Old 11-26-2011, 02:55 AM   #1
ktmr32 OP
Oddometer: 15
how to remove the flywheel with out any special tools
hi folks i am going soon to remove my flywheel and i was wondering if i could remove it with out any ktm tools?
Any suggestions?
thanks in advance
ktmr32 is offline   Reply With Quote
Old 11-26-2011, 08:20 AM   #2
Aquanout
Hooliganantic
Aquanout's Avatar
Oddometer: 748
Ignition rotor?
Aquanout is offline   Reply With Quote
Old 11-26-2011, 01:59 PM   #3
xdbx
Motorcycle Connoisseur
xdbx's Avatar
Oddometer: 2,512
you'll need a way to block the motor from spinning to rotate the bolt. Impact drivers work well for this, or you can use a penny into some meshing gears as well. In a pinch, you can also put rope into spark plug hole and turn the motor over into it. Wouldn't get creative unless you need to.
After you get the bolt off, you'll need to pull that rotor off, as its pressed on. You can use any press tool to do this. The easiest is often a steering wheel puller, or adjustable 3 jaw puller, purchased from an autoparts/hardware store, or rented from a local "O'reilly's or auto zone".
Daniel
2005 KTM 950 Adventure S
2004 KTM 525 exc
2006 Beta Rev3
xdbx is offline   Reply With Quote
Old 11-26-2011, 11:09 PM   #4
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,717
find 2 trees approximately 2 feet apart. remove the flywheel cover and park the bike one one side. attach a chain to the flywheel and attach the other end to a good truck. give yourself some slack so you can get some speed up before the chain goes taught. the rest is pretty intuitive.
or
put the bike in gear, hold the rear brake, and loosen the flywheel nut. Its been a while since I've been into a 950 flywheel but I think you have to pull the stator. you might be able to use 2 pprybars or large flat screw drivers...one on each side and carefully pry the flywheel off...carefully being the key word. never done this one a 950 so its all about watching and taking it slow. if it looks like you will damage the case or scratch something than i would advise looking into a puller
Seth S
Seth S screwed with this post 11-26-2011 at 11:18 PM
Seth S is online now   Reply With Quote
Old 11-27-2011, 12:06 AM   #5
BLUE(UK)
BLUE(UK)'s Avatar
Oddometer: 3,423
I was told it is OK to just lock up the crank with the crank locking bolt at TDC and undo it although this was AFTER i'd used my own method of using a 50pence coin in the teeth.
Getting it off....I took mine in to my local dealer who used the proper puller to remove it since I always buy my parts from there they do a few bits for me for free. No way would I have managed to get it off without the proper puller.
BLUE(UK) is offline   Reply With Quote
Old 11-27-2011, 02:31 AM   #6
ktmr32 OP
Oddometer: 15
thanks guys
Old 11-27-2011, 02:59 AM   #7
garmei
garmei's Avatar
Oddometer: 90
A mate of mine made me a copy of the KTM puller (large bolt and grub screw). That didn't work (the grub screw just kep being pushed into the balancer shaft), so i tapped a hole into the bolt and converted it into a slide hammer with some stud bar and a heavy tube and some washers. Heat, anti seize and half an hour of furious bashing didn't move it one bit. I just replaced the rear cam chain and left the front for another day. That sucker is really stuck on there.
garmei is offline   Reply With Quote
Old 11-27-2011, 03:45 AM   #8
BLUE(UK)
BLUE(UK)'s Avatar
Oddometer: 3,423
Sounds like the only solution is to pay a shop if the engine is out or buy the tool and once you've used it,either rent it out or sell it on for $10 less each time until it becomes cheap enough for someone to just keep it.
Old 11-27-2011, 06:58 AM   #9
kamanya
Andrew to most
kamanya's Avatar
Oddometer: 1,322
If you bike is pre-2005, just go to your local bolt shop and ask for the following;
A grub screw, 16mm diameter with a 2mm thread pitch. The large bolt is 20mm diameter with a 1.5mm thread pitch.
CAUTION
IF it is post 2005, then the grub screw is a finer thread - I don't know it at the mo, but someone will be along soon I am sure.
The grub'ed threaded one or "pressure screw" that KTM refer to (600.29.009.010 up to 2004 and 600.29.009.110 for 2005 and later) threads into the crank. By itself it can't pull anything. It just screws into the crank.
Then you have to thread the second puller (or in this case the pusher) into the generator; 600.29.009.000. If you look you can see a fine thread in the generator.
