Old 11-26-2011, 01:57 PM   #1
halmc OP
Turkey T*urd
halmc's Avatar
Oddometer: 2,158
Two smoke boring
I have a Yamaha IT 175 that needs an oversized piston fitted. Everyone in my neck o' the woods wants to hone the cylinder, but I want it bored.
My question: any folks out there in ADV land have a machine shop that they use to bore small (~67mm) jugs? Although I'm in N. Fla, I don't mind shipping via ups, etc to a machine shop in a distant place.
PS: I've looked for a two stroke section of ADV, but never found one. If this note belongs somewhere else, please PM me and let me put it there.
BMW R1200RT; KTM 300 XCW; KTM 400 EXC: Suzuki 350SE; Buell X-1
Always forgive your enemies, but never forget their names -- JFK
halmc is offline   Reply With Quote
Old 11-26-2011, 02:21 PM   #2
SpeedFourJoe
Oddometer: 44
I'd check with Enduronut on http://yamahaenduro.com/. He really knows the old Yamahas. I think he charges $40 for bore, hone, and chamfer.
SpeedFourJoe is offline   Reply With Quote
Old 11-26-2011, 02:22 PM   #3
mykill
odd
mykill's Avatar
Oddometer: 1,166
Try Gary at http://www.spec2.com/
He has been doing 2 strokes forever and knows Yamahas intimately. He also did all the boring for Moto Carrera as well as numerous other shops around So. Cal.
Never underestimate the laxative properties of motorcycling.
mykill is offline   Reply With Quote
Old 11-26-2011, 02:37 PM   #4
MSrider
Rebel with a sixfiddy
MSrider's Avatar
Oddometer: 4,276
Send me a PM. We can do it here.
http://www.titanracinginc.com/
KOKA
MSrider is offline   Reply With Quote
Old 11-26-2011, 03:08 PM   #5
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
The oversize piston fitment process involves both, first we bore, then we hone to final size and cross hatch pattern.
Old 11-26-2011, 03:46 PM   #6
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,286
This normally is the correct procedure. However, it does depend upon how much material needs to be removed.
"I couldn't wait for success, so I went ahead without it."
Strong Bad is offline   Reply With Quote
Old 11-26-2011, 05:01 PM   #7
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
All japanese motorcycle pistons are offered in .5mm, 1.0mm, 1.5mm O.S., and so, the minimum bore is .5mm, (he didn't specify the amount needed to clean) way more than is practical to hone out.
Old 11-26-2011, 05:37 PM   #8
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,270
surely there's a shop in your area that could bore it. the real question is why does everyone want to hone it? is it not bad, and you just wanna bore it for peace of mind? i know on my it200 that is now on last bore, i wish a hone was all it needed - it200 cylinders do not grow on trees... make sure the ports are chamfered too.... have had a few cylinders come in that were not chamfered, don't know why....
current bikes
stainlesscycle is offline   Reply With Quote
Old 11-26-2011, 09:42 PM   #9
Duck_Pilot
Retired Roadracer
Oddometer: 6,020
You are incorrect here, Sir. Some OEM & aftermarket suppliers offer in increments of 0.25mm....especially in racing-specific engines. I know this to be true of the Suzi PE-175 - the Yamaha IT-175's ISDE arch-rival. It's worth a look-see in Yamaha's FREE online lookup to be sure.
*EDIT* I took a quick look on "Yamaha-Motor.com" and saw that the 1982 model had 4 oversize piston kits available, in +0.25, +0.50, +0.75 & 1.0mm. I had not noticed the OP's model year, but I suspect that the same pattern follows for most years, based on my past professional experience with Yamaha.
" A man that can have patience, can have what he will." - Benjamin Franklin
"Man cannot imagine how life could be more difficult or complex. But Congress can." - Cullen Hightower
Honestly, I *do* like Socialists. They just need a little tartar sauce.
Duck_Pilot screwed with this post 11-26-2011 at 10:40 PM Reason: Fumbly fangerz.
Duck_Pilot is offline   Reply With Quote
Old 11-27-2011, 07:05 AM   #10
anotherguy
anotherguy's Avatar
Oddometer: 6,631
Two stroke cylinders are hard on boring tools. The interrupted cut beats the hell outta carbide. That's why I prefer to hone .010"/.025MM. If it needs more than that boring is OK but I'd rather not. Modern stones can take a lot of material out fast. Sometimes with cast in liners boring is needed to square the bore up. Yamaha is particularly bad with that.
you don't see luggage racks on a hearse..........act accordingly
Old 11-27-2011, 08:23 AM   #11
baloneyskin daddy
bikaholic
Oddometer: 2,157
If the cyl .isn't worn and clearances are fine don't waste the money on a bore job. Theres very little hp.to be gained by simply boring it out, however it will run hotter with each increase in size causing more rapid wear.
baloneyskin daddy is offline   Reply With Quote
Old 11-27-2011, 01:33 PM   #12
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
LOL, I knew it. I thought of writing "most" but got lazy. Carry on. Hone away.
Old 11-28-2011, 04:46 PM   #13
halmc OP
Turkey T*urd
halmc's Avatar
Oddometer: 2,158
Thanks for all comments. I was interested in boring as opposed to honing as the conventional wisdom holds that honing alone (not the finish honing to which one inmate refers) replicates out-of-round condition, whereas boring ensures a constant radius and squares the bore with the base. No?
Old 11-28-2011, 06:39 PM   #14
anotherguy
anotherguy's Avatar
Oddometer: 6,631
No. A properly honed bore is as round and true and they get. The guide shoes keep the stones from removing in the low spots. It goes-drill-ream-bore-hone-lap in order of precision. I use a hone/stone set similar to this for big bore two strokes or smaller bore with large ports. The guide shoes follow the high spots and make the stones do the same until they're gone. It does take an experienced touch to get a two stroke right.
Does that explain it well enough?
Old 11-28-2011, 07:37 PM   #15
showkey
Oddometer: 1,955
One thing no matter how the cylinder is resized:
If it is not done correctly and the shirt clearance is not exact to the new spec (about .0009 to .0012") check the book) and have near zero taper and zero out of round the OP will continue this thread with:
NOW the engine has ring rattle or piston slap noise
Bore ( to get a perfect hole) and hone to the perfect size and cross hatch is the best way to insure success
There are dozens of other threads stating 2 stroke bored or honed by a guy use to chevy block clearances and now the new piston has .003 or .004" skirt clearance with piston rattle after rebuild.
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X
1971 CT90,1981 C70, 1986 TRX 250,
1993 TRX300 4X4, 2001 TRX500 4x4, 1987 XR250L
showkey is online now   Reply With Quote
Times are GMT -7.   It's 04:57 PM.
