Old 11-30-2011, 12:36 PM   #16
exhaust_nut
exhaust_nut's Avatar
Oddometer: 190
LEDs
"PS: If anyone is interested, I'm about to finish up a full LED conversion (turn signals, brake light, full cluster) on my bike. Let me know if a guide would be desired. "
Beware if you convert to an LED for the GEN light in your gage cluster you may have a problem with the charging system. The alternator exciter circuit passes battery voltage through the alternator (GEN) bulb and the rotor to ground, you need an LED with the proper draw to get the battery to charge.
Or you can add on of these- CLICKY
exhaust_nut is offline   Reply With Quote
Old 11-30-2011, 01:02 PM   #17
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,344
Keep looking for the rare slider. You might get lucky.
It is an improvement to properly align the caliper and the change to an EBC or other aftermarket disk is a large improvement.
The steel braided brake lines, even if I don't like them, are more rigid. Riders report this is an improvement in braking.
Even a fresh cable from the handle bar to the under tank master cylinder can be an improvement. The old cables get stretchy as they age. This is the theory. I changed mine years ago and did feel good about doing that. This cable rarely goes bad so it rarely gets changed for any other reason. Riders don't think it needs changing if it works.
I lived on the streets of downtown San Francisco after I got out of the Army in 1969. It was really a different world in those days.
Charlie
disston is online now   Reply With Quote
Old 11-30-2011, 04:06 PM   #18
Arkwright
Grumpy ole Git
Arkwright's Avatar
Oddometer: 110
You should be able to get the correct slider and the other bits second hand from either Motobins or Motorworks in the UK. Personally I would do the conversion to Twin discs with Brembo brakes and handlebar mounted master cylinder but I have a lathe to make the necessary spacers and bushes (I'm doing it to my Caff Racer) similar to this.
Duncan
R1200 GS (07)
R80 being Cafe Racered (82)
R80 G/S (81)
R100 GSPD (92)
Arkwright is offline   Reply With Quote
Old 11-30-2011, 09:59 PM   #19
gfx OP
gfx
gfx's Avatar
Oddometer: 40
Are those 2-spot brembos on the same forks that use the ATE calipers? Did you do a conversion, or do you have a later model airhead with a different brake configuration?
I'm definitely interested in the dual disc, but for now I think a caliper rebuild will go a long way. The DPO's documentation of the bike stopped in 2001, and a caliper rebuild was on his to-do list. The front wheel seems to be squeaky at times and this is definitely going to be investigated; I figure I'll take it one step at a time instead of diving into a pricy and laborious job. Perhaps a rebuild and an EBC disc/pad will be satisfactory.
disston: I'm not one for SS brake lines either.
exhaust_nut: This is actually more elegant than what I was going to do, so thanks for that. As I'm sure you know, there is no LED that will fit and draw anywhere near the normal current. My bike doesn't have a volt meter, so it's a bit of a risk indeed. I'll note the risk in the guide I conjure up.
1977 BMW R100/7 "Satan's Lawnmower"
R.I.P - 1988 BMW K75S "Red Rocket"
gfx is offline   Reply With Quote
Old 12-01-2011, 03:24 PM   #20
Arkwright
Grumpy ole Git
Arkwright's Avatar
Oddometer: 110
Those are twin pot Brembos on 'K' Sport forks fitted to a '77 Caff Racer.
Duncan
R1200 GS (07)
R80 G/S (81)
R100 GSPD (92)
Old 12-01-2011, 03:47 PM   #21
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,344
Also notice no cross over on the exhaust system. I've always thought this would have no real advantage. How's it work?
Charlie
Old 12-02-2011, 12:43 AM   #22
gfx OP
gfx
gfx's Avatar
Oddometer: 40
You're the 2nd person I've seen with the K forks on an airhead, but the 1st person I've seen using the standard spoke wheels. Very jealous of your immensely improved handling and braking.
Old 12-02-2011, 12:54 AM   #23
Arkwright
Grumpy ole Git
Arkwright's Avatar
Oddometer: 110
Charlie
Firstly it's on Delortos, secondly it's got the latest Keihan 'Y' piece which is a proper 'Y' piece not a 'T' piece and thirdly it's twin plugged, runs a treat, high compression 1000cc. The customer wanted 'GS' downpipes!
Duncan
R1200 GS (07)
R80 G/S (81)
R100 GSPD (92)
Old 12-02-2011, 03:46 AM   #24
Kentucky
Oddometer: 1,224
My '83 RT has a slight leak at the handlebar MC. Is a rebuild difficult?
Barry
2013 Kymco Like 200i
2009 Piaggio BV500 Tourer
2009 Kawasaki KLR650
1973 Jawa 350 Californian two stroke twin
Kentucky is offline   Reply With Quote
Old 12-02-2011, 07:58 PM   #25
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,695
The only special tool you need is snap ring pliers, if the cylinder isn't scored then it's an easy fix.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 12-03-2011, 04:23 AM   #26
Kentucky
Oddometer: 1,224
The bike only has 27k miles so hopefully it is leaking due to sitting for the last 5 years or so. Thanks. I'm going to do it. I'm thinking there is a rebuild kit available. Today I will check on that.
Barry
Old 12-03-2011, 01:55 PM   #27
Motorace
Michelin Man
Motorace's Avatar
Oddometer: 556
Can you elaborate on the front brake conversion with regards to a bar mounted master cylinder?
I just bought a 77 R100/7 hack and the front brake is just horrible. Like a rock, no feel but it does slow down. Just not great.
I would like to keep the look of the single disk, but add an aftermarket disk like EBC, fresh pads, and clean the caliper. The front brake lever assembly seems to be a one piece unit - how would you add another master to this and still keep all the wiring and stuff intact?
Dave P
MSF AMA
1977 BMW R100/7 with Sputnik sidecar
Check out my eBay store!
Motorace is offline   Reply With Quote
Old 12-03-2011, 05:44 PM   #28
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,344
Sometimes the biggest improvement for the Ate can be to align the brake caliper. It is held onto the fork leg by an eccentric bolt that works like a cam. It is supposed to be adjusted so the caliper is in proper position. I'm not going to tell you what that is. My method is not even plain to me. I do take the cam/eccentric bolt out and clean/lube it. It is mentioned in the manuals and else where.
Charlie
Old 12-04-2011, 01:28 AM   #29
r77toy
Oddometer: 464
Arkwright:
What hub is used with the K forks?
What year/model K ?
r77toy is offline   Reply With Quote
Old 12-05-2011, 12:28 AM   #30
fishkens
Further...
Oddometer: 5,147
As far as steel braided brake lines go, I'm not a fan of those. I'll save my explanation for now unless you really want to know. If you want to use them then please go right ahead. I have one on my R90/6 right now but it came on the bike. I'm going to be eliminating it when I convert to dual ATE's in the near future.
Charlie
Just curious, so I'd love to hear your thoughts.
Thanks.
jim
p.s. I agree on your assessment of the eccentric bolt and ATE calipers. I used a sharpie to gauge whether or not the caliper was aligned.
fishkens is offline   Reply With Quote
Times are GMT -7.   It's 04:39 AM.