Lock the engine with the locking bolt, then;
The idea is that the grubbed pressure screw sits just proud of the end of the crank and takes up the pressure that the second puller will exert when you start putting torque into it. This second one threads into the generator and as you torque it, it comes up against the pressure screw. The crank is going nowhere so it ends up pushing the generator off.
It doesn't take much force to get it off using these tools, but then a thread multiplies the input torque hugely. I wouldn't want to try lever it off, I think it would take a lot of persuading.
I often wonder where that road goes? And that, has usually made all the difference. Appologies to Mr Frost
kamanya screwed with this post 11-27-2011 at 07:03 AM
kamanya is online now   Reply With Quote
Old 11-27-2011, 09:03 AM   #10
Aquanout
Hooliganantic
Aquanout's Avatar
Oddometer: 748
Yep, what Kamanya wrote. Pullers and heat are not good to use on the ignition rotor.
Old 07-14-2012, 12:14 PM   #11
Lil' Irv
Lil' Irv's Avatar
Oddometer: 317
Just had to do this after my stator and flywheel were trashed by broken rotor bolts. In the grand scheme of things the added cost for the puller wasn't that much more so I just ordered both bolts along with the other parts. Wouldn't you know that everything came except for the smaller bolt that goes in the crankshaft. KTM says they're backordered and they don't know when they'll come from the Fatherland. So I picked up 10 grub screws (smallest number I could buy) from Grainger for about 5 bucks to give it a try.
Unfortunately the pitch is steeper on the small bolt than the large bolt so every time it started to snug up the small bolt walked away. Tried this several times with the same result. The large bolt does make contact with the crank end but I was scared to reef on that and make matters worse.
I was considering cutting one of the grub screws in half so I could bottom one out and follow it with the cut one as a solution. Before I got that far I decided to try a little heat on it so I heated the hub of the flywheel with a MAP gas torch for not even 10 seconds. Quickly threaded the large bolt in finger tight and put the wrench to it thinking just a little pressure, don't get carried away and f* things up! I didn't even turn it an 1/8 of a turn and the flywheel just came off, no pop, no fanfare, just came right off. The crank end was just barely warm to the touch.
So heat can help if used quickly and judiciously.
i__i__i
-----@--@--(_)--@--@-----
Lil' Irv is offline   Reply With Quote
Old 07-16-2012, 06:29 AM   #12
BillyD
BillyD's Avatar
Oddometer: 635
Years ago, my auto shop teacher said, "if you need a tool and don't buy it, you pay for it anyway."
No truer words have ever been spoken.
Bill
KTM '08 690 RFR, '08 990Adv S (carbs), '07 640Adv, '03 540EXC, Ducati 851, Moto Guzzi 850 Lemans, Ercole & 2VT and Yamaha RD350.
BillyD is offline   Reply With Quote
Old 07-16-2012, 08:10 AM   #13
walstibsf
ADVENTURE-HOLIC
walstibsf's Avatar
Oddometer: 212
or
The trees are just for shade, right?
W A L S T I B........ S F......................
what a long strange trip it's been......SO FAR......
walstibsf is offline   Reply With Quote
Old 03-07-2013, 03:53 AM   #14
Datan556
Datan556's Avatar
Oddometer: 97
damn that takes me back!
Suffering is caused by desire, A. Sh.
Datan556 is offline   Reply With Quote
Old 03-08-2013, 06:25 AM   #15
RedRupert
Brit in the Soviet Union
RedRupert's Avatar
Location: Riga, Latvia / Bergerac, France / Colchester, UK
Oddometer: 582
CAUTION
That is how I've been doing it. It's easy that way.
The two parts cost an unbelievable €40 from KTM.
You could cut down your flywheel bolt to use as a grub-screw, but check the price and availability of a replacement before you do.
Early bikes had an M16 x 2 mm grub screw (and flywheel retaining bolt). Later bikes had an M16 x 1.5 mm grub screw.
Check to see which one you've got, by measuring the tread pitch of your flywheel bolt, this is the 1.5 mm version from a 990:
KTM 970 Adventure (2004 with carbed 2008 SD 990)
Yamaha WR 450 F
Honda 650 Dominator (1988)
Kawasaki KLR 650 (1988)
Yamaha RD 350 LC (1984)
RedRupert screwed with this post 03-08-2013 at 11:35 AM
RedRupert is offline   Reply With Quote
Times are GMT -7.   It's 03:06 PM.
