Old 02-06-2012, 10:02 AM   #196
HarveyMushman
commutingmysentence
HarveyMushman's Avatar
Oddometer: 16,262
Originally Posted by g容g View Post
seems McLaren is either really right... or really wrong (or it really won't matter much).
The Woking crew seems to be making a habit of starting each season on the back foot, with respect to aero developments.
Tim
photo galleries
HarveyMushman is offline   Reply With Quote
Old 02-06-2012, 10:05 AM   #197
g容g
Canadian living in exile
g容g's Avatar
Oddometer: 6,469
one more
Greg
Europe 2013 Europe 2012 Europe 2011 England 2010 Gaspe PQ 2008 Nova Scotia 2007
Try to see the world beyond your front door.
g容g is online now   Reply With Quote
Old 02-06-2012, 10:27 AM   #198
g容g
g容g's Avatar
Oddometer: 6,469
ok one more
Greg
Old 02-06-2012, 11:21 AM   #199
RedRocket
Yeah! I want Cheesy Poofs
RedRocket's Avatar
Oddometer: 19,872
At least the Red Bull paint job hides its ugly duck bill nose
RedRocket is offline   Reply With Quote
Old 02-06-2012, 11:37 AM   #200
g容g
g容g's Avatar
Oddometer: 6,469
well it is interesting the Torro Rosso nose is a lot different than the Red Bull.
the red Bull launch though just has renderings & a weird video for now.
Greg
Old 02-06-2012, 12:34 PM   #201
anotherguy
anotherguy's Avatar
Oddometer: 6,208
It appears the RB8 has some ducting in the nose step. Man Newey has never even seen "inside the box". The ToroRosso has an interesting step treatment as well. Have they done any testing yet?
you don't see luggage racks on a hearse..........act accordingly
Old 02-06-2012, 12:38 PM   #202
g容g
g容g's Avatar
Oddometer: 6,469
testing has started for some of the teams at Jerez.
Kimi was out today in the Lotus.
oops.. I misspoke
they have been out purely for "filming purposes"
http://www.lotusf1team.com/The-E20-lights-up-Jerez.html
Greg
g容g screwed with this post 02-06-2012 at 12:50 PM
Old 02-06-2012, 01:41 PM   #203
wxwax
Excited Member
wxwax's Avatar
Oddometer: 78,495
Toro Rosso say they plan to change their nose to a "more aggressive" design. More or less saying they got it wrong for the launch.
This leaves McLaren as the outlier. Very interesting. Either they're geniuses or they blundered. Hard to see a middle ground.
Sid.
It has been said that man is a rational animal. All my life I have been searching for evidence which could support this.
-- Bertrand Russell
To make an apple pie from scratch,
you must first invent the universe.
-- Carl Sagan
wxwax is offline   Reply With Quote
Old 02-06-2012, 01:45 PM   #204
wxwax
Excited Member
wxwax's Avatar
Oddometer: 78,495
Read this after writing that.
The argument for "genius":
There is a school of thought that McLaren did not need to do the stepped nose because they anticipated the 2012 rules in their 2011 design and thus have an already well sorted concept.
Sid.
-- Bertrand Russell
-- Carl Sagan
Old 02-06-2012, 01:51 PM   #205
g容g
g容g's Avatar
Oddometer: 6,469
McLaren nose compared to "maximums"
Greg
Old 02-06-2012, 02:21 PM   #206
wxwax
Excited Member
wxwax's Avatar
Oddometer: 78,495
I feel sorry for plucky Sauber. Their technical director quits just a few weeks before the season starts.
Sid.
-- Bertrand Russell
-- Carl Sagan
Old 02-06-2012, 03:33 PM   #207
srad600
srad600's Avatar
Oddometer: 656
Honestly i don't even see the need for the step nose thing, is that just me? If the nose needs to be lowered the only thing in the way of that seems to be the front suspension where it meets the chassis, and if that can be designed in a way to lower the whole assembly, then the step is no longer necessary? Maybe this is the Maclaren approach? Maybe (most likely) I'm just not seeing something...
srad600 is offline   Reply With Quote
Old 02-07-2012, 08:01 AM   #208
g容g
g容g's Avatar
Oddometer: 6,469
from Tiwtter:
Ted Kravitz has just told the press room that the STR7 stopped 'because the car was disintegrating'. 1st red flag of 2012!
Greg
Old 02-07-2012, 10:07 AM   #209
doyle
RallyRaidReview-ing
doyle's Avatar
Oddometer: 23,302
The limit becomes one of geometry. The upper and lower wishbones have to be a certain distance apart on order for the wheel/upright to maintain the proper angles through it's movement. That said, most of this nose issue is prompted on the new rule that the nose height may not exceed 550mm due to the fact that some noses were getting too close to the cockpit minimum height of 625mm. The difference between the bulkhead/chassis placement and the nose height restriction is why the hump noses are now appearing. Simply moving the suspension down may help with CoG, but it then interferes with the aerodynamics through the massively important frontal zone which serves to channel the airflow to the most critical of areas, under the car and around the sidepods. The more 'free' area under the nose, the better they are able to control and sculpt the airflow. The last thing they want is to have to incorporate clunky suspension bits there.
RallyRaidReview - @RallyRaidReview
doyle screwed with this post 02-07-2012 at 10:18 AM
doyle is offline   Reply With Quote
Old 02-07-2012, 10:09 AM   #210
anotherguy
anotherguy's Avatar
Oddometer: 6,208
Originally Posted by doyle View Post
The limit becomes one of geometry. The upper and lower wishbones have to be a certain distance apart on order for the wheel/upright to maintain the proper angles through it's movement. That said, most of this nose issue is prompted on the new rule that the nose height may not exceed 550mm due to the fact that some noses were getting to close to the cockpit minimum height of 625mm. The difference between the bulkhead/chassis placement and the nose height restriction is why the hump noses are now appearing. Simply moving the suspension down may help with CoG, but it then interferes with the aerodynamics through the massively important frontal zone which serves to channel the airflow to the most critical of areas, under the car and around the sidepods. The more 'free' area under the nose, the better they are able to control and sculpt the airflow. The last thing they want is to have to incorporate clunky suspension bits there.
Thanks for stating that so I could understand why.
Times are GMT -7.   It's 10:46 AM.
