Old 10-02-2013, 03:34 PM   #586
Droptarotter
Oddometer: 1,283
Mike;
What is the depth difference between the Squadron and the XL?
I have a 640 KTM Adventure that has been converted to the Enduro headlight( No more fairing).........I need to find a way to get some light out there. I'm toying with the idea of putting a Squadron into the KTM headlight panel.
Any suggestions would be appreciated!
Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is offline   Reply With Quote
Old 10-02-2013, 06:05 PM   #587
Queen of Spades
tall drink of water
Queen of Spades's Avatar
Oddometer: 961
Originally Posted by Baja Designs View Post
Hey guys
Sorry haven't been to active lately on the forums have been taking on multiple different tasks.
Like a few guys mentioned both the Squadron and Squadron XL use the same LED the Cree XML2 LED the main difference is the size of the housing allowing us to use the high speed spot reflector. This is the same reflector that we use in the High Speed OnX LED Light Bar. Therefore even greater distance can be achieved.
The smaller Squadron is a 3x3" and the Squadron XL is a 4.5 x 4.5". We also have new lenses for the XL to change the different beam patterns since the high speed spot reflector is used in each pattern. There is a clear lens for all spot, a half n half lens( half clear and half wide-cornering) this is the driving/combo, and there is an all diffused wide-cornering light.
The Squadron XL also has a built in 50% mode which will take place of the dimmer. We are working on a wiring adapter to utilize your stock hi/lo switches to activate the 50% and 100% modes.
We also have version of the Squadron for the 2008-2013 KTMs and a version for the 2014 as well. Retail pricing is $374.95 before the ADVrider discount.
Hope this helps let me know if you guys have any questions
Mike
Having recently bought the Squadron and dimmer kit.. ugh. I've not even installed mine, all of it is still in box/bags. I wish I'd known you were working on a kit that had a built in dim capability.
'99 KTM 640 LC4 Enduro http://www.youtube.com/watch?v=fifXkDQpda4 (January 2014 snow ride)
Queen of Spades is offline   Reply With Quote
Old 10-08-2013, 09:06 PM   #588
etingelefunts
retem-odo
etingelefunts's Avatar
Oddometer: 815
We also have version of the Squadron for the 2008-2013 KTMs and a version for the 2014 as well....hope this helps let me know if you guys have any questions
Mike
Hi Mike,
Your web site details only mention the 50% dimmer in the 2014 description, no mention of it under the 2008-2013 heading. (both same MSRP)
Mine is a 2013 KTM 350 EXC-F
  • Will the kit and wiring adapter provide dimming functions for that bike?
  • ETA?
Thanks in advance for any reply.
Less pondering. Simply march ahead, to the ends of this majestic planet.
etingelefunts is offline   Reply With Quote
Old 10-10-2013, 02:11 PM   #589
Baja Designs
Baja Designs
Baja Designs's Avatar
Oddometer: 625
Originally Posted by Droptarotter View Post
Mike;
Cheers
The depth between the motorcycle Squadron XL and the Squadron are actually the same. If you have about 2.75" you should be good.
Baja Designs is offline   Reply With Quote
Old 10-10-2013, 02:12 PM   #590
Baja Designs
Baja Designs
Oddometer: 625
Truly sorry about that.
Old 10-10-2013, 03:04 PM   #591
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,745
Mike, I know BD will be at SEMA, will you be there as well?
traveltoad is online now   Reply With Quote
Old 10-10-2013, 03:27 PM   #592
Baja Designs
Baja Designs
Oddometer: 625
Originally Posted by etingelefunts View Post
Hi Mike,
  • ETA?
Yes the 2008-13 has the 50% as well I will have our website guy fix that
Old 10-10-2013, 03:29 PM   #593
Baja Designs
Baja Designs
Oddometer: 625
Unfortunately probably not I wish I could.
Old 10-13-2013, 02:49 AM   #594
ElchQ
ElchQ's Avatar
Oddometer: 9
Mike,
it would be really cool if you would be able to dimm the Squadron (XL) with a little poti... Even 50% might be too bright to drive as a drv light on German streets. Any future plans?
Love the beam / driving combo, which would give me the perfect light for drv. here in Europe, but need that dimming capabilities from lets say 10..20% to full incl. a highbeam bypass...
All that with a waterproof poti of course :)
Cheers
ElchQ is offline   Reply With Quote
Old 10-13-2013, 03:22 AM   #595
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,445
Originally Posted by ElchQ View Post
Mike,
Cheers
+1. I find that 20 percent brightness is about the highest that I can run leds in traffic at night, mine switch to 100 percent when I hit the high beams courtesy of my Skene dimmer.
Sent from my PC36100 using Tapatalk 2
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
twinrider is offline   Reply With Quote
Old 10-13-2013, 09:36 AM   #596
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,567
Mike,
Cheers
Keep in mind that to dim an LED you need a PWM Dimmer (Pulse Width Modulator), not a regular potentiometer.
Additionally it's nice to have the high beam bypass so that you can run the LED dimmed with the low beam, but they go to 100% power when the high beam is turned on.
Baja Designs, Skene Designs, and ADVMonster all make a PWM dimmer w/ High beam by pass. I have used all three and find the ADVM one to be the simplest.
Old 10-14-2013, 11:22 AM   #597
ElchQ
ElchQ's Avatar
Oddometer: 9
Jupp... i know that you need a pwm rather than a normal Poti. my question
is do the Squadrons support an external PWM, or do they already have a
controll port for that?
Old 10-14-2013, 02:35 PM   #598
GravityDT
Oddometer: 60
Question regarding the Complete Squadron XL kits for the KTM 690. What year Headlight shell comes with the KTM kit or do they all fit the same? Can I specify which shell?
13 500 EXC
11 690 Enduro R SOLD
07 640 Adventure SOLD
12 350 XCF-W SOLD
GravityDT is offline   Reply With Quote
Old 10-14-2013, 07:29 PM   #599
Yellow Pig
Yellow Pig's Avatar
Oddometer: 7,567
No built in dimmer, but you can use any aftermarket pwm dimmer
Old 10-21-2013, 11:14 AM   #600
thetable
thetable's Avatar
Oddometer: 1,458
Anyone have a picture of the beam pattern of the new Squadron XL with the combination beam? It's peaking my interest, I'm also curious as to how bright it is at 50%. Not that I'm planning on playing in traffic in the dark, but sometimes, stuff happens.
thetable is offline   Reply With Quote
Times are GMT -7.   It's 07:09 AM.
