Old 11-30-2011, 07:19 PM   #16
LoJack
LoJack's Avatar
Oddometer: 1,605
Originally Posted by notmybikemodelname View Post
This is how. Not only is it only 5 lbs and acts as the sub frame, it also holds 6.7 gallons and allows for 11.5 inches of travel due to the over-swing arm shock position and angle being changed. And, it uses a G650X seat pan that has been finished by Renazco. This seat is half the weight of stock F650
Rob, I'll make you an aluminum swing arm and trade it for one of those. What do you say?
LoJack is offline   Reply With Quote
Old 11-30-2011, 07:20 PM   #17
notmybikemodelname
KOTW is a myth!
notmybikemodelname's Avatar
Location: I'm in jail Dad, and I like it here.............
Oddometer: 7,276
Sounds Good. Is it done yet?
But seriously, I'm down for that if you're serious.
And, I'm a great crash test dummy. Just ask anyone who know me. I can break anything............
BTW, this whole mod resulted in a weight savings of nearly 20 lbs. And the new seat allows for riding the bike like a real dirt bike. I can nearly slide all the way up to the bars on the seat and pinch the seat to whip it around like a small bike.
notmybikemodelname is offline   Reply With Quote
Old 11-30-2011, 07:28 PM   #18
LoJack
LoJack's Avatar
Oddometer: 1,605
Yes, serious. I want it to be worth thrashing and it would be slick to have one of those sub frame tanks of yours. But it's barely in the design stages. By spring ideally. The ground is just starting to freeze here. Trying to decide if I want to put studs on my 450's tires and join the local yahoos on the lakes.
Old 11-30-2011, 07:33 PM   #19
notmybikemodelname
KOTW is a myth!
Oddometer: 7,276
Well I'll ride and test mine through the winter and then make a set of complete molds for Scrimping. It's super trick, bolts right up and the fuel pump drops right in. You'll need to run a small battery like a Sycl and also a racing K&N filter without the intake snorkel. This mod really simplifies the bike too it's bare essentials.
These changes result in another 7-8lbs in weight savings.
Old 11-30-2011, 07:37 PM   #20
LoJack
LoJack's Avatar
Oddometer: 1,605
Got the Sycl already There is an airbox mod involved as well, right? Or do you just clamp the K&N right onto the intake?
Old 11-30-2011, 07:48 PM   #21
notmybikemodelname
KOTW is a myth!
Oddometer: 7,276
A small mounting tube about two inches long and the filter mounts straight to that.
Old 11-30-2011, 08:42 PM   #22
tmotten
Lefthand ride Dutchy
tmotten's Avatar
Oddometer: 2,472
Did you say 'mould'????
tmotten is offline   Reply With Quote
Old 11-30-2011, 08:49 PM   #23
tex_downey
tex_downey's Avatar
Oddometer: 468
NMBMN
That is cool. I dont know if I want to go that far but maybe.
How strong is it, could it carry 2 people?
also hes not lieing every ride I go to I hear a story about him. mostly crashing, crashing and drinking.
tex_downey is offline   Reply With Quote
Old 11-30-2011, 09:03 PM   #24
notmybikemodelname
KOTW is a myth!
Oddometer: 7,276
Originally Posted by tex_downey View Post
NMBMN
It should carry two people, but I never go two up anyways.
If that's the worst you've heard about me, I feel pretty good.
And............It's drinking, crashing, drinking.....
Old 12-01-2011, 06:53 AM   #25
rm_pt
rm_pt's Avatar
Oddometer: 66
i've a standard '06 GS and looking to improve it on these learning threads :) so, 2 questions:
1. will NGK Iridium spark plug make any difference from the standard ones (NGK D8EA) - any experience on those?
2. also on the oil filter any difference on K&N vs generic one?
thanks!
btw, tks to notmybikemodelname for the tip on Syclbatt i've read on another thread - impressive stuff!
rm_pt is offline   Reply With Quote
Old 12-01-2011, 08:41 AM   #26
notmybikemodelname
KOTW is a myth!
Oddometer: 7,276
No, I said "mold". Goddam Aussies........................................:ro fl
Old 12-01-2011, 01:28 PM   #27
tmotten
tmotten's Avatar
Oddometer: 2,472
Old 12-01-2011, 01:37 PM   #28
ferals5
800+652
ferals5's Avatar
Oddometer: 1,160
thanks!
No you won't save any weight with these items
ferals5 is online now   Reply With Quote
Old 12-01-2011, 01:47 PM   #29
rm_pt
rm_pt's Avatar
Oddometer: 66
ok ok ok, point taken , let's say better performance (?) on same weight...
Old 12-01-2011, 01:51 PM   #30
Parx400
Oddometer: 1,901
On a single spark yes they do help with some of the surging issues. On a 2 spark no. They will last longer but I don't think you would see any gains from it. I use to use those plugs in my wr400 and wr450. I didn't see any gains but I felt the bike ran better at higher altitudes. Since you have FI that's not an issue.
Parx400 is offline   Reply With Quote
Times are GMT -7.   It's 07:27 PM.
