subsequent impacts.
More compression damping if you experience excessive brake dive or find yourself bottoming out too frequently despite correct spring weight and preload. Less compression damping if you feel excessive harshness on sharper impacts or if you notice that your forks (sprung and preloaded correctly) are not utilizing a enough of their potential travel.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 10-01-2013, 05:46 PM   #848
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,866
Mine are working out really well. They're a damn sight better than my xr250 forks, i'll give them that
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 10-02-2013, 01:13 AM   #849
Phreaky Phil
Oddometer: 1,855
Thanks guys, I had a big ride on the Beemer for the first time in a long time last weekend and what was clear was how shite the suspension is. The rear was harsh but that has a heavy spring for two up riding so thats an easy fix. The forks however won't be so easy and after the DRZ forks of my DR650 they aren't good. I have two options, keep and modify the Beemer ones or change them. Fitting the cartridge kits is probably the cheaper of the two as changing them out will require new clamps ( if you want to retain steering lock ) The Beemer forks are very rigid with the fork brace so changing them for bigger ones won't benefit in that aspect (in fact if you turn the front wheel against the steering stop and twist it further, there is more movement in my DRZ 49mm forks ) and I'm not tall enough to be able to have much longer travel. So the cartridge kits may be my best option.
I see the damping adjusters knobs that were on the original kits aren't on these kits. Shame would be cool to be able to adjust them on the fly.
Cheers Phil
Old 10-02-2013, 02:19 AM   #850
advNZer?
advNZer?'s Avatar
Oddometer: 2,903
Cheers Phil
I have a set with adjustors that I might part with.i got the heavier springs cos of the extra fuel the pd carries,never installed
aka BMWST?
advNZer? is offline   Reply With Quote
Old 10-02-2013, 02:40 AM   #851
Ras Thurlo
Desert Lion
Ras Thurlo's Avatar
Oddometer: 673
I bought 2 sets both with the stiffer spring (5.8?) one to go on my city 100GS and one for my farm-hack 80GS.
At the time HH said the stiffer spring was better even for the off-road 80GS, because of the extra weight in an HPN tank.
For my city ride I have really liked them, and bike now handles totally competently as a road ride.
But never got into them for the dirt bike as I found them too stiff, so swapped them out almost immediately for Marzocchi Magnum forks and have never looked back. However, I think this says more about what I want out of the 80GS than a fair appraisal of the cartridges.
Ras Thurlo is offline   Reply With Quote
Old 07-09-2014, 05:19 AM   #852
a_bakla
A&F
a_bakla's Avatar
Oddometer: 122
hhracetech cartidge oil level-viscosity
A friend of mine bought HHracetech cartidges for his 1993 r80gs. Order came without mounting instruction. Any one have this instruction ? I wonder oil level and viscosity of each fork leg. is there any other detail for mounting ?
a_bakla is offline   Reply With Quote
Old 07-09-2014, 06:46 AM   #853
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,866
I thought it was in the 400ml range. Close to stock, but you didn't need different amounts. Oil weight was light, like 5-7w. I would probably use 7 and 400 as good numbers to try.
Old 07-09-2014, 08:37 AM   #854
akabeton
akabeton's Avatar
Oddometer: 420
+1
1995 R100 GSPD
akabeton screwed with this post 07-09-2014 at 08:42 AM
Old 07-09-2014, 08:41 AM   #855
akabeton
akabeton's Avatar
Oddometer: 420
Good luck
Everything comes out.
Everything goes in.
I used 5w. ( no problems )
400-420 ml sounds right.
If you need the instructions, I may have them somewhere.
1995 R100 GSPD
Times are GMT -7.   It's 12:47 AM.
